Page 2 of 2
Re: dzvents rgb broadlink
Posted: Sunday 12 May 2019 0:13
by pvklink
My system crashes again, i am going to remove broadlink
Posted: Sunday 12 May 2019 10:14
by waaren
pvklink wrote: Saturday 11 May 2019 20:52 I upgraded the script like you said,
Added the global helper, dont know if i did that right, see below...
Almost.
you left out a comma at the end of the myHelperFunction.
helpers = {
		myHelperFunction = function(domoticz)
			-- code
should be
helpers = {
			-- code
		end,
helpers is here a Lua table. A Lua table can contain values, strings, sub-tables but also functions.
Every helper function is declared in this helpers table with the function name as key and the function body as value.
So if you are use domoticz.helpers.myHelperFunction in your script, you call the function body and this will be executed.
The comma is necessary to separate the table entries from each other.
Hope this clarifies a bit and also explain why the comma is required at that place.
Posted: Sunday 12 May 2019 20:18
by pvklink
Thanks and clear!
No hope that somebody has the same instability as me with broadlink and the latest domoticz and raspbian.
I cant use this script until this is solved...
Posted: Saturday 25 May 2019 17:38
by pvklink
Hi Waaren, i got broadlink working again!
So now finishing my last usb lamp script....
I used these posts to recover from...
i made the global_data.lua on scripts/dzvents/scripts
i see that there also is a global_data.lua on /scripts/templates/...
which one do i use / can i delete ?
Is it possible to call
dz.helpers.alertLidl(dz, "blauw", 12) without the 12, so that it stays on ?
		devices = {
			'test'
	execute = function(dz, device)
		dz.log('Device ' .. device.name .. ' was changed', dz.LOG_INFO)
global_data.lua
	data = {
		myGlobalVar = { initial = 12 }
	helpers = {
		alertLidl = function(dz, action, period)
			local controlVar = dz.variables("controlVar")
			local value = controlVar.value
        	        if controlVar.value ~= action then
                		controlVar.set(action)
                        	controlVar.set(value).afterSec(period)
	                        dz.log("alert requested; controlVar set to " .. action .. ". It will return to ".. value .. " after " .. period .. " seconds." ,dz.LOG_FORCE)
	                        dz.log("No changed needed; controlVar is already set to " .. value,dz.LOG_DEBUG)
usb_lamp
- maak variable controlVar Aan
-- dz.helpers.alertLidl(dz, "paars", 12) daarmee kun je t licht n kleur geven
-- let op ook /script/templates/global_data.dzVents
local controlVar = "controlVar"  -- var, define as type string
            on =    {   devices = { "usb lamp" }, -- controller , define as virtual selector Switch with all level as named in action table
                        variables = { controlVar },   -- var, define as type string
        logging =   {   level     =   domoticz.LOG_DEBUG,
                        marker    =   "Lidl"   },
    execute = function(dz, item)
        local triggerDevice_Off    = dz.devices(1415)
        local triggerDevice_Aan    = dz.devices(1414)
        local triggerDevice_Kleur  = dz.devices(1416)
        local triggerDevice_Wit    = dz.devices(1422)
        local triggerDevice_Flame  = dz.devices(1418)
        local triggerDevice_Play   = dz.devices(1419)
        local triggerDevice_Dim    = dz.devices(1420)
        local triggerDevice_Speed  = dz.devices(1421)
        local controlVar = dz.variables(controlVar)
        colors = { rood = 1,
                   groen = 2,
                   blauw = 3,
                   oranje = 4,
                   grijs = 5,
                   roze = 6,
                   paars = 7,
        actions =   {   Off = function() triggerDevice_Off.switchOn() return end,
                        Aan = function() triggerDevice_Aan.switchOn() return end,
                        Kleur = function(color)
                                    local repeats = (( colors[color] or 1 ) - 1)
                                    dz.log("Color requested :" .. tostring(color) .. "==>> repeats required " .. repeats ,dz.LOG_DEBUG )
                                    triggerDevice_Kleur.switchOn().repeatAfterSec(0.1, repeats )
                                    return
                                end,
                        Wit = function() triggerDevice_Aan.switchOn() triggerDevice_Wit.switchOn() return end,
                        Flame = function() triggerDevice_Aan.switchOn() triggerDevice_Flame.switchOn() return end,
                        Play = function() triggerDevice_Aan.switchOn() triggerDevice_Play.switchOn() return end,
                        Dim = function() triggerDevice_Aan.switchOn() triggerDevice_Dim.switchOn() return end,
                        Speed = function() triggerDevice_Aan.switchOn() triggerDevice_Speed.switchOn() return end,
        local function setVar( request )
