Page 2 of 2
Re: thermostat for cooling and heating
Posted: Friday 30 November 2018 18:55
by Maxx
Hello
I solved it with a file on the SD card:
local myFile = "www/LightSettings.json"
local f = assert(io.open(myFile, "r"))
local t = f:read("*all")
f:close()
Put the LightSettings.json with a string, as long as you like, on your sd card
Then you can read the json from t
Posted: Friday 30 November 2018 20:13
by waaren
Skippiemanz wrote: Friday 30 November 2018 17:31
Maybe anyone has a idea for the user variables limitation
Can you try this one ? (moved from JSON formatted var to internal / persistent data)
version: 20181130-02
This script manage the different heating zones
Before making this script active you should first enter your rooms , sensors and valves indexes below in function initPersistent
define a switch for chiller if there is a main switch
define a switch for heater if there is a main switch
the value heater is the idx or name of the main heater switch. If your system does not have this, leave it out completely
the value cooler is the idx or name of the main cooler switch. If your system does not have this, leave it out completely.
the value selector is the idx or name of the selector switch that control if the heating or cooling system is active or stopped both.
the values room1, room2 etc, are the zonenames or roomnames and can be changed
the value after "s" is the id of the setpoint device in that room
the value after "t" is the id of the temperature sensor in that room
the value after "v" is the id of the radiator valve in that room (can be valvetype switch or valvetype setPoint )
idx are without "" and names are with ""
Change history:
20181012-01 Initial setup
20181012-02 Add Season selector
20181012-03 Add optional control for main heater / cooler device. Moved some code to functions
20181012-04 Add optional control for main heater / cooler device
20181013-01 Moved heater, cooler and selector idx to (JSON) uservariable
20181014-01 Bugfixes: defined local heating inside if block causing it to be nil.
return false from open and shut function could overwrite previous true state
20181114-01 Open and Shut also for setPoint TRV's
20181130-01 Add On and Off Hysterisis
20181130-02 Use internal / persistent table for systems with more than 3 rooms
on = { timer = { "every minute" }, -- adjust to your needs
logging = { level = domoticz.LOG_DEBUG, -- Comment this and the next line if script execute as expected
marker = "zoneTemperatures" },
data = { heating = { initial = {} },
execute = function(dz)
-- initialize table
t = {}
openTemperature = 28
closeTemperature = 16.5
local function initPersistent()
t.heater = 1095
t.cooler = 1096
t.selector = "Season"
t.rooms = {}
t.rooms = { -- Fill table below with roomNames, setPoint IDX, temp sensors IDX,and valve IDX
{room="room1",s=1088,t=144,v=1093},
{room="room2",s=1089,t=145,v=1094},
{room="room3",s=1090,t=146,v=1095},
{room="room4",s=1091,t=147,v=1096},
{room="room5",s=1092,t=148,v=1097},
dz.data.heating = t
-- do everything :-)
local function processRooms(t)
local heating if t.heater ~= nil then heating = dz.devices(t.heater) end
local cooling if t.cooler ~= nil then cooling = dz.devices(t.cooler) end
local action if t.selector ~= nil then action = dz.devices(t.selector).levelName else action = "Heating" end -- defaults to "Heating"
local hysteresisOn = 0.5
local hysteresisOff = 0.2
local openHeatingValves
local openCoolingValves
local function open(device)
if device == nil then return openHeatingValves end
if device.deviceSubType == "SetPoint" then
device.updateSetPoint(openTemperature)
device.switchOn().checkFirst()
return true
local function shut(device)
if device == nil then return openCoolingValves end
device.updateSetPoint(closeTemperature)
device.switchOff().checkFirst()
for i=1,#t.rooms do -- loop trough the rooms
local roomName = t.rooms[i].room
local setPoint = dz.devices(t.rooms[i].s).setPoint
local temperature = dz.devices(t.rooms[i].t).temperature
local radiatorValve = dz.devices(t.rooms[i].v)
if action == "Cooling" then
if temperature < setPoint then shut(radiatorValve) -- stop cooling
elseif temperature > ( setPoint + hysteresis ) then openCoolingValves = open(radiatorValve) end --start cooling
elseif action == "Heating" then
if temperature > ( setPoint - hysteresisOff ) then shut(radiatorValve) -- stop heating
elseif temperature < ( setPoint - hysteresisOn ) then openHeatingValves = open(radiatorValve) end --start heating
elseif action == "Stop" then
shut(cooling) shut(heating) shut(radiatorValve)
if openCoolingValves then open(cooling) else shut(cooling) end
if openHeatingValves then open(heating) else shut(heating) end
-- Get table from init function or persistent data
if not next(dz.data.heating) then
initPersistent()
t = dz.data.heating
processRooms(t)
Posted: Sunday 27 January 2019 21:30
by JvDorst
The developed scripts look usefull for my situation. More specific, I use the following devices 4 Popp radiator valves, 2 Honeywell radiator valves (controlled by Fibaro switches) and a thermostat (Essent e-thermostat). Next to implementing this script I want to add day/night scheme, triggering by presence switch and 24/7 temperature control of my daughter's (2 weeks old) bedroom. At this moment I just want to implement the script as added below by Waaren.
The above added plans for further developing this script are on my wish list (of course I will give an update when this is completed!). For now I created some dummy switches (temp, setpoint, etc.) to see if it works. Cooling is not relevant for me, but before removing the lines I want the script to work with dummy devices. Unfortunately I'm not managing to get it working.
Perhaps I missed something... Since this is my first step in programming/dzVents: can someone please indicate if the scipt works and which steps I have to follow?
waaren wrote: Friday 30 November 2018 20:13
Change history:
-- initialize table
t = {}
t.heater = 1095
t.cooler = 1096
t.rooms = {}
dz.data.heating = t
return true
initPersistent()
t = dz.data.heating
processRooms(t)
Posted: Monday 28 January 2019 0:49
by waaren
JvDorst wrote: Sunday 27 January 2019 21:30
The developed scripts look usefull for my situation. More specific, I use the following devices 4 Popp radiator valves, 2 Honeywell radiator valves (controlled by Fibaro switches) and a thermostat (Essent e-thermostat). Unfortunately I'm not managing to get it working.
Can you please elaborate on the "not managing to get it working bit" ?
If you are not yet familiar with dzvents then please look at the 10 lines
using dzVents with Domoticz for an intro to dzVents and howto get this script active in domoticz.
When you activate the script what do you see in the log ?
Posted: Tuesday 29 January 2019 20:19
by JvDorst
Thanks for your reply. I missed that section of the manual. At this moment I have no errors in the log and I will monitor the script for the coming days.
Still planning to further develop the script for my own purposes and in case of progress I will give an update. Now time to start learning dzVents will become my issue
