Page 2 of 2
Re: dzVents: MaxMin Temp and Humidity
Posted: Saturday 15 August 2020 23:36
by waaren
zavjah wrote: Saturday 15 August 2020 21:26 I'd like to combine this with a second script I have for rain level:
I would keep these script separate because they handle different type of sensors.
Can you check this one?
local RainLevelTest = 'getRainLevel'
return
    on=
        timer =
            'every Minute',
        httpResponses =
            RainLevelTest,
    logging =
        level = domoticz.LOG_DEBUG, --LOG_DEBUG, LOG_ERROR, LOG_INFO
        marker =    RainLevelTest,
    execute = function(dz, item)
        local rainDevice = dz.devices('Regen') -- name enclosed in quotes or number without quotes
        local regenMaenge = 8       -- Wieviel mm Regen braucht es, damti ich NICHT gieße?
        local regenZeitraum = 240     -- Hours vom Zeitpunkt des Skript lauf aus, also heute!
        local function getGraphData(dv, hours)
            if item.isDevice or item.isTimer then
                local period = 'day'
                if hours > 24 then
                    period = 'month'
                    if hours % 24 ~= 0 then
                        dz.log('Script can only calculate for multiples of 24 or < 24' )
                dz.openURL(
                    { url =  dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=rain&idx=' .. dv.idx .. '&range=' .. period, --&range=day oder &range=month
                     callback = RainLevelTest,
        local function getmmRain(rt, hours)
            local startDate = dz.time.addHours(-1 * math.floor(hours)).rawDateTime
            local mm = 0
            for index, record in ipairs(rt) do
                if record.d > startDate then
                    dz.log(record,dz.LOG_DEBUG)
                    mm = mm + record.mm
            return mm
        -- Main
           getGraphData(rainDevice, regenZeitraum)
        elseif item.ok and item.isJSON then
            dz.log('Regenmenge in den letzten ' .. (regenZeitraum) .. ' h: ' .. getmmRain(item.json.result, regenZeitraum) .. ' mm')
            dz.log('Keine valide Antwort von domoticz ',dz.LOG_ERROR)
            dz.log(item,dz.LOG_ERROR)
Posted: Sunday 16 August 2020 21:23
by zavjah
Hi waaren,
thx for your replay. It seems to me that your modified script does pretty much the same as mine, which in deed is based on one of yours from this forum :-).
Back to my initial question: I need the Information about the max temperature yesterday and the rain level within the last 24h in my main script for watering my garden. if I understood you correctly you suggest to have:
1. Script for Rain level
2. Script for max temperature
3. Script for watering that calls the their two and get the necessary Information.
I assume 1 and 2 should be kind of independant functions. Correct? If yes, then my questions are:
a) how do they should like and
b) how am I to call them from my main script (3)
thx,
zavjah
Posted: Sunday 16 August 2020 21:40
by waaren
zavjah wrote: Sunday 16 August 2020 21:23 It seems to me that your modified script does pretty much the same as mine, which in deed is based on one of yours from this forum :-).
Your script ignore the date/time of the records. It adds all values from the json return without checking if it should be part of the sum.
yes
Not quite. It should not call the scripts
You now only report the values to the domoticz log but it is more common that you use these values to update a virtual sensor or a uservariable. The main script for watering can then retrieve the values from the uservariables or the virtual sensors and apply it' s logic to decide what needs to be done.
Posted: Monday 17 August 2020 15:31
by zavjah
Hi wareen,
I've done following:
1. Created global_data.lua via domoticz scripting GUIO with following content:
        helpers = {},
        data = {
          MaxTempGestern = { initial = false },
          RegenGestern = { initial = false }
2. Then, to add values to the variables I have my scripts and provide values like this
        -- Main
            extremes = getExtremes(item.json.result)
            dz.globalData.MaxTempGestern = extremes.high.temperature
            dz.log('Regenmenge in den letzten 24h: ' .. getmm(item.json.result) .. 'mm')
            dz.globalData.RegenGestern = getmm(item.json.result)
3. When I try to read those variables in my main script I get some error about nill values. Did I forget something?
thx,
Zavjah
Posted: Monday 17 August 2020 15:56
by waaren
zavjah wrote: Monday 17 August 2020 15:31 3. When I try to read those variables in my main script I get some error about nill values. Did I forget something?
The code you show here looks OK.
Please share your main script and loglines. That might help in locating the issue.
Posted: Monday 17 August 2020 16:12
by zavjah
Hello waaren,
this is my global_data.lua
        helpers = {},
        data = {
This is globalData_MaxTempGestern.dzvent, that provides the value for MaxTempGestern:
local MaxTemperature = 'getMaxTemp'
return {on = {timer           =   {'every Minute'},                       -- Your preferred time
              httpResponses   =   { MaxTemperature }
        local tempDevice = dz.devices('Außen')
        local extremes = {}
            dz.openURL({    url = 'http://192.168.178.23:8080/json.htm?type=graph&sensor=temp&range=day&idx=' .. tempDevice.idx  .. '&range=day',
                            method = "GET",
                            callback = MaxTemperature })
            return
        local function getExtremes(rt)
            extremes.high               = {}
            extremes.high.temperature   = -256
            for key in ipairs(rt) do
                if tonumber(rt[key].te) > extremes.high.temperature then
                    extremes.high.temperature = tonumber(rt[key].te)
            return extremes
        -- Main
The globalData_RegenGestern supplies the value for MaxTempGestern:
return {on= {
            httpResponses = {RainLevelTest,},
        local regenZeitraum = 2     -- Tage vom Zeitpunkt des Skript lauf aus, also heute!
            dz.openURL(
                {url = 'http://192.168.178.23:8080/json.htm?type=graph&sensor=rain&idx=' .. rainDevice.idx .. '&range=day', --&range=day oder &range=week oder &range=month
            return
        local function getmm(rt)
            local startDate = (dz.time.addMinutes(-1 * regenZeitraum * 24 * 60)).rawDate
            local mm = 0
                mm = mm + record.mm
            return mm
-- Main
The main script, just for test, should report the values into the log:
	on = {timer = {'at 12:11'}
	execute = function(dz, timer)
        dz.log('Info aus Variablen: Regenmenge: ' .. dz.globalData.RegenGestern .. ' || MaxTemp: ' .. dz.globalData.MaxTempGestern)
Does this makes sense?
Cheers,
zavjah
Posted: Monday 17 August 2020 17:32
by waaren
zavjah wrote: Monday 17 August 2020 16:12 Does this makes sense?
Yes it does (apart from the earlier comment I posted that you ignore and data / time selection) but kind of hard to debug without log :D so if it does not work as expected you might need to add some log statements and will need to look at the log to see what happens.
Re: dzVents: MaxMin Temp and Humidity  [Solved]
Posted: Monday 17 August 2020 20:17
by zavjah
Hello waaren
I've turned on the DEBUG logging, but couldn't find any error. I put the values in global variables and when I print them out of the script that sets them it works. But I cannot retrieve them from another script.
So I decided to switch to virtual sensors and created one for rain and one for temperature and was able to update their values as needed. So it works now, thx.
Cheers,
Zavjah
Posted: Thursday 08 October 2020 11:43
by Nautilus
waaren wrote: Monday 21 January 2019 17:40
AYAMY wrote: Monday 21 January 2019 11:33 The ranges of the calculation are incorrect... The Entreme date is today (21 January ) and yesterday (20 January ) but the high\ low temperatures and high\low humidity are of the 16 January 2019 and 14 January 2019
Adjusted the script to make the range a configurable amount of hours.
