Hi All,
first of all, I registered myself many years ago, but it took me "some" time to finally switch over to ZWave/Domoticz.
Since last moth the ZWave area arrived at my place so therefor I was a bit inactive (till now
I'm facing the same problem too with all mine Fibaro FGS-223 nodes (Windows build of Domoticz):
- they do not respond to any command comming from Domoticz: NOK
- status updates from the FGS-223 tool works fine: OK
- Controlling it via the physical switch works also fine :OK[/list][/list]
All my Qubino nodes (ZMNHDD1 Flush Dimmer) work fine in all directions(switch, commands, updates).
I did not see a any post so far which pinpointed the "real" reason of the issue, or a possible solution which seems to work out for everyone.
So therefor I'm trying to hibernate this thread
It seems that the problem is indeed related to the Domoticz(openZWave) build as mentioned earlier in this thread(since it is working without any problem for the e.g. Qubino nodes ).
As skippy711 posed earlier (post_id=185630 time=1530821818) it might be related to the windows build, since it seems to work on the linux build?
So my questions:
- @virtualfreak: were you already able to solve the issue in the meantime yourself?
- @anyone/skippy711: is this issue indeed fixed by switching over from the windows to the linux version?
