Page 2 of 2
Re: Script to display next F1 Race
Posted: Saturday 15 September 2018 18:08
by Brutus
elmortero wrote: Saturday 15 September 2018 17:30
Brutus wrote: Saturday 15 September 2018 17:03 I don't understand the logic when these script run:
The second checks the qualifying every 20 min every day while the qualifying only is at Saturday?
The third script checks the Driver standings, every 15 minutes on saterday, sunday or monday. At Saturday there can't be any new driver standings because the race is at Sunday.
Last thing when will the site https://ergast.com/api/f1/2018/15/qualifying update? The qualifying is already done for a couple of hours and still no data...
EDIT: Qualifying data is now online after about 2 hours. I think this is normal?
You can of course change all the timers to your taste
About the third one: most likely I was doing tests on a Saturday while writing the script and did not want to wait until Sunday (so got the results from the previous results)
As for the update of the results (of qualify and race), that depends on the maintainer of Ergast. I believe I read somewhere that he tries to make sure to update within 4 hours.
If you want real-time results - and are willing to pay - you could subscribe to the F1.com API and adapt these scripts to get their data .
Dzvents is new for me so I looked at the following wiki page for timer options. Damm... planty of options there!
https://www.domoticz.com/wiki/DzVents:_ ... gger_rules
Posted: Saturday 15 September 2018 18:34
by melgi
Brutus wrote:I have extended the qualifying results to a top 6 . Max doesn't always qualify in the top 3 like today ;)
		timer = { 'every 20 minutes' },
		httpResponses = { 'nextF1', 'qualyF1' } -- matches callback string below
        data = {
            nextF1 = { initial = nil }
	execute = function(domoticz, triggerItem)
		if situation == 'CET' then -- check for DST
			 offset = 1            -- offset for timezone Madrid Winter time
        else offset = 2             -- offset for timezone Madrid Summer time, change these values to match your timezone
    local board = domoticz.data.nextF1
	local sensor =  domoticz.devices('F1 Race')
	local qboard =  domoticz.devices('F1 Kwalificatie')
	local prevQboard	= qboard.text
		if (triggerItem.isTimer) then
			domoticz.openURL({
				url = 'https://ergast.com/api/f1/current/next.json',
				method = 'GET',
				callback = 'nextF1'
		elseif (triggerItem.isHTTPResponse) then
			local response = triggerItem
				if (response.ok and response.isJSON) and (triggerItem.callback == 'nextF1') then			--when a valid json is received do this
				 local name = response.json.MRData.RaceTable.Races[1].raceName
				 local country = response.json.MRData.RaceTable.Races[1].Circuit.Location.country
				 local season = response.json.MRData.RaceTable.season
				 local round = response.json.MRData.RaceTable.round
				 local qualURL = ('https://ergast.com/api/f1/'..season..'/'..round..'/qualifying.json')
				 print('Find qualify at '..qualURL)
				 local fechapura = (response.json.MRData.RaceTable.Races[1].date)   --get the date as provided(YYYY-MM-DD)
    				 _,_,y,m,d = string.find(fechapura, "(%d+)%-(%d+)%-(%d+)")
				 local fecha = (d..'/'..m..'/'..y)
				 local horapura = (response.json.MRData.RaceTable.Races[1].time) --get time as provided (GMT without offset for DST)
    				 _,_,h,mi = string.find(horapura, "(%d+):(%d+)")
				  local hora = ((h + offset)..':'..mi)
				 local race = (name..'\n'..fecha..'Starting at '..hora)
				 	 if board ~= race then              --Only update text sensor if current info is different from the stored info
				 	  sensor.updateText(race)
					  domoticz.data.nextF1 = race       --write the new info to global variable
				 --now get qualify
				 print('** Fetching info from qualify')
				 --local qualURL = 'https://ergast.com/api/f1/2018/7/qualifying.json'
					domoticz.openURL({