Nice work waaren, I was looking for ideas to implement this kind of notifications from our summer cottage and this does the trick very well. I'm new to dzVents and while I checked the wiki I was not able to transform this (yet) to the kind of script that would loop through an array of sensors and combine the max/min values to one message. I tried by chancing the device.id to an array of devices and looping through them in the main section (which I assumed would give me the info I am after as separate messages), but there was clearly something wrong as it ended up in an infinite loop. Could you point me to the right direction, please? :)
Here's my attempt:
        local S1 = dz.devices('Olohuoneen lämpötila')
        local S2 = dz.devices('Makuuhuoneen lämpötila')
        local S3 = dz.devices('Danielin huoneen lämpötila')
        local temphumDevices = {S1,S2,S3}
        for i = 1,#temphumDevices do
            temphumDevice=temphumDevices[i]
            if not temphumDevice.isHTTPResponse then
                triggerJSON()
            elseif temphumDevice.ok then                                      -- statusCode == 2xx
                extremes = getExtremes(temphumDevice.json.result)
                notify(getTimeWindow(24))
                logWrite("Could not get (good) data from domoticz. Error (" .. (temphumDevice.statusCode or 999) .. ")"  ,dz.LOG_ERROR)
                logWrite(temphumDevice.data)
Posted: Thursday 08 October 2020 12:19
by waaren
Nautilus wrote: Thursday 08 October 2020 11:43 I was not able to transform this (yet) to the kind of script that would loop through an array of sensors and combine the max/min values to one message.
Do you want a max/min per device or one max and one min for the array of devices?
Please share your complete script as there are more versions "flying around"
Posted: Thursday 08 October 2020 13:55
by Nautilus
waaren wrote: Thursday 08 October 2020 12:19
I was thinking that I will configure the exact content once I get a hold of the loop logi. But max/min would be for each divice separately (or prehaps max for each, min for each etc. in one group). The functions were working ok and the script itself with one device. First I thought the probem was the execute = function(dz, item) as this resulted in double notifications from the devices (in random order, though) and then found one looping example where it was just execute = function(dz) - but this then resulted to the infinite loop and I was afraid to test anything after this...:) So hopefully it is just a light push that I'd need to the right direction. In any case, please find below the code I was testing.
-- getMaxTempHum
local httpResponses = "getMaxTempHum"
    on      =   {
                    timer           =   { "at 7:30"     },                       -- Your preferred time
                    httpResponses   =   { httpResponses }
    logging =   {
                    level           =   domoticz.LOG_ERROR,
                    marker          =   httpResponse
        -- ****************************** Your settings below this line ***************************************************
        --temphumDevice = dz.devices(14)    -- Replace with ID of Device you want to be notified on
        local S1 = dz.devices('AAA')
        local S2 = dz.devices('BBB')
        local S3 = dz.devices('CCC')
        -- ****************************** No changes required below this line *********************************************
        local extremes = {}
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local function triggerJSON()
            local  URLString   = dz.settings['Domoticz url'] .. "/json.htm?type=graph&sensor=temp&range=day&idx=" .. temphumDevice.id
            dz.openURL({    url = URLString,
                            method = "GET",
                            callback = httpResponses })
        local function convertTime(timeString)               -- based on incoming format yyyy-mm-dd hh:mm
            local year, month, day, hour, minute
            _,_, year, month, day, hour, minute = string.find(timeString, "(%d+)-(%d+)-(%d+) (%d+):(%d+)")
            fmtString = os.date("%A, %d %B %Y (%H:%M)",os.time({year=year, month=month, day=day, hour=hour, minute=minute })):gsub(" 0"," ")
            logWrite(fmtString)
            return fmtString                                 -- outgoing format: ddd d mmmm yyyy (hh:mm)
        local function showResult(str)
            textDevice.updateText(str)
            logWrite(str,dz.LOG_FORCE)
        local function getTimeWindow(hours)
            local to   = os.time(os.date("*t"))
            local from = os.date("%A, %d %B %Y (%H:%M)",to - hours * 3600)
            local to   = os.date("%A, %d %B %Y (%H:%M)",to)
            return to, from
        local function notify(from,now)
            local notificationString =  "\nKorkein lämpötila: " .. extremes.high.temperature .. " C (" .. extremes.high.tTime .. ")\n------------------------------\n"
            notificationString = notificationString .. "Alin läpötila: " .. extremes.low.temperature .. " C (" .. extremes.low.tTime .. ")\n------------------------------\n"
            notificationString = notificationString .. "Korkein kosteus: " .. extremes.high.humidity .. "% (" .. extremes.high.hTime .. ")\n------------------------------\n"
            notificationString = notificationString .. "Matalin kosteus:  " .. extremes.low.humidity .. "% (" .. extremes.low.hTime .. ")\n========================="
            logWrite("\nVaihtelu välillä " .. from .. " ja " .. now .. "\n" .. notificationString,dz.LOG_FORCE)
            dz.notify("Vaihtelu välillä " .. from .. " ja " .. now, notificationString, dz.PRIORITY_NORMAL, nil,nil, dz.NSS_TELEGRAM)
            extremes.low                = {}
            extremes.high               = {}
            extremes.low.temperature    = 10000
            extremes.low.humidity       = 100
            extremes.high.humidity      = 0
                if tonumber(rt[key].hu) > extremes.high.humidity then
                    logWrite("New max humidity found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].hu )
                    extremes.high.humidity = tonumber(rt[key].hu)
                    extremes.high.hTime = rt[key].d
                if tonumber(rt[key].hu) < extremes.low.humidity then
                    logWrite("New min humidity found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].hu )
                    extremes.low.humidity = tonumber(rt[key].hu)
                    extremes.low.hTime = rt[key].d
                    logWrite("New max temperature found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].te )
                    extremes.high.tTime = rt[key].d
                if tonumber(rt[key].te) < extremes.low.temperature then
                    logWrite("New min temperature found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].te )
                    extremes.low.temperature = tonumber(rt[key].te)
                    extremes.low.tTime = rt[key].d
            return extremes
        -- Main
                triggerJSON()
Posted: Thursday 08 October 2020 17:21
by waaren
Nautilus wrote: Thursday 08 October 2020 13:55 I was thinking that I will configure the exact content once I get a hold of the loop logi. But max/min would be for each divice separately (or prehaps max for each, min for each etc. in one group). The functions were working ok and the script itself with one device. F
Light push below ....
-- getMaxTempHum
local scriptVar = 'getMaxTempHum'
return
    on =
        timer =
            'at 7:30'  -- Your preferred time
        devices =
            'extremeTrigger', -- just for test can be ignored
        httpResponses =
            scriptVar .. '*',
    logging =
        marker = scriptVar,
    data =
        extremes =
            initial =
             'AAA',
             'BBB',
             'CCC',
        local extremes = {}
        local function triggerJSON(id, delay)
            local  URLString   = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=temp&range=day&idx=' .. id
            dz.openURL(
                url = URLString,
                callback = scriptVar .. '_' .. id
            }).afterSec(delay)
            _,_, year, month, day, hour, minute = string.find(timeString, '(%d+)-(%d+)-(%d+) (%d+):(%d+)')
            fmtString = os.date('%A, %d %B %Y (%H:%M)',os.time({year=year, month=month, day=day, hour=hour, minute=minute })):gsub(' 0',' ')
            dz.log(fmtString)
            dz.log(str,dz.LOG_FORCE)
            local to   = os.time(os.date('*t'))
            local from = os.date('%A, %d %B %Y (%H:%M)',to - hours * 3600)
            local to   = os.date('%A, %d %B %Y (%H:%M)',to)
            return to, from
        local function notify(now, from, extremes)
            for device, r in pairs(extremes) do
                dz.log(device)
                dz.log(r)
                notificationString =  '\n' ..   device ..' high temp: '     .. r.highTemperature .. ' C (' .. r.highTemperatureTime .. ')\n' ..
