Page 2 of 2
Re: Capacitive Soil Moisture Sensor Wemos ESPeasy
Posted: Monday 25 May 2020 17:51
by zavjah
Hello folks,
I am looking for a solution to measure the soil moisture in my outside garden and this seams to be a promising solution. I didn’t though understand two things:
1. How is this sensor being supplied with electricity? Battery or something else?
2. Is this combo suitable for outside, too, provided I make it water proof?
Thx,
Zavjah
Posted: Sunday 28 June 2020 21:22
by acaonweb
I can explain you how i set my sensor
1) flashed with easyesp
2) connected sensor as shown in the thread here before
3) create a device for A0 analog, setting two point calibration to 0 the sensor min value (wet point) and 100 to sensor max value (dry point)
set an interval (ie:5)
Give a name to the sensor (ie: soil) and a name to the value (ie.: cP) and set 0 as decimal
4) create in domoticz a dummy sensor soil moisture and remember idx (ie:1000)
5) add MQTT server in controller menu
5) enable rules and write this rule
ON MQTT#Connected DO
    publish domoticz/in,'{"idx":1000,"nvalue":[soil#cP]}'
ENDON
6) in config menu set Sleep awake time to 10 and Sleep time 3600. it means that esp stay in deep sleep mode for 3600 seconds, wakes up, connect to network, connect to mqtt send value for 10 seconds and then go to sleep
7) with a jumper cable connect rat pin to gpio16 to enable deepsleep mode
8) connect 3 AAA battery to achieve 4.5V and connect esp to battery
9) reset the sensor et voilà
Ciao
Fabrizio
Posted: Sunday 27 December 2020 11:21
by florin
hello,
i have 1 little problem.
in domoticz, how i add rules and set rules ?
https://ibb.co/0rPd67V
Posted: Thursday 01 April 2021 12:33
by EDsteve
i also use Domoticz. But your posted img doesn't look familiar to me. Are you sure you are using Domoticz?
In Domoticz you can add rules under:
Setup -> More Oprions -> Events
