Page 2 of 2
Re: Forecast of the yield of solar panels
Posted: Thursday 04 July 2019 13:46
by Toulon7559
@FireWizard
See the Addition at the bottom of
this message
Summary: if the predicted Power-value for 1 hour is extrapolated over 1 hour, then the result is equivalent to the Energy over that hour
, and reverse.
Therefore with the hourly input-data from forecast.solar, it does not really matter what unit you take for display, because the value in W or the value in Wh will the same.
Posted: Thursday 04 July 2019 16:11
by FireWizard
Hi Toulon7559,
You are right, I fully agree,
The values for Estimated Power in Watts and Estimated Energy in Wh or kWh
are identical.
Thank you for the reply.
Posted: Thursday 13 August 2020 14:08
by Toulon7559
Just puzzled, and therefore requesting your views ....
Since a year using the
dzvents-script in this message.
After a system crash & restauration the script running without showing errors in the log.
However, one of the devices (3148) does not refresh anymore [but no problem with the other 3 devices of same type (3126, 3127 and 3136)]:
somebody having a pragmatic solution?
Posted: Thursday 13 August 2020 14:40
by waaren
Toulon7559 wrote: Thursday 13 August 2020 14:08
My first step in the process of finding the issue would be to look at the log for the line with "watt-hours_cum today: "
(assuming the script has still LOG_DEBUG active)
Posted: Thursday 13 August 2020 15:43
by Toulon7559
Subject dzvents-script presently is only one at this machine.
With below lines would expect some input to the logging of Domoticz [?], but nothing appears
logging = {
level = domoticz.LOG_DEBUG, -- switch to LOG_ERROR when all OK
marker = webResponse
Posted: Thursday 13 August 2020 17:14
by waaren
Toulon7559 wrote: Thursday 13 August 2020 15:43
logging = {
If you don't see anything in the log then your settings for event logging / dzVents logging do probably prevent that.
Posted: Thursday 13 August 2020 19:14
by Toulon7559
@waaren,
Whatever the reason of the described error, stripping & tuning the mentioned script for serving device 3148 only was successful.
Now to remerge the 2 working scripts to return to 1 script (to save on calls to the website).
Or (as alternative approach) reduce the calling rate per script to stay within the allowance.
{in hindsight my experiments during restauration to get the scripts running again might have required more calls per time frame than allowed, causing a temporary blockade]
And next have a look why no logging visible for DzVents, because at the Setup-page of Domoticz all settings seem OK .....