                                                device ..' low temp: '      .. r.lowTemperature .. ' C (' .. r.lowTemperatureTime .. ')\n'..
                                                device ..' high humidity: ' .. r.highHumidity .. '% (' .. r.highHumidityTime .. ')\n' ..
                                                device ..' low humidity: '  .. r.lowHumidity .. '% (' .. r.lowHumidityTime .. ')\n'
                dz.log(notificationString .. from .. ' until ' .. now,dz.LOG_FORCE)
                dz.notify(device .. ':' .. from .. ' until ' .. now, notificationString, dz.PRIORITY_NORMAL, nil,nil, dz.NSS_TELEGRAM)
        local function getExtremes(rt )
            local dvExtremes = {}  -- extremes per device
            dvExtremes.lowTemperature    = 10000
            dvExtremes.lowHumidity       = 100
            dvExtremes.highHumidity      = 0
            dvExtremes.highTemperature   = -256
                if tonumber(rt[key].hu) > dvExtremes.highHumidity then
                    -- dz.log('New max humidity found on ' .. convertTime(rt[key].d) .. ' ==>> ' .. rt[key].hu )
                    dvExtremes.highHumidity = tonumber(rt[key].hu)
                    dvExtremes.highHumidityTime = rt[key].d
                if tonumber(rt[key].hu) < dvExtremes.lowHumidity then
                    -- dz.log('New min humidity found on ' .. convertTime(rt[key].d) .. ' ==>> ' .. rt[key].hu )
                    dvExtremes.lowHumidity = tonumber(rt[key].hu)
                    dvExtremes.lowHumidityTime = rt[key].d
                if tonumber(rt[key].te) > dvExtremes.highTemperature then
                    -- dz.log('New max temperature found on ' .. convertTime(rt[key].d) .. ' ==>> ' .. rt[key].te )
                    dvExtremes.highTemperature = tonumber(rt[key].te)
                    dvExtremes.highTemperatureTime = rt[key].d
                if tonumber(rt[key].te) < dvExtremes.lowTemperature then
                    -- dz.log('New min temperature found on ' .. convertTime(rt[key].d) .. ' ==>> ' .. rt[key].te )
                    dvExtremes.lowTemperature = tonumber(rt[key].te)
                    dvExtremes.lowTemperatureTime = rt[key].d
            return dvExtremes
        -- Main
        if item.isTime or item.isDevice then
            local delay = 0
            for _, deviceName in ipairs(temphumDevices) do
                triggerJSON(dz.devices(deviceName).id, delay)
                delay = delay + 5
                dz.data.extremes.lastDevice = deviceName
        elseif item.isJSON and #item.json.result > 10 then         -- statusCode = OK and JSON contains enough records
            local extremes = dz.data.extremes -- get table from persistent data
            local deviceName = dz.devices(tonumber( ( item.trigger:gsub(scriptVar .. '_','' )) )).name
            dz.log('Handling device  ' .. deviceName ,dz.LOG_DEBUG )
            extremes[deviceName] = getExtremes(item.json.result) -- Merge device extremes in total extremes
            if deviceName == dz.data.extremes.lastDevice then -- all devices done
                dz.log('All devices are done. Extremes can be found in table extremes and in persistent data' ,dz.LOG_DEBUG )
                extremes.lastDevice = nil -- We do not need this anymore
                local from, now = getTimeWindow(24)
                -- dz.utils.dumpTable(extremes) -- for debugging
                notify(from, now, extremes)
            dz.data.extremes = extremes -- store Table in persistent data
            dz.log('Could not get (good) data from domoticz. Error (' .. (temphumDevice.statusCode or 999) .. ')'  ,dz.LOG_ERROR)
            dz.log(temphumDevice.data,dz.LOG_DEBUG)
Posted: Friday 09 October 2020 15:06
by Nautilus
Thanks, this is great! Unfortunately I may need a sligthly harder push :)
First I was not getting anything else in the log than start, "nil" and stop. I then changed some value from device to devices, cannot remember anymore which. At this point I started getting errors in the log and noticed that the first if clause in main is not true at any point. I then changed it to what I originally had, i.e. "if not item.isHTTPResponse then". This seemed to take it a step further so script is running until the notify section. But there I get nil value errors from all the variables that should contain the high/low values and times, e.g:
Error: dzVents: Error: (3.0.14) getMaxTempHum: ...e/pi/domoticz/scripts/dzVents/generated_scripts/Test.lua:91: attempt to concatenate a nil value (field 'highHumidityTime')
I tried a few things but I'm afraid I keep adding new error on top of old ones if I keep going :) After enabling debugging I can see in the log:
2020-10-09 15:56:00.398 Status: dzVents: Debug: getMaxTempHum: Processing device-adapter for Olohuoneen lämpötila: Temperature+humidity device adapter
2020-10-09 15:56:00.398 Status: dzVents: Debug: getMaxTempHum: OpenURL: url = http://127.0.0.1:30/json.htm?type=graph ... day&idx=14
2020-10-09 15:56:00.398 Status: dzVents: Debug: getMaxTempHum: OpenURL: method = GET
2020-10-09 15:56:00.398 Status: dzVents: Debug: getMaxTempHum: OpenURL: post data = nil
2020-10-09 15:56:00.398 Status: dzVents: Debug: getMaxTempHum: OpenURL: headers = nil
2020-10-09 15:56:00.398 Status: dzVents: Debug: getMaxTempHum: OpenURL: callback = getMaxTempHum_14
2020-10-09 15:56:00.399 Status: dzVents: Debug: getMaxTempHum: Processing device-adapter for Makuuhuoneen lämpötila: Temperature+humidity device adapter
2020-10-09 15:56:00.399 Status: dzVents: Debug: getMaxTempHum: OpenURL: url = http://127.0.0.1:30/json.htm?type=graph ... day&idx=66
2020-10-09 15:56:00.399 Status: dzVents: Debug: getMaxTempHum: OpenURL: method = GET
2020-10-09 15:56:00.399 Status: dzVents: Debug: getMaxTempHum: OpenURL: post data = nil
2020-10-09 15:56:00.399 Status: dzVents: Debug: getMaxTempHum: OpenURL: headers = nil
2020-10-09 15:56:00.399 Status: dzVents: Debug: getMaxTempHum: OpenURL: callback = getMaxTempHum_66
2020-10-09 15:56:00.399 Status: dzVents: Debug: getMaxTempHum: Processing device-adapter for Danielin huoneen lämpötila: Temperature+humidity device adapter
2020-10-09 15:56:00.400 Status: dzVents: Debug: getMaxTempHum: OpenURL: url = http://127.0.0.1:30/json.htm?type=graph ... day&idx=75
2020-10-09 15:56:00.400 Status: dzVents: Debug: getMaxTempHum: OpenURL: method = GET
2020-10-09 15:56:00.400 Status: dzVents: Debug: getMaxTempHum: OpenURL: post data = nil
2020-10-09 15:56:00.400 Status: dzVents: Debug: getMaxTempHum: OpenURL: headers = nil
2020-10-09 15:56:00.400 Status: dzVents: Debug: getMaxTempHum: OpenURL: callback = getMaxTempHum_75
2020-10-09 15:56:00.400 Status: dzVents: Info: getMaxTempHum: ------ Finished Test
2020-10-09 15:56:00.401 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-09 15:56:00.545 Status: dzVents: Info: Handling httpResponse-events for: "getMaxTempHum_14"
2020-10-09 15:56:00.545 Status: dzVents: Info: getMaxTempHum: ------ Start internal script: Test: HTTPResponse: "getMaxTempHum_14"
2020-10-09 15:56:00.633 Status: dzVents: Debug: getMaxTempHum: Processing device-adapter for Olohuoneen lämpötila: Temperature+humidity device adapter
2020-10-09 15:56:00.633 Status: dzVents: Debug: getMaxTempHum: Handling device Olohuoneen lämpötila
2020-10-09 15:56:00.633 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (15:00)
2020-10-09 15:56:00.633 Status: dzVents: Info: getMaxTempHum: New max humidity found on Sunday, 4 October 2020 (15:00) ==>> 48
2020-10-09 15:56:00.633 Status: dzVents: Info: getMaxTempHum: New min humidity found on Sunday, 4 October 2020 (15:00) ==>> 48
