Page 2 of 3
Re: Upload gas usage to mindergas.nl
Posted: Saturday 05 December 2020 9:54
by markruys
This script is more robust, uses user variables and doesn't upload to mindergas.nl at midnight to prevent overload:
-- Script to upload gas metering readings to mindergas.nl. To use this script
-- you first need to define the following user variables:
-- MINDERGAS_DEVICE_NAME (gas metering device name like 'Gas')
-- MINDERGAS_AUTH_TOKEN (cf https://www.mindergas.nl/member/api)
logging = {
level = domoticz.LOG_INFO,
marker = "MinderGas"
timer = {
'at 0:05' -- 5 minutes after midnight we take a sample of the gas metering device
httpResponses = {
'mindergas'
if item.isTimer then
local mindergas_auth_token = domoticz.variables('MINDERGAS_AUTH_TOKEN')
if mindergas_auth_token == nil then
return
local mindergas_device = domoticz.variables('MINDERGAS_DEVICE_NAME')
if mindergas_device == nil then
return
local gas_metering_device = domoticz.devices(mindergas_device.value)
if gas_metering_device == nil or gas_metering_device.counter == nil then
domoticz.log("Unknown or wrong metering device '" .. mindergas_device.value .. "'", domoticz.LOG_ERROR)
return
local yesterday = os.date("%Y-%m-%d", os.time() - 24 * 60 * 60)
domoticz.log('MinderGas meter reading for ' .. yesterday .. ' is ' .. gas_metering_device.counter, domoticz.LOG_INFO)
domoticz.openURL({
url = 'https://www.mindergas.nl/api/gas_meter_readings',
method = 'POST',
headers = {
['AUTH-TOKEN'] = mindergas_auth_token.value,
['Content-Type'] = 'application/json'
postData = {
reading = gas_metering_device.counter,
date = yesterday
callback = 'mindergas'
}).withinHour(4) -- to prevent peak load on MinderGas infra, upload the sample a few hours later
elseif item.isHTTPResponse then
if item.ok then
domoticz.log('Uploaded meter reading to MinderGas', domoticz.LOG_INFO)
domoticz.log('Failed to upload meter reading to MinderGas (code ' .. item.statusCode .. ')', domoticz.LOG_ERROR)
I like DzEvents!!
Posted: Sunday 06 December 2020 8:38
by markruys
Fixed a typo in the URL above, sorry about that.
Posted: Saturday 12 December 2020 18:20
by dutchronnie
Thanks markruys,
Sorry, it take a while before i see your post.
I stil have the problem, but now i wil try your script. I hope that it is the solution.
I wil let it know.
Posted: Monday 14 December 2020 10:14
by dutchronnie
Hello markruys,
I used the script you have posted, but i get the following error in Domoticz
2020-12-14 10:10:00.921 Error: dzVents: Error: (3.0.16) MinderGas: There is no uservariable with that name or id: gsMxrjmtFF3UxXz4DYre
Did i put the API on the wrong place?
logging = {
timer = {
'at 10:10' -- 5 minutes after midnight we take a sample of the gas metering device
httpResponses = {
'mindergas'
local mindergas_auth_token = domoticz.variables('gsMxrjmtFF3UxXz4DYre')
return
local mindergas_device = domoticz.variables('Gas')
return
return
domoticz.openURL({
method = 'POST',
headers = {
postData = {
date = yesterday
if item.ok then
Posted: Tuesday 05 January 2021 21:35
by MeAlbert
MinderGas made it also possible to upload the power usage from a heat pump.
A gas meter has a counter and that counter is used in the script. But a kWh device has only counterToday so I have to use WhTotal /1000 to get the right value in mindergas. In the original script from Roblom I managed it and it works. But in your script you use .value at some places and I don't know if your script works when I only change .counter in .WhTotal?
If so can you explain how I can be sure that this line: local gas_metering_device = domoticz.devices(mindergas_device.value) gives the WhTotal value?
Posted: Tuesday 05 January 2021 23:33
by waaren
MeAlbert wrote: ↑Tuesday 05 January 2021 21:35
Not sure if I understand you correctly but the available attributes for a kWh device in dzVents are:
- actualWatt: Number. Actual usage in Watt.
- counterToday: Number.
- usage: Number.
- WhToday: Number. Total Wh usage of the day. Note the unit is Wh and not kWh!
