Page 2 of 2
Re: OZW 1.6 RELEASED !!
Posted: Monday 13 May 2019 8:20
by Doler
Posted: Monday 13 May 2019 21:51
by antwan
No problems here with ...741
Posted: Tuesday 14 May 2019 20:48
by emme
1.6 messed up fibaro FGS222 double relay sqitch (2x1.5kW) that now show the parameters for the multisensor device
Posted: Tuesday 14 May 2019 21:40
by Holland
Just updated to 4.10751
And openzwave 1.6 returns the following
2019-05-14 21:38:23.826 Error: OpenZWave: Exception. Type: 102, Msg: ValueID passed to GetValueAsByte is not a Byte Value, File: /home/pi/open-zwave-read-only/cpp/src/Manager.cpp (Line 2192)
2019-05-14 21:38:33.013 Error: OpenZWave: Exception. Type: 102, Msg: ValueID passed to GetValueAsByte is not a Byte Value, File: /home/pi/open-zwave-read-only/cpp/src/Manager.cpp (Line 2192)
2019-05-14 21:38:33.203 Error: OpenZWave: Exception. Type: 102, Msg: ValueID passed to GetValueAsByte is not a Byte Value, File: /home/pi/open-zwave-read-only/cpp/src/Manager.cpp (Line 2192)
2019-05-14 21:38:33.393 Error: OpenZWave: Exception. Type: 102, Msg: ValueID passed to GetValueAsByte is not a Byte Value, File: /home/pi/open-zwave-read-only/cpp/src/Manager.cpp (Line 2192)
Posted: Tuesday 14 May 2019 22:17
by Skippiemanz
Holland wrote: Tuesday 14 May 2019 21:40
Same problem here.
It works thought but just some error messages.
Posted: Tuesday 14 May 2019 22:20
by pvm
I'm very happy the integration of 1.6 is ongoing, hope we get over the first issues soon. Thanks for putting in the effort
Posted: Thursday 16 May 2019 17:45
by JohnnyJohnny
I am getting the Exception as well, while everything else work it seems to screw up a sensative strip I added, everytime I try activating the strip it notices it and tries to add it's devices, but then I get the exception and nothing is added. So I hope this can be sorted out.
Posted: Monday 20 May 2019 20:35
by zedd
Seems to be solved in Domoticz 4.10798.
Had the same errors from my sensitive strip, not anymore since this version.
Posted: Monday 20 May 2019 20:59
by Gravityz
i still get the same errors with 10798.
i am using the jumbotroll build for synology
Posted: Friday 24 May 2019 13:49
by subtrEM
Domoticz 4.10806 on Raspi 3.
Z-Stick AEON Gen 5
Qbino Smart Plug ZMNHYD1 not functional after upgrade to 4.10806 from latest stable: activating switch gives error dialog (check hardware), switches are no longer accessible, do not report status. Log file has many "Error: OpenZWave: Exception. Type: 102..." events logged.
Reverting to 4.10717 resolves that issue.
Edit: could this be related to
https://github.com/OpenZWave/open-zwave/issues/1820?
Posted: Sunday 11 August 2019 0:04
by Piacco
After the update from ozw from 1.4 to 1.6 the double click function of my fibaro FGD212 Dimmer 2+ is not working anymore
With the double click action i trigger a script, so that the lights in my house all go off. Could this be fixed in a update?
Piacco
Posted: Monday 30 September 2019 20:36
by jake
I finally dared to update Domoticz from the latest stable to the most recent beta, this because of the OZW 1.6 horror stories. To my surprise all devices were instant available, no fiddling by healing nodes etc:
FIBARO System FGWPE/F Wall Plug
FIBARO System FGMS001 Motion Sensor
Danfoss Popp Radiator Thermostat
FIBARO System FGS222 Double Relay Switch 2x1.5kW
Aeotec DSA02203 Z-Stick S2
well done!
Posted: Friday 08 November 2019 13:14
by paolone919191
after update from stable to latest beta... everything is broken for me. I needed to fall back to latest stable.
On domoticz, prior to the complete death, I can see the message:
"Not all Nodes have been Queried yet, OpenZWave not fully initialized yet!"
on Openzwave, I can see a lot of
2019-11-08 13:11:30.755 Error, ERROR: Not enough space in stream buffer
2019-11-08 13:11:30.756 Always,
2019-11-08 13:11:30.756 Always, Dumping queued log messages
2019-11-08 13:11:30.756 Always, End of queued log message dump
in my house I have an AEON Labs ZW090 Z-Stick Gen5 EU gateway, some eurotronics SPIRITZ valves and 3 zwave repeaters.
Posted: Tuesday 20 April 2021 17:54
by wawrion
Am I the only one having empty OZW control panel? I am having that due to some....
Does anyone know how to solve that issue?