2020-10-09 15:56:00.633 Status: dzVents: Info: getMaxTempHum: New max temperature found on Sunday, 4 October 2020 (15:00) ==>> 21.6
2020-10-09 15:56:00.633 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (15:00) ==>> 21.6
2020-10-09 15:56:00.633 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (16:00)
2020-10-09 15:56:00.633 Status: dzVents: Info: getMaxTempHum: New max humidity found on Sunday, 4 October 2020 (16:00) ==>> 49
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (16:00)
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (16:00) ==>> 21.4
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (18:00)
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (18:00) ==>> 21.1
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (19:00)
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (19:00) ==>> 21.0
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (20:00)
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: New max humidity found on Sunday, 4 October 2020 (20:00) ==>> 50
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (20:00) ==>> 20.9
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (21:00)
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (21:00) ==>> 20.8
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (23:00)
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (23:00) ==>> 20.7
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (02:00)
2020-10-09 15:56:00.634 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (02:00) ==>> 20.6
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (13:00)
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (13:00) ==>> 22.1
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (14:00)
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (14:00) ==>> 47
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 22.6
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (14:00) ==>> 46
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 23.2
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (14:00) ==>> 45
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 23.3
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 23.7
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (14:00) ==>> 44
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 24.2
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (15:00)
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (15:00) ==>> 43
2020-10-09 15:56:00.635 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (15:00) ==>> 24.7
2020-10-09 15:56:00.636 Status: dzVents: Info: getMaxTempHum: Tuesday, 6 October 2020 (18:00)
2020-10-09 15:56:00.636 Status: dzVents: Info: getMaxTempHum: New max humidity found on Tuesday, 6 October 2020 (18:00) ==>> 51
2020-10-09 15:56:00.637 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (09:00)
2020-10-09 15:56:00.637 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (09:00) ==>> 20.5
2020-10-09 15:56:00.638 Status: dzVents: Info: getMaxTempHum: ------ Finished Test
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: New max temperature found on Sunday, 4 October 2020 (15:00) ==>> 19.9
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (15:00)
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (15:00) ==>> 19.9
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (16:00)
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: New max temperature found on Sunday, 4 October 2020 (16:00) ==>> 20.0
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (22:00)
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (22:00) ==>> 19.8
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (03:00)
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (03:00) ==>> 19.7
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (04:00)
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (04:00) ==>> 19.6
2020-10-09 15:56:05.682 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (14:00)
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 20.1
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (14:00)
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: New max humidity found on Monday, 5 October 2020 (14:00) ==>> 55
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (15:00)
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (15:00) ==>> 20.2
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (16:00)
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (16:00) ==>> 20.3
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (17:00)
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (17:00) ==>> 20.4
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (18:00)
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (18:00) ==>> 20.5
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (20:00)
2020-10-09 15:56:05.683 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (20:00) ==>> 20.6
2020-10-09 15:56:05.685 Status: dzVents: Info: getMaxTempHum: ------ Finished Test
2020-10-09 15:56:10.570 Status: dzVents: Info: Handling httpResponse-events for: "getMaxTempHum_75"
2020-10-09 15:56:10.570 Status: dzVents: Info: getMaxTempHum: ------ Start internal script: Test: HTTPResponse: "getMaxTempHum_75"
2020-10-09 15:56:10.656 Status: dzVents: Debug: getMaxTempHum: Processing device-adapter for Danielin huoneen lämpötila: Temperature+humidity device adapter
2020-10-09 15:56:10.656 Status: dzVents: Debug: getMaxTempHum: Handling device Danielin huoneen lämpötila
2020-10-09 15:56:10.656 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (15:00)
2020-10-09 15:56:10.656 Status: dzVents: Info: getMaxTempHum: New max humidity found on Sunday, 4 October 2020 (15:00) ==>> 52
2020-10-09 15:56:10.656 Status: dzVents: Info: getMaxTempHum: New min humidity found on Sunday, 4 October 2020 (15:00) ==>> 52
2020-10-09 15:56:10.656 Status: dzVents: Info: getMaxTempHum: New max temperature found on Sunday, 4 October 2020 (15:00) ==>> 20.5
2020-10-09 15:56:10.656 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (15:00) ==>> 20.5
2020-10-09 15:56:10.656 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (16:00)
2020-10-09 15:56:10.656 Status: dzVents: Info: getMaxTempHum: New max temperature found on Sunday, 4 October 2020 (16:00) ==>> 20.6
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (20:00)
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (20:00) ==>> 20.4
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: Sunday, 4 October 2020 (22:00)
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: New max humidity found on Sunday, 4 October 2020 (22:00) ==>> 53
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: New min temperature found on Sunday, 4 October 2020 (22:00) ==>> 20.3
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (00:00)
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (00:00) ==>> 20.2
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (00:00) ==>> 20.1
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (04:00)
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (04:00) ==>> 20.0
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (15:00)
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (15:00) ==>> 20.8
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (15:00) ==>> 21.0
2020-10-09 15:56:10.657 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (16:00)
2020-10-09 15:56:10.658 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (16:00) ==>> 21.1
2020-10-09 15:56:10.658 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (17:00)
2020-10-09 15:56:10.658 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (17:00) ==>> 21.2