- WhTotal: Number. Total Wh usage.
I would have to see the script because I don't remember that I shared one on the forum but the line
certainly does not return any other value then a device object
btw. I have not seen a follow-up on the xml script I sent you via PM?
Posted: Tuesday 05 January 2021 23:57
by MeAlbert
This is the script
logging = {
timer = {
httpResponses = {
'mindergas'
return
return
return
domoticz.openURL({
method = 'POST',
headers = {
postData = {
date = yesterday
if item.ok then
I thought is was yours but it is from markruys. Sorry for the confusion.
Other answers in PM.
Posted: Wednesday 06 January 2021 0:06
by HvdW
The alternative way on RPI is a script like:
#!/bin/bash
#Token to authenticate with mindergas.nl
TOKEN=<your token>
#fetch meterstand (use jq to parse JSON object correctly)
# rid is the Idx number for the Gas reading in Setup->Devices in Domoticz
METERSTAND=`curl -s "http://127.0.0.1:8080/json.htm?type=devices&rid=<Idx number>" | jq '.result[0].Counter'| tr $
#Get OS date, and format it corectly.
NOW=$(date +"%Y-%m-%d")
#Build JSON by hand 😉
JSON='{ "date":"'$NOW'", "reading":"'$METERSTAND'" }'
#post using curl to API
curl -v -H "Content-Type:application/json" -H "AUTH-TOKEN:$TOKEN" -d "$JSON" https://www.mindergas.nl/a$
and in Cron 'crontab -e'
# mindergas uploaden
3 0 1 * * /home/pi/scripts/mindergas-upload.sh
3 0 15 * * /home/pi/scripts/mindergas-upload.sh
Credits for the code
to this site.
Posted: Wednesday 06 January 2021 7:41
by waaren
MeAlbert wrote: ↑Tuesday 05 January 2021 23:57
I have not received a PM. Please check your sent folder. If it reached 150 you will have to clean it.
Can you also share the working @roblom script in which you added the heatpump usage?
Posted: Wednesday 06 January 2021 11:52
by MeAlbert
new try on PM send just done.
The @problem script as you call it is the following.
/home/pi/javascript:void(0)domoticz/scripts/dzVents/scripts/upload_gas_usage_to_minderGas.lua
Author : Roblom
Adapted to heatpunp : MeAlbert
Description : This script collects the kWh values from Domoticz (for example from the smart meter) and uploads the values to a MinderGas account.
For more information about MinderGas, see the API instructions on their website on https://mindergas.nl/member/api
local AUTH_TOKEN = 'xxxxxxxxxxxxxxxxxxx'' -- Fill in here your Mindergas authentication token
active = true,
timer = {'at 00:05'},
httpResponses = {'UploadToMindergas'}
logging = {
level = domoticz.LOG_DEBUG,
marker = 'Mindergas'
local kWhUsageCounter = domoticz.devices(3).WhTotal/1000
local TodaysDate = tostring(domoticz.time.rawDate)
domoticz.log('The kWh usage is ' .. kWhUsageCounter, domoticz.LOG_INFO)
domoticz.log('The date is ' .. TodaysDate, domoticz.LOG_INFO )
domoticz.openURL({
method = 'POST',
headers = {
['Content-Type'] = 'application/json',
['AUTH-TOKEN'] = AUTH_TOKEN
callback = 'UploadToMindergas',
postData = {
['date'] = TodaysDate,
['reading'] = kWhUsageCounter
elseif (item.isHTTPResponse) then
if item.ok then -- self.statusCode >= 200 and self.statusCode <= 299
domoticz.log('kWh usage data is sucessfully upoaded to Mindergas.nl.', domoticz.LOG_INFO)
if (item.statusCode == 401) then
domoticz.log('There was an authorisation problem with the Mindergas.nl database.', domoticz.LOG_ERROR)
if (item.statusCode == 422) then
domoticz.log('There was an unprocessable enrty while trying to upload the gas usage data to Mindergas.nl', domoticz.LOG_ERROR)
domoticz.notify('Domoticz error', 'An error occured while trying to upload the gas usage data to Mindergas.nl', PRIORITY_NORMAL)
It worked ok but I like the other one with the delay and user variables
Posted: Wednesday 06 January 2021 12:49
by MeAlbert
Also adapted the other script. Understand the code and how to work with user variables.
Tested it and works fine only have to wait one hour before it appears in MinderGas.