            if controlVar.value ~= request then
                controlVar.set(request).silent()
        local function isColorAction( action )
            for color, number in pairs(colors) do -- check if called with one of the defined colors
                if action == color then
                    setVar(color)
                    actions["Kleur"](color)
                    return true
            return false
        local function doAction( action )
            if actions[action] then
                dz.log("known action requested ( " .. action .." )",dz.LOG_DEBUG )
                setVar(action)
                actions[action]()    -- Call required function with key = action
               dz.log("unknown action requested ( " .. action .." )",dz.LOG_ERROR )
               return false
        if item.isDevice and ( not ( isColorAction(item.levelName) ) ) then
            doAction(item.levelName)
        elseif item.isVariable and ( not ( isColorAction(item.value) ) ) then
            doAction(item.value)
Posted: Saturday 25 May 2019 23:04
by waaren
pvklink wrote: Saturday 25 May 2019 17:38 I made the global_data.lua on scripts/dzvents/scripts
Use the scripts/dzvents/scripts one. No need to delete the other one.
If you change the global_data part to this you can
return
    data =
    helpers =
                if period then
                    dz.log("alert requested; controlVar set to " .. action  ,dz.LOG_FORCE)
Posted: Sunday 26 May 2019 22:37
by pvklink
I did,
when the lamp is already on and has a color, turning it to blue or some other color does not give the right color because it is a state where the color numbers dont match anymore...
in this situation it also goes back to the wrong color state
Posted: Sunday 26 May 2019 22:56
by waaren
pvklink wrote: Sunday 26 May 2019 22:37 I did,
Is there a way to determine what the current color of the light is ?
If the lamp is switched Off does it reset to the initial state ?
Posted: Monday 27 May 2019 7:01
by pvklink
yes. with a off command it goes back to initial...
so changing colors must :
- registrate the times colors is clicked and use that nr to count how much signals it must give or
- when changing color first off on the device
the script can get a color for example red or a push on the color selector that means next color
Posted: Monday 27 May 2019 7:41
by waaren
pvklink wrote: Monday 27 May 2019 7:01 - register the times colors is clicked and use that nr to count how much signals it must give.
This solution is not robust enough. Chance of counter getting out of sync with reality is quite high.
Added a triggerDevice_Off.switchOn() in function Kleur.
-- let op ook scripts/dzVents/scripts/global_data.lua
                        marker    =   "Lidl"   },
                   groen = 2,
                   blauw = 3,
                   oranje = 4,
                   grijs = 5,
                   roze = 6,
                   paars = 7,
                                    return
                                end,
                    setVar(color)
                    return true
            return false
                setVar(action)
               return false
Posted: Monday 27 May 2019 19:17
by pvklink
ok,!
Almost there!
When the light is white and i do a
it becomes blue and then white again!
Same for red. etc.
When its off and i do a
dz.helpers.alertLidl(dz, "blauw", 12), it turns off after blue! perfect!
Only thing that does not work is when i click on "kleur" on the usb_lamp selector instead of a script command. It has to toggle the colors
kleur = id 20. It does not,
when it is off and i click on kleur it becomes red (the second color instead off white)
When it is already on and i click on kleur it goes off and then becomes red, i cant select colors by clicking it...
When ik click On or off, or flame, or speed or dim etc. they also all work fine!
So almost there !
i tried to change the script, amd it is working..... hope this is the right way ! i add a function and action with another name kleuren.
Default on is also changed in default to flame...
-- maak variable controlVar Aan
                        marker    =   "Lidl"   },
        local triggerDevice_Kleuren= dz.devices(1416)
                   groen = 2,
                   blauw = 3,
                   oranje = 4,
                   grijs = 5,
                   roze = 6,
                   paars = 7,
                        Aan = function() triggerDevice_Aan.switchOn() triggerDevice_Flame.switchOn() return end,
                        Kleuren = function() triggerDevice_Aan.switchOn() triggerDevice_Kleuren.switchOn() return end,
                                    return
                                end,
                    setVar(color)
                    return true
            return false
                setVar(action)
               return false