2020-10-09 15:56:10.658 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (17:00) ==>> 21.4
2020-10-09 15:56:10.658 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (18:00)
2020-10-09 15:56:10.658 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (18:00) ==>> 21.5
2020-10-09 15:56:10.658 Status: dzVents: Info: getMaxTempHum: Wednesday, 7 October 2020 (08:00)
2020-10-09 15:56:10.658 Status: dzVents: Info: getMaxTempHum: New max humidity found on Wednesday, 7 October 2020 (08:00) ==>> 54
2020-10-09 15:56:10.659 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (08:00)
2020-10-09 15:56:10.659 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (08:00) ==>> 19.9
2020-10-09 15:56:10.659 Status: dzVents: Debug: getMaxTempHum: All devices are done. Extremes can be found in table extremes and in persistent data
2020-10-09 15:56:10.659 Status: dzVents: > 1:
2020-10-09 15:56:10.659 Status: dzVents: > Makuuhuoneen lämpötila:
2020-10-09 15:56:10.659 Status: dzVents: > lowTemperatureTime: 2020-10-05 04:35
2020-10-09 15:56:10.659 Status: dzVents: > highTemperatureTime: 2020-10-05 20:15
2020-10-09 15:56:10.659 Status: dzVents: > lowHumidity: 54
2020-10-09 15:56:10.659 Status: dzVents: > highHumidity: 55
2020-10-09 15:56:10.659 Status: dzVents: > highTemperature: 20.6
2020-10-09 15:56:10.659 Status: dzVents: > lowHumidityTime: 2020-10-04 15:55
2020-10-09 15:56:10.659 Status: dzVents: > highHumidityTime: 2020-10-05 14:50
2020-10-09 15:56:10.659 Status: dzVents: > lowTemperature: 19.6
2020-10-09 15:56:10.659 Status: dzVents: > Olohuoneen lämpötila:
2020-10-09 15:56:10.660 Status: dzVents: > lowTemperatureTime: 2020-10-09 09:35
2020-10-09 15:56:10.660 Status: dzVents: > highTemperatureTime: 2020-10-05 15:35
2020-10-09 15:56:10.660 Status: dzVents: > lowHumidity: 43
2020-10-09 15:56:10.660 Status: dzVents: > highHumidity: 51
2020-10-09 15:56:10.660 Status: dzVents: > highTemperature: 24.7
2020-10-09 15:56:10.660 Status: dzVents: > lowHumidityTime: 2020-10-05 15:35
2020-10-09 15:56:10.660 Status: dzVents: > highHumidityTime: 2020-10-06 18:55
2020-10-09 15:56:10.660 Status: dzVents: > lowTemperature: 20.5
2020-10-09 15:56:10.660 Status: dzVents: > Danielin huoneen lämpötila:
2020-10-09 15:56:10.660 Status: dzVents: > lowTemperatureTime: 2020-10-09 08:50
2020-10-09 15:56:10.660 Status: dzVents: > lowTemperature: 19.9
2020-10-09 15:56:10.660 Status: dzVents: > lowHumidity: 52
2020-10-09 15:56:10.660 Status: dzVents: > highHumidity: 54
2020-10-09 15:56:10.660 Status: dzVents: > highTemperature: 21.5
2020-10-09 15:56:10.660 Status: dzVents: > lowHumidityTime: 2020-10-04 15:55
2020-10-09 15:56:10.660 Status: dzVents: > highTemperatureTime: 2020-10-05 18:45
2020-10-09 15:56:10.660 Status: dzVents: > highHumidityTime: 2020-10-07 08:20
2020-10-09 15:56:10.660 Status: dzVents: Info: getMaxTempHum: 1
2020-10-09 15:56:10.660 Status: dzVents: Info: getMaxTempHum: {}
2020-10-09 15:56:10.660 Status: dzVents: Info: getMaxTempHum: ------ Finished Test
2020-10-09 15:56:10.660 Error: dzVents: Error: (3.0.14) getMaxTempHum: An error occurred when calling event handler Test
2020-10-09 15:56:10.660 Error: dzVents: Error: (3.0.14) getMaxTempHum: ...e/pi/domoticz/scripts/dzVents/generated_scripts/Test.lua:91: attempt to concatenate a nil value (field 'lowHumidity')
2020-10-09 15:56:56.093 Proxy: Error, reconnecting (Connection timed out)
It must be some mistake I have made along the way or some feature of dzVents I have not enabled?
Posted: Friday 09 October 2020 16:08
by waaren
Nautilus wrote: Friday 09 October 2020 15:06 I may need a sligthly harder push :)
This 1 should not be there and when I (successfully) test the script I don't see it.
Only thing I can think of now is that there is still some old data left in the persistent data file.
If you can remove the persistent data file from <domoticz dir>/scripts/dzVents/data/ and change
to
            dz.data.extremes = {} -- this will remove any data from this persistent table
and try again with only names of temp+hum sensors in temphumDevices.
Posted: Saturday 10 October 2020 0:19
by Nautilus
Ok, if I change it from "if not item.isHTTPResponse then" back to "if item.isTime or item.isDevice then" and add dz.data.extremes = {} I go back to getting the same error as initially got:
2020-10-10 01:14:47.928 Status: EventSystem: reset all events...
2020-10-10 01:14:47.929 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Test.lua
2020-10-10 01:15:00.262 Status: dzVents: Info: getMaxTempHum: ------ Start internal script: Test:, trigger: "at 01:15"
2020-10-10 01:15:00.263 Status: dzVents: Debug: getMaxTempHum: nil
2020-10-10 01:15:00.264 Status: dzVents: Info: getMaxTempHum: ------ Finished Test
2020-10-10 01:15:00.263 Error: dzVents: Error: (3.0.14) getMaxTempHum: Could not get (good) data from domoticz. Error (999)
So the first if clause (item.isTime or item.isDevice) does not seem to be true.
Posted: Saturday 10 October 2020 0:31
by Nautilus
I then went back to "if not item.isHTTPResponse then" and included dz.data.extremes = {}. This actually worked and I got the notification for each three devices on a separate message. Btw, I also checked the data directory, but I didn't have anyting there except:
-rw-r----- 1 root root 1140 Oct 10 01:21 __data_Test.lua
-rw-r--r-- 1 pi pi 278 Jul 14 16:12 README.md
edit: sorry, __data_Test.lua --> this was of course the file as I named the script "Test" :)
With the succesful run the log says:
2020-10-10 01:21:00.333 Status: dzVents: Info: getMaxTempHum: ------ Start internal script: Test:, trigger: "at 01:21"
2020-10-10 01:21:00.350 Status: dzVents: Debug: getMaxTempHum: Processing device-adapter for Olohuoneen lämpötila: Temperature+humidity device adapter
2020-10-10 01:21:00.350 Status: dzVents: Debug: getMaxTempHum: OpenURL: url = http://127.0.0.1:30/json.htm?type=graph ... day&idx=14
2020-10-10 01:21:00.350 Status: dzVents: Debug: getMaxTempHum: OpenURL: method = GET
2020-10-10 01:21:00.350 Status: dzVents: Debug: getMaxTempHum: OpenURL: post data = nil
2020-10-10 01:21:00.350 Status: dzVents: Debug: getMaxTempHum: OpenURL: headers = nil
2020-10-10 01:21:00.350 Status: dzVents: Debug: getMaxTempHum: OpenURL: callback = getMaxTempHum_14
2020-10-10 01:21:00.351 Status: dzVents: Debug: getMaxTempHum: Processing device-adapter for Makuuhuoneen lämpötila: Temperature+humidity device adapter
2020-10-10 01:21:00.351 Status: dzVents: Debug: getMaxTempHum: OpenURL: url = http://127.0.0.1:30/json.htm?type=graph ... day&idx=66
2020-10-10 01:21:00.351 Status: dzVents: Debug: getMaxTempHum: OpenURL: method = GET
2020-10-10 01:21:00.351 Status: dzVents: Debug: getMaxTempHum: OpenURL: post data = nil
2020-10-10 01:21:00.351 Status: dzVents: Debug: getMaxTempHum: OpenURL: headers = nil
2020-10-10 01:21:00.351 Status: dzVents: Debug: getMaxTempHum: OpenURL: callback = getMaxTempHum_66
2020-10-10 01:21:00.352 Status: dzVents: Debug: getMaxTempHum: Processing device-adapter for Danielin huoneen lämpötila: Temperature+humidity device adapter
2020-10-10 01:21:00.352 Status: dzVents: Debug: getMaxTempHum: OpenURL: url = http://127.0.0.1:30/json.htm?type=graph ... day&idx=75
2020-10-10 01:21:00.352 Status: dzVents: Debug: getMaxTempHum: OpenURL: method = GET
2020-10-10 01:21:00.352 Status: dzVents: Debug: getMaxTempHum: OpenURL: post data = nil
2020-10-10 01:21:00.352 Status: dzVents: Debug: getMaxTempHum: OpenURL: headers = nil
2020-10-10 01:21:00.352 Status: dzVents: Debug: getMaxTempHum: OpenURL: callback = getMaxTempHum_75
2020-10-10 01:21:00.353 Status: dzVents: Info: getMaxTempHum: ------ Finished Test