					url = qualURL,
					method = 'GET',
					callback = 'qualyF1'
			elseif  (response.ok and response.isJSON) and (triggerItem.callback == 'qualyF1') then
					local Races = #response.json.MRData.RaceTable.Races
					print('**Number of records for Qualify = '..Races)
				if Races > 0 then
				 print('** Qualify results are availabale')
					--get data for P1
					 local P1driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[1].Driver.familyName
					 local P1Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[1].Constructor.name
					 local P1Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[1].Q1
						 _,_,m,s = string.find(P1Q1, "(%d+):(%d+.+)")
						local P1Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P1Best = P1Q1
					 local P1Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[1].Q2
						 _,_,m,s = string.find(P1Q2, "(%d+):(%d+.+)")
						local P1Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P1Q2sec < P1Q1sec then P1Best = P1Q2 end
					 local P1Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[1].Q3
						 _,_,m,s = string.find(P1Q3, "(%d+):(%d+.+)")
						local P1Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P1Q3sec < P1Q1sec and P1Q3sec < P1Q2sec then P1Best = P1Q3 end
					print('P1Best = '..P1Best)
					--now get data for P2
					 local P2driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[2].Driver.familyName
					 local P2Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[2].Constructor.name
					 local P2Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[2].Q1
						 _,_,m,s = string.find(P2Q1, "(%d+):(%d+.+)")
						local P2Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P2Best = P2Q1
					 local P2Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[2].Q2
						 _,_,m,s = string.find(P2Q2, "(%d+):(%d+.+)")
						local P2Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P2Q2sec < P2Q1sec then P2Best = P2Q2 end
					 local P2Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[2].Q3
						 _,_,m,s = string.find(P2Q3, "(%d+):(%d+.+)")
						local P2Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P2Q3sec < P2Q1sec and P2Q3sec < P2Q2sec then P2Best = P2Q3 end
					print('P2Best = '..P2Best)
					-- get data for P3
					 local P3driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[3].Driver.familyName
					 local P3Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[3].Constructor.name
					 local P3Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[3].Q1
						 _,_,m,s = string.find(P3Q1, "(%d+):(%d+.+)")
						local P3Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P3Best = P3Q1
					 local P3Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[3].Q2
						 _,_,m,s = string.find(P3Q2, "(%d+):(%d+.+)")
						local P3Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P3Q2sec < P3Q1sec then P3Best = P3Q2 end
					 local P3Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[3].Q3
						 _,_,m,s = string.find(P3Q3, "(%d+):(%d+.+)")
						local P3Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P3Q3sec < P3Q1sec and P3Q3sec < P3Q2sec then P3Best = P3Q3 end
					print('P3Best = '..P3Best)
					--now get data for P4
					 local P4driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[4].Driver.familyName
					 local P4Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[4].Constructor.name
					 local P4Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[4].Q1
						 _,_,m,s = string.find(P4Q1, "(%d+):(%d+.+)")
						local P4Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P4Best = P4Q1
					 local P4Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[4].Q2
						 _,_,m,s = string.find(P4Q2, "(%d+):(%d+.+)")
						local P4Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P4Q2sec < P4Q1sec then P4Best = P4Q2 end
					 local P4Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[4].Q3
						 _,_,m,s = string.find(P4Q3, "(%d+):(%d+.+)")
