I think this is a pretty good approach.pgielen wrote: Tuesday 09 April 2019 12:24 By the way, I entered the gpio sequence to set production mode in /etc/rc.local so that if the pi reboots, Pizigate will still work.
Pizigate / Zigate not working Topic is solved
Re: Pizigate / Zigate not working
Correct. 255 make the Led blinking for ever. Which means you can pair new devices all of the time.
If you want to set to 0 (in order to disable Pairing new HW), do it first with 1 restart the plugin and then 0 restart the plugin.
As 0 as not impact at all
Just do a git pull to get 4.1.4 , this is fixed nowdomogijs wrote: Monday 08 April 2019 21:37 I have the same problems as Pgielen.
If i configure the plugin an choose PI for model this is not saved/updated. It is saved as usb.
Anybody ideas?
Greets Gijs
domogijs
When I start the plugin I get these errors: 2019-04-10 20:09:00.774 Error: (Zigate volg) onMessage : Frame size is bad, computed = 12 received = 21
2019-04-10 20:09:00.774 Error: (Zigate volg) onMessage : Frame CRC is bad, computed = 105 received = 151
Anybody ideas
Greets gijs
Anybody ideas
Greets gijs
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
This issue is related to the Software Reset done just after the Erase PDM.
Make sure that you have Erase PDM set to False , otherwise every time you'll restart you will remove all information from Zigate
Here is the reference to the bug :
https://github.com/fairecasoimeme/ZiGate/issues/164
domogijs
Ok thanks!
domogijs
Ok thanks.
I also successfully added ikea lamps now.
- pgielen
- Domoticz version: 2020.2
So did I, today!
https://robothuis.nl, RPi4B, RFXCOM XL, Aeotec Z-Stick, ESP Easy, Weatherstation, several switches and sensors, Ikea Trädfri, Philips Hue, Foscam, Reolink, Lyric T6, Ring
PS/ On the beta branche you have even now the Over-The-Air upgrade of Ikea/Tradfri firmware
domogijs
Good there is active deleopment going on. Thanks for the gpio tip (i found out the hard way
I sam trying to update but i dont know wich path.
./JennicModuleProgrammer -V 6 -P 115200 -f "<path to bin>" -s / dev / ttyUSB0
What to fill out over there?
Sorry i am noob
Greets Gijs
Sorry i am noob
Greets Gijs
This is quiet Zigate HW related. I suggest that you use : https://zigate.fr/forum/ there is an English channel, where you can report the issue.domogijs wrote: Saturday 13 April 2019 10:38 Good there is active deleopment going on. Thanks for the gpio tip (i found out the hard way)
Sorry i am noob
Greets Gijs
But here is where you can find the latest firmware version: https://github.com/fairecasoimeme/ZiGat ... ag/Release
domogijs
hmm reboot still also gives the firmware issue
this is how the file looks like. What am i doing wrong?
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
gpio mode 0 out
gpio mode 2 out
gpio write 2 1
gpio write 0 0
gpio write 0 1
exit 0
#!/bin/sh -e
# rc.local
# value on error.
# bits.
gpio mode 0 out
gpio mode 2 out
gpio write 2 1
gpio write 0 0
gpio write 0 1
exit 0
domogijs
seems like i am on tyhe right version allready: Zigate plugin 4.1.2 startedpipiche wrote: Saturday 13 April 2019 11:21This is quiet Zigate HW related. I suggest that you use : https://zigate.fr/forum/ there is an English channel, where you can report the issue.domogijs wrote: Saturday 13 April 2019 10:38 Good there is active deleopment going on. Thanks for the gpio tip (i found out the hard way)
Sorry i am noob
Greets Gijs
But still the PI flips to USB in setting up theb hardware.
Make sure you are on the latest version of the plugin, which seems not the casedomogijs wrote: Saturday 13 April 2019 11:27seems like i am on tyhe right version allready: Zigate plugin 4.1.2 startedpipiche wrote: Saturday 13 April 2019 11:21This is quiet Zigate HW related. I suggest that you use : https://zigate.fr/forum/ there is an English channel, where you can report the issue.domogijs wrote: Saturday 13 April 2019 10:38 Good there is active deleopment going on. Thanks for the gpio tip (i found out the hard way)
Sorry i am noob
Greets Gijs
git pull-
domogijs
I try to achieve this but the pins go back to deafult after reboot. What am i doing wrong?
#!/bin/sh -e
# rc.local
# value on error.
# bits.
gpio mode 0 out
gpio mode 2 out
gpio write 2 1
gpio write 0 0
gpio write 0 1
exit 0
Is the script executable ? Did you check that is correctly executed ?
Instead of the gpio command, I would instead refer to the. So if in the future there is some changes required, it will be automatically done without any changes to the rc.local
Tools/pi-zigate.sh run-
domogijs
used the tool and works!
Thanks.
Greets Gijs
Thanks.
Greets Gijs
That is safe!pgielen wrote: Tuesday 09 April 2019 12:24 By the way, I entered the gpio sequence to set production mode in /etc/rc.local so that if the pi reboots, Pizigate will still work.
Sjuul70
sudo apt install python3-dev
sudo apt-get update
sudo apt-get upgradeRaspbian Buster Lite
Happy pizigate-user now.
Yep that is correct, Domoticz Python Framework requires python-devSjuul70 wrote: Thursday 10 October 2019 19:50Raspberry pi 3B+Code: Select all
sudo apt install python3-dev sudo apt-get update sudo apt-get upgrade
Happy pizigate-user now.![]()
https://www.domoticz.com/wiki/Using_Python_plugins