-- Script to upload kWh metering readings to mindergas.nl. To use this script
-- you first need to define the following user variables in - setup - more options - User variables :
-- origianaly developed by : Roblom
-- optimized by : markruys
-- adapted to heatpump by : MeAlbert
-- MINDERGAS_DEVICE_NAME (Power metering device name like 'WP verbruik')
------ no changes needed below this point ----=
logging = {
timer = {
-- 'at 0:10' -- 5 minutes after midnight we take a sample of the gas metering device
'every minute'
httpResponses = {
'mindergas'
return
return
local kWh_metering_device = domoticz.devices(mindergas_device.value)
if kWh_metering_device == nil or kWh_metering_device.WhTotal == nil then
return
domoticz.log('MinderGas meter reading for ' .. yesterday .. ' is ' .. kWh_metering_device.WhTotal/1000, domoticz.LOG_INFO)
domoticz.openURL({
method = 'POST',
headers = {
postData = {
reading = kWh_metering_device.WhTotal/1000,
date = yesterday
}).withinHour(1) -- to prevent peak load on MinderGas infra, upload the sample the # of hours later filed in at .withinHour(#)
if item.ok then
Posted: Thursday 07 January 2021 0:47
by waaren
MeAlbert wrote: ↑Wednesday 06 January 2021 12:49
Great !
Do you also still have the same script for Gas? If so could the two be combined?
Posted: Thursday 07 January 2021 23:01
by MeAlbert
Posted: Saturday 09 January 2021 0:09
by HvdW
Used the script, replaced MINDERGAS_AUTH_TOKEN and MINDERGAS_DEVICE_NAME then:
MinderGas: There is no uservariable with that name or id: 1234mytoken5678
Posted: Saturday 09 January 2021 1:54
by waaren
HvdW wrote: ↑Saturday 09 January 2021 0:09
You should not enter your token and devicename but the domoticz user variablenames containing them.
Posted: Saturday 09 January 2021 14:49
by HvdW
Never too old to learn.
Posted: Wednesday 13 January 2021 22:35
by vandermark1977
Great that the script is updated for kWh & heatpumps!
I don't understand the new script though... I see something happening every minute now? Why is that the case when all i want is to upload kWh total from the heautpump device?
Can someone explain the logic of the new script?
Posted: Thursday 14 January 2021 0:48
by waaren
vandermark1977 wrote: ↑Wednesday 13 January 2021 22:35
That was just for test.
Change the lines from
timer = {
'every minute'
to
timer = {
'at 0:03' -- 3 minutes after midnight we take a sample of the gas metering device
-- 'every minute'
Posted: Friday 05 August 2022 22:06
by mvveelen
I still haven't been able to upload the values to Mindergas.nl from my Synology.
I only have the gas values and the name of the device is .... tadaaa .... Gas.
The API nr. I have, but what script should I use: dzVents - timer? Wat should be the code exactly, because I'm not sure where to put the different details.
Posted: Sunday 07 August 2022 14:42
by mvveelen
I use:
/home/pi/domoticz/scripts/dzVents/scripts/upload_gas_usage_to_minderGas.lua
Author : Roblom
Description : This script collects the gas values from Domoticz (for example from the smart meter) and uploads the values to a MinderGas account.
local AUTH_TOKEN = 'my_mindergas_API' -- Fill in here your Mindergas authentication token
active = true,
timer = {'at 12:26'},
logging = {
marker = "Mindergas"
local GasUsageCounter = domoticz.devices('Gas').counter
--local GasUsageCounter = domoticz.devices('Gas').counter
domoticz.log('The gas usage is ' .. GasUsageCounter, domoticz.LOG_INFO)
domoticz.openURL({
method = 'POST',
headers = {
postData = {
['reading'] = GasUsageCounter
if (item.statusCode == 201) then
domoticz.log('Gas usage data is sucessfully upoaded to Mindergas.nl.', domoticz.LOG_INFO)
domoticz.log('There was an unprocessable entry while trying to upload the gas usage data to Mindergas.nl', domoticz.LOG_ERROR)
but whatever I try, I keep getting the error message:
Error: EventSystem: in Mindergas: [string "--[[..."]:22: attempt to index a nil value (global 'domoticz')
Error on line 22? That is the logging-part and that seems to be OK. Is it the "Gas"-reading? Been at this for days now and I can't figure it out.