						local P4Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P4Q3sec < P4Q1sec and P4Q3sec < P4Q2sec then P4Best = P4Q3 end
					print('P4Best = '..P4Best)
					--now get data for P5
					 local P5driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[5].Driver.familyName
					 local P5Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[5].Constructor.name
					 local P5Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[5].Q1
						 _,_,m,s = string.find(P5Q1, "(%d+):(%d+.+)")
						local P5Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P5Best = P5Q1
					 local P5Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[5].Q2
						 _,_,m,s = string.find(P5Q2, "(%d+):(%d+.+)")
						local P5Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P5Q2sec < P4Q1sec then P5Best = P4Q2 end
					 local P5Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[5].Q3
						 _,_,m,s = string.find(P5Q3, "(%d+):(%d+.+)")
						local P5Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P5Q3sec < P5Q1sec and P5Q3sec < P5Q2sec then P5Best = P5Q3 end
					print('P5Best = '..P5Best)
					--now get data for P6
					 local P6driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[6].Driver.familyName
					 local P6Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[6].Constructor.name
					 local P6Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[6].Q1
						 _,_,m,s = string.find(P6Q1, "(%d+):(%d+.+)")
						local P6Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P6Best = P4Q1
					 local P6Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[6].Q2
						 _,_,m,s = string.find(P6Q2, "(%d+):(%d+.+)")
						local P6Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P6Q2sec < P6Q1sec then P6Best = P6Q2 end
					 local P6Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[6].Q3
						 _,_,m,s = string.find(P6Q3, "(%d+):(%d+.+)")
						local P6Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P6Q3sec < P6Q1sec and P6Q3sec < P6Q2sec then P6Best = P6Q3 end
					print('P6Best = '..P6Best)
					local Qresults = ('1. '..P1driver..'('..P1Const..') - '..P1Best..'\n2. '..P2driver..'('..P2Const..') - '..P2Best..'\n3. '..P3driver..'('..P3Const..') - '..P3Best..'\n4. '..P4driver..'('..P4Const..') - '..P4Best..'\n5. '..P5driver..'('..P5Const..') - '..P5Best..'\n6. '..P6driver..'('..P6Const..') - '..P6Best)
					local QresultsPrint = ('\n'..Qresults)
					print(Qresults)
    				if Qresults ~= prevQboard then
    				 qboard.updateText(Qresults)
				--end
Brutus, I'd like to use your script. I have a virtual sensor called "F1" and two text switches called "F1 Race" and "F1 Quali". What do I need to change in your script to have it work for me too?
Verstuurd vanaf mijn SM-G955F met Tapatalk
Posted: Saturday 15 September 2018 18:40
by Brutus
@melgi
I don't know why u need a Virtual Sensor called "F1"?
But for now you need the change this:
To this:
	local qboard =  domoticz.devices('F1 Quali')
Posted: Saturday 15 September 2018 18:59
by melgi
Brutus, thanx for your reply. Will try that. In my post I made a mistake. The "F1" is actually the Dummy I created in the Hardware section. On this hardware I created the said virtual text sensors.
Posted: Saturday 15 September 2018 20:05
by Furiousz23
Great script! Now i don`t have to open the Ziggo app anymore to check when the race is starting :mrgreen: . Now i have to figure out how to get a Telegram notification through Domoticz one hour before the start of the race.
Posted: Sunday 16 September 2018 12:01
by Brutus
Furiousz23 wrote: Saturday 15 September 2018 20:05 Great script! Now i don`t have to open the Ziggo app anymore to check when the race is starting :mrgreen: . Now i have to figure out how to get a Telegram notification through Domoticz one hour before the start of the race.
That would be cool indeed.
Posted: Monday 17 September 2018 21:11
by melgi
I still can't get this to work :-(.