2020-10-10 01:21:00.354 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-10 01:21:00.510 Status: dzVents: Info: Handling httpResponse-events for: "getMaxTempHum_14"
2020-10-10 01:21:00.510 Status: dzVents: Info: getMaxTempHum: ------ Start internal script: Test: HTTPResponse: "getMaxTempHum_14"
2020-10-10 01:21:00.607 Status: dzVents: Debug: getMaxTempHum: Processing device-adapter for Olohuoneen lämpötila: Temperature+humidity device adapter
2020-10-10 01:21:00.607 Status: dzVents: Debug: getMaxTempHum: Handling device Olohuoneen lämpötila
2020-10-10 01:21:00.607 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (01:00)
2020-10-10 01:21:00.607 Status: dzVents: Info: getMaxTempHum: New max humidity found on Monday, 5 October 2020 (01:00) ==>> 50
2020-10-10 01:21:00.607 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (01:00) ==>> 50
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (01:00) ==>> 20.7
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (01:00)
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (01:00) ==>> 20.7
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (02:00)
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (02:00) ==>> 20.6
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (10:00)
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (10:00) ==>> 20.8
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (11:00)
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (11:00) ==>> 20.9
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (12:00)
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (12:00) ==>> 21.1
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (13:00)
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (13:00) ==>> 49
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (13:00) ==>> 21.3
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (13:00) ==>> 21.6
2020-10-10 01:21:00.608 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (13:00) ==>> 48
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (13:00) ==>> 22.1
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (14:00)
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (14:00) ==>> 47
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 22.6
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (14:00) ==>> 46
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 23.2
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (14:00) ==>> 45
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 23.3
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 23.7
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (14:00) ==>> 44
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 24.2
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (15:00)
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (15:00) ==>> 43
2020-10-10 01:21:00.609 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (15:00) ==>> 24.7
2020-10-10 01:21:00.610 Status: dzVents: Info: getMaxTempHum: Tuesday, 6 October 2020 (18:00)
2020-10-10 01:21:00.610 Status: dzVents: Info: getMaxTempHum: New max humidity found on Tuesday, 6 October 2020 (18:00) ==>> 51
2020-10-10 01:21:00.611 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (09:00)
2020-10-10 01:21:00.611 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (09:00) ==>> 20.5
2020-10-10 01:21:00.611 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (19:00)
2020-10-10 01:21:00.611 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (19:00) ==>> 20.4
2020-10-10 01:21:00.611 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (21:00)
2020-10-10 01:21:00.611 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (21:00) ==>> 20.3
2020-10-10 01:21:00.611 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (22:00)
2020-10-10 01:21:00.611 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (22:00) ==>> 20.2
2020-10-10 01:21:00.611 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (22:00) ==>> 20.1
2020-10-10 01:21:00.611 Status: dzVents: Info: getMaxTempHum: Saturday, 10 October 2020 (00:00)
2020-10-10 01:21:00.611 Status: dzVents: Info: getMaxTempHum: New min temperature found on Saturday, 10 October 2020 (00:00) ==>> 20.0
2020-10-10 01:21:00.612 Status: dzVents: Info: getMaxTempHum: ------ Finished Test
2020-10-10 01:21:05.505 Status: dzVents: Info: Handling httpResponse-events for: "getMaxTempHum_66"
2020-10-10 01:21:05.505 Status: dzVents: Info: getMaxTempHum: ------ Start internal script: Test: HTTPResponse: "getMaxTempHum_66"
2020-10-10 01:21:05.591 Status: dzVents: Debug: getMaxTempHum: Processing device-adapter for Makuuhuoneen lämpötila: Temperature+humidity device adapter
2020-10-10 01:21:05.591 Status: dzVents: Debug: getMaxTempHum: Handling device Makuuhuoneen lämpötila
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (01:00)
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: New max humidity found on Monday, 5 October 2020 (01:00) ==>> 54
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (01:00) ==>> 54
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (01:00) ==>> 19.8
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (01:00) ==>> 19.8
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (03:00)
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (03:00) ==>> 19.7
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (04:00)
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (04:00) ==>> 19.6
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (12:00)
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (12:00) ==>> 19.9
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (13:00)
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (13:00) ==>> 20.0
2020-10-10 01:21:05.592 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (14:00)
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 20.1
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (14:00)
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: New max humidity found on Monday, 5 October 2020 (14:00) ==>> 55
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (15:00)
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (15:00) ==>> 20.2
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (16:00)
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (16:00) ==>> 20.3
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (17:00)
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (17:00) ==>> 20.4
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (18:00)
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (18:00) ==>> 20.5
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (20:00)
2020-10-10 01:21:05.593 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (20:00) ==>> 20.6
2020-10-10 01:21:05.595 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (22:00)
2020-10-10 01:21:05.595 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (22:00) ==>> 19.5
2020-10-10 01:21:05.595 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (22:00) ==>> 19.4
2020-10-10 01:21:05.595 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (23:00)
2020-10-10 01:21:05.595 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (23:00) ==>> 19.3
2020-10-10 01:21:05.595 Status: dzVents: Info: getMaxTempHum: Saturday, 10 October 2020 (00:00)
2020-10-10 01:21:05.595 Status: dzVents: Info: getMaxTempHum: New min humidity found on Saturday, 10 October 2020 (00:00) ==>> 53
2020-10-10 01:21:05.595 Status: dzVents: Info: getMaxTempHum: New min temperature found on Saturday, 10 October 2020 (00:00) ==>> 19.2
2020-10-10 01:21:05.596 Status: dzVents: Info: getMaxTempHum: ------ Finished Test
2020-10-10 01:21:10.992 Notification sent (telegram) => Success
2020-10-10 01:21:10.531 Status: dzVents: Info: Handling httpResponse-events for: "getMaxTempHum_75"
2020-10-10 01:21:10.531 Status: dzVents: Info: getMaxTempHum: ------ Start internal script: Test: HTTPResponse: "getMaxTempHum_75"
2020-10-10 01:21:10.618 Status: dzVents: Debug: getMaxTempHum: Processing device-adapter for Danielin huoneen lämpötila: Temperature+humidity device adapter
2020-10-10 01:21:10.618 Status: dzVents: Debug: getMaxTempHum: Handling device Danielin huoneen lämpötila
2020-10-10 01:21:10.618 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (01:00)
2020-10-10 01:21:10.618 Status: dzVents: Info: getMaxTempHum: New max humidity found on Monday, 5 October 2020 (01:00) ==>> 53
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (01:00)
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: New min humidity found on Monday, 5 October 2020 (01:00) ==>> 53
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (01:00) ==>> 20.2
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (01:00) ==>> 20.2
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (01:00) ==>> 20.1
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (04:00)
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: New min temperature found on Monday, 5 October 2020 (04:00) ==>> 20.0
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (11:00)
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (11:00) ==>> 20.3
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (14:00)
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 20.4
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (14:00) ==>> 20.6
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (15:00)
2020-10-10 01:21:10.619 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (15:00) ==>> 20.8
2020-10-10 01:21:10.620 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (15:00) ==>> 21.0
2020-10-10 01:21:10.620 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (16:00)
2020-10-10 01:21:10.620 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (16:00) ==>> 21.1
2020-10-10 01:21:10.620 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (17:00)
2020-10-10 01:21:10.620 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (17:00) ==>> 21.2
2020-10-10 01:21:10.620 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (17:00) ==>> 21.4
2020-10-10 01:21:10.620 Status: dzVents: Info: getMaxTempHum: Monday, 5 October 2020 (18:00)
2020-10-10 01:21:10.620 Status: dzVents: Info: getMaxTempHum: New max temperature found on Monday, 5 October 2020 (18:00) ==>> 21.5
2020-10-10 01:21:10.620 Status: dzVents: Info: getMaxTempHum: Wednesday, 7 October 2020 (08:00)
2020-10-10 01:21:10.620 Status: dzVents: Info: getMaxTempHum: New max humidity found on Wednesday, 7 October 2020 (08:00) ==>> 54
2020-10-10 01:21:10.621 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (08:00)
2020-10-10 01:21:10.621 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (08:00) ==>> 19.9
2020-10-10 01:21:10.621 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (20:00)
2020-10-10 01:21:10.621 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (20:00) ==>> 19.8
2020-10-10 01:21:10.622 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (20:00)
2020-10-10 01:21:10.622 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (20:00) ==>> 19.6
2020-10-10 01:21:10.622 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (21:00)
2020-10-10 01:21:10.622 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (21:00) ==>> 19.5
2020-10-10 01:21:10.622 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (22:00)
2020-10-10 01:21:10.622 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (22:00) ==>> 19.3
2020-10-10 01:21:10.622 Status: dzVents: Info: getMaxTempHum: Friday, 9 October 2020 (23:00)
2020-10-10 01:21:10.622 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (23:00) ==>> 19.2
2020-10-10 01:21:10.622 Status: dzVents: Info: getMaxTempHum: New min temperature found on Friday, 9 October 2020 (23:00) ==>> 19.1
2020-10-10 01:21:10.622 Status: dzVents: Info: getMaxTempHum: Saturday, 10 October 2020 (00:00)
2020-10-10 01:21:10.622 Status: dzVents: Info: getMaxTempHum: New min temperature found on Saturday, 10 October 2020 (00:00) ==>> 19.0
2020-10-10 01:21:10.622 Status: dzVents: Debug: getMaxTempHum: All devices are done. Extremes can be found in table extremes and in persistent data
2020-10-10 01:21:10.622 Status: dzVents: > Makuuhuoneen lämpötila:
2020-10-10 01:21:10.622 Status: dzVents: > lowTemperatureTime: 2020-10-10 00:45
2020-10-10 01:21:10.622 Status: dzVents: > highTemperature: 20.6
2020-10-10 01:21:10.622 Status: dzVents: > highHumidity: 55
2020-10-10 01:21:10.622 Status: dzVents: > highHumidityTime: 2020-10-05 14:50
2020-10-10 01:21:10.622 Status: dzVents: > lowTemperature: 19.2
2020-10-10 01:21:10.622 Status: dzVents: > lowHumidityTime: 2020-10-10 00:45
2020-10-10 01:21:10.622 Status: dzVents: > lowHumidity: 53
2020-10-10 01:21:10.622 Status: dzVents: > highTemperatureTime: 2020-10-05 20:15
2020-10-10 01:21:10.622 Status: dzVents: > Danielin huoneen lämpötila:
2020-10-10 01:21:10.622 Status: dzVents: > lowTemperatureTime: 2020-10-10 00:30
2020-10-10 01:21:10.622 Status: dzVents: > highHumidityTime: 2020-10-07 08:20
2020-10-10 01:21:10.622 Status: dzVents: > highHumidity: 54
2020-10-10 01:21:10.622 Status: dzVents: > highTemperature: 21.5
2020-10-10 01:21:10.622 Status: dzVents: > lowTemperature: 19.0
2020-10-10 01:21:10.622 Status: dzVents: > lowHumidityTime: 2020-10-05 01:20
2020-10-10 01:21:10.622 Status: dzVents: > highTemperatureTime: 2020-10-05 18:45
2020-10-10 01:21:10.622 Status: dzVents: > Olohuoneen lämpötila:
2020-10-10 01:21:10.622 Status: dzVents: > lowTemperatureTime: 2020-10-10 00:10
2020-10-10 01:21:10.622 Status: dzVents: > highTemperature: 24.7
2020-10-10 01:21:10.622 Status: dzVents: > highHumidity: 51
2020-10-10 01:21:10.623 Status: dzVents: > highHumidityTime: 2020-10-06 18:55
2020-10-10 01:21:10.623 Status: dzVents: > lowTemperature: 20.0
2020-10-10 01:21:10.623 Status: dzVents: > lowHumidityTime: 2020-10-05 15:35
2020-10-10 01:21:10.623 Status: dzVents: > lowHumidity: 43
2020-10-10 01:21:10.623 Status: dzVents: > highTemperatureTime: 2020-10-05 15:35
2020-10-10 01:21:10.623 Status: dzVents: Info: getMaxTempHum: Makuuhuoneen lämpötila
2020-10-10 01:21:10.623 Status: dzVents: Info: getMaxTempHum: {["lowTemperatureTime"]="2020-10-10 00:45", ["highTemperature"]=20.6, ["highHumidity"]=55, ["highHumidityTime"]="2020-10-05 14:50", ["lowTemperature"]=19.2, ["lowHumidityTime"]="2020-10-10 00:45", ["lowHumidity"]=53, ["highTemperatureTime"]="2020-10-05 20:15"}
2020-10-10 01:21:10.623 Status: dzVents: !Info: getMaxTempHum:
2020-10-10 01:21:10.623 Makuuhuoneen lämpötila high temp: 20.6 C
2020-10-10 01:21:10.623 Makuuhuoneen lämpötila low temp: 19.2 C
2020-10-10 01:21:10.623 Makuuhuoneen lämpötila high humidity: 55%
2020-10-10 01:21:10.623 Makuuhuoneen lämpötila low humidity: 53%
2020-10-10 01:21:10.623 Friday, 09 October 2020 (01:21) until Saturday, 10 October 2020 (01:21)
2020-10-10 01:21:10.623 Status: dzVents: Info: getMaxTempHum: Danielin huoneen lämpötila
2020-10-10 01:21:10.623 Status: dzVents: Info: getMaxTempHum: {["lowTemperatureTime"]="2020-10-10 00:30", ["highHumidityTime"]="2020-10-07 08:20", ["highHumidity"]=54, ["highTemperature"]=21.5, ["lowTemperature"]=19.0, ["lowHumidity"]=53, ["lowHumidityTime"]="2020-10-05 01:20", ["highTemperatureTime"]="2020-10-05 18:45"}
2020-10-10 01:21:10.623 Danielin huoneen lämpötila high temp: 21.5 C
2020-10-10 01:21:10.623 Danielin huoneen lämpötila low temp: 19.0 C
2020-10-10 01:21:10.623 Danielin huoneen lämpötila high humidity: 54%
2020-10-10 01:21:10.623 Danielin huoneen lämpötila low humidity: 53%
2020-10-10 01:21:10.623 Status: dzVents: Info: getMaxTempHum: Olohuoneen lämpötila
2020-10-10 01:21:10.623 Status: dzVents: Info: getMaxTempHum: {["lowTemperatureTime"]="2020-10-10 00:10", ["highTemperature"]=24.7, ["highHumidity"]=51, ["highHumidityTime"]="2020-10-06 18:55", ["lowTemperature"]=20.0, ["lowHumidityTime"]="2020-10-05 15:35", ["lowHumidity"]=43, ["highTemperatureTime"]="2020-10-05 15:35"}
2020-10-10 01:21:10.623 Olohuoneen lämpötila high temp: 24.7 C
2020-10-10 01:21:10.623 Olohuoneen lämpötila low temp: 20.0 C
2020-10-10 01:21:10.623 Olohuoneen lämpötila high humidity: 51%
2020-10-10 01:21:10.623 Olohuoneen lämpötila low humidity: 43%
2020-10-10 01:21:10.624 Status: dzVents: Info: getMaxTempHum: ------ Finished Test
2020-10-10 01:21:10.624 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-10 01:21:10.640 Status: Notification: Makuuhuoneen lämpötila:Friday, 09 October 2020 (01:21) until Saturday, 10 October 2020 (01:21)
2020-10-10 01:21:10.640 Status: Notification: Danielin huoneen lämpötila:Friday, 09 October 2020 (01:21) until Saturday, 10 October 2020 (01:21)
2020-10-10 01:21:10.640 Status: Notification: Olohuoneen lämpötila:Friday, 09 October 2020 (01:21) until Saturday, 10 October 2020 (01:21)
It came to my mind that does it matter which type I select for the dzVent script in the event editor? For Lua scripts I know it matters (you should select device for those that are triggered from device change etc.), but for dzVents I'm not sure. From where I picked up the script originally it said to select the Http Request but should it rather be timer? Or does this matter for dzVents?
Posted: Saturday 10 October 2020 0:51
by Nautilus
I tested with type timer, but it did not matter. In any case, in this format:
-- getMaxTempHum
return
    on =
        timer =
            'at 01:53'  -- Your preferred time
        devices =
        httpResponses =
            scriptVar .. '*',
    logging =
        level = domoticz.LOG_INFO,
        marker = scriptVar,
    data =
        extremes =
            initial =
        -- ****************************** Settings below this line ***************************************************
        'Olohuoneen lämpötila',
        'Makuuhuoneen lämpötila',
        'Danielin huoneen lämpötila',
        local extremes = {}
            dz.openURL(
                url = URLString,
            }).afterSec(delay)
            dz.log(fmtString)
            return to, from
                dz.log(device)
                dz.log(r)
            return dvExtremes
        -- Main
            local delay = 0
                delay = delay + 5
...the script provides the output I was looking for. So thanks a lot! :) Of course, if we can find an exlanation for this inconsistency between my system and yours I'd appreciate it very much as it would help me to understand the logic. Also, Iäd be interested to understand for which purpose are these in the beginning of the scirpt:
        devices =
        httpResponses =
            scriptVar .. '*',
edit: One challenge remains I noticed. I'd like the range to be 24 hours, but the json seems to return the whole short log which is defined for 5 days in my setup. So extremes are picked from the course of 5 days. I guess I need a condition for looping the array, somethin like:
                if rt[key].d > "time now - 24h"
But I did not succeed in making this work. With Lua I've used timedifference function in this type of situations. Would that be preferred here with dzVents as well?
edit2: One more thing :D Now the Telegram messages come in seemingly random order. I guess I would need to tell dzVents to wait until one message is sent and then move to next so that it would respect the order in which I've listed the devices? Any pointers to this?
Posted: Saturday 10 October 2020 8:00
by waaren
Nautilus wrote: Saturday 10 October 2020 0:51 ...the script provides the output I was looking for.
Of course, if we can find an explanation for this inconsistency between my system and yours I'd appreciate it very much as it would help me to understand the logic.
I don't think there are any inconsistencies but expect the issues encountered were caused by a typo I made. I used "item.isTime" and it should have been "item.isTimer" . Because I test with a device as trigger, I did not notice that before.
In this script
and
        if item.isTimer or item.isDevice then
Will do the same as besides HTTPResponses there are no other triggers used then Time and Devices. So if it is not a HTTPResponse it can only be Time or Device.
        devices =
        httpResponses =
            scriptVar .. '*',
I use a dummy device named extremeTrigger to trigger the script when testing so I don't have to modify the time and wait until the next full minute. That is also why I use "if item.isTime or item.isDevice"
See below (I use the dzVents addHours method for time objects to create a new time object with a time of 24 hours ago)
See below for the changes I made in function notify to have the script do this.
-- getMaxTempHum
return
    on =
        timer =
        devices =
        httpResponses =
            scriptVar .. '*',
    logging =
        marker = scriptVar,
    data =
        extremes =
            initial =
        local reportHours = 36 -- Amount of hours in the past until now (cannot be more then what you defined as short log period)
        local secondsBetweenApiCalls = 5 -- used in main to allow for some time between API calls (do not overload system)
        local secondsBetweenNotifications = 5 -- used in notify function to allow for some time between messages
        local extremes = {}
            dz.openURL(
                url = URLString,
            }).afterSec(delay)
            dz.log(fmtString)
            return to, from
            local delay = 0
               for _, sensorName in pairs(temphumDevices) do
                dz.log('Now processing records from sensor ' .. sensorName, dz.LOG_DEBUG)
                r = extremes[sensorName] -- get the right record
                notificationString =  '\n' ..   sensorName ..' high temp: '     .. r.highTemperature .. ' C (' .. r.highTemperatureTime .. ')\n' ..
                                                sensorName ..' low temp: '      .. r.lowTemperature .. ' C (' .. r.lowTemperatureTime .. ')\n'..
                                                sensorName ..' high humidity: ' .. r.highHumidity .. '% (' .. r.highHumidityTime .. ')\n' ..
                                                sensorName ..' low humidity: '  .. r.lowHumidity .. '% (' .. r.lowHumidityTime .. ')\n'
                dz.notify(sensorName .. ':' .. from .. ' until ' .. now, notificationString, dz.PRIORITY_NORMAL, nil,nil, dz.NSS_TELEGRAM, delay)
                delay = delay + secondsBetweenNotifications -- Allow some time between messages
            local pastTime = dz.time.addHours(reportHours  * -1).raw
            dz.log(reportHours .. ' hours ago...   ' .. pastTime, dz.LOG_DEBUG)
            for key in ipairs(rt) do
                if rt[key].d >= pastTime then
            return dvExtremes
        -- Main
            local delay = 0
                delay = delay + secondsBetweenApiCalls
                local from, now = getTimeWindow(reportHours)
Posted: Monday 12 October 2020 11:41
by Nautilus
Thanks a million, this is working great! :D I also sure I gained a lot of understanding about dzVents and can use it instead of traditional lua scripts in the future...:)