THIS SCRIPT DOESN'T WORK FOR ME:
timer = { 'every 2 minutes on sat, sun, mon, tu, wed, thu, fri' }
--timer = { 'at 10:00' },
httpResponses = { 'nextF1' } -- matches callback string below
data = {
local sensor = domoticz.devices('F1_next_race') -- name of my virtual text sensor
domoticz.openURL({
method = 'GET',
callback = 'nextF1'
if (response.ok and response.isJSON) then --when a valid json is received do this
--Next line converts it to DD-MM-YYYY, you can delete it if you are OK with provided date format
local YY = string.sub(fechapura, 1,4); local MM = string.sub(fechapura, 6,7); local DD = string.sub(fechapura, 9,10); local fecha = (DD..'-'..MM..'-'..YY)
--convert provided time to time in your timezone
local HH = (string.sub(horapura, 1,2) + offset); local MM = string.sub(horapura, 4,5); local hora = (HH..':'..MM)
local race = (name..'\n'..fecha..' at '..hora)
print('**nextF1 failed to fetch info')
end --end of actions after valid json received
THIS SCRIPT WORKS FOR ME:
timer = { 'every 2 minutes on sat, sun, mon, tu, wed, thu, fri' }, --{ 'at *:22', 'every 15 minutes on sat, sun, mon, tu, wed, thu, fri' },
httpResponses = { 'F1-Top3' },
devices = {'F1'}
local board = domoticz.devices('F1 race') --a virtual text sensor
local prevboard = tostring(board.text) --get current value of text sensor
domoticz.openURL({
url = 'https://ergast.com/api/f1/current/driverStandings.json',
method = 'GET',
callback = 'F1-Top3'
local pInfo = ''
local bInfo = ''
tl = 5
tc = 1
repeat
local code = tostring(response.json.MRData.StandingsTable.StandingsLists[1].DriverStandings[tc].Driver.code)
local points = tostring(response.json.MRData.StandingsTable.StandingsLists[1].DriverStandings[tc].points)
local const = tostring(response.json.MRData.StandingsTable.StandingsLists[1].DriverStandings[tc].Constructors[1].name)
local pos = tostring(response.json.MRData.StandingsTable.StandingsLists[1].DriverStandings[tc].position)
if string.len(points) < 3 then points = (' '..points) end
local Full = (pos..'. '..code..' '..points..' '..const..'\n')
tc = tc + 1
pInfo = (pInfo..Full)
until tc == tl + 1
if pInfo ~= prevboard then
board.updateText(pInfo)
print('** F1-Top3 failed to fetch info')
What am I doing wrong? I'm just starting to use dzVents and trying really hard to understand this. Sadly I can't see any log from running this script. Maybe it contains the errors that show up while running this script. If only I could read/see them, I could try to figure out what is going wrong here.
Posted: Wednesday 29 April 2020 9:58
by Mdieli
For some reason, since a couple of months the time is not shown correct anymore.
instead of
Example Grand Prix at 15:10
it shows
Example Grand Prix at 15.0:10
When i remove the addition of the offset, the time is shown correctly.
Original code:
Removed the offset:
local HH = (string.sub(horapura, 1,2)); local MM = string.sub(horapura, 4,5); local hora = (HH..':'..MM)
So my best educated guess is that the mistake is happening with rounding of the "offset" value.
However, i'm no programmer and have absolutely no clue how to solve this.
Do you have any ideas I can try?
Posted: Wednesday 29 April 2020 12:14
by elmortero
Hi, I hadn't noticed actually since there are no GPs in the near future :-P
I think - but no time to check now - that it has to do with the upgrade to LUA 5.3
It is strange that by removing the offset you get the correct time as it is in UTC.
Quick (and dirty) fix for now:
Change this line:
into : local hora = (math.floor(h + offset)..':'..mi)
That will get rid of the .0 decimal
Posted: Wednesday 29 April 2020 12:26
by Snowtiger
elmortero wrote:Hi, I hadn't noticed actually since there are no GPs in the near future :-P
Change this line:
Correct, since 5.3 - Introduction of an integer subtype for numbers with as side effect that a conversion of a float to a string now adds a .0 suffix to
the result if it looks like an integer. (For instance, the float 2.0 will be printed as 2.0, not as 2 )
Posted: Wednesday 29 April 2020 13:10
by Mdieli
elmortero wrote: Wednesday 29 April 2020 12:14 Hi, I hadn't noticed actually since there are no GPs in the near future :-P
Change this line:
Thank you for your quick response, the solution works like a charm!
Posted: Sunday 16 October 2022 14:17
by Drees
Brutus wrote: Saturday 15 September 2018 17:42 I have extended the qualifying results to a top 6 . Max doesn't always qualify in the top 3 like today ;)
        data = {
			domoticz.openURL({
				method = 'GET',
				callback = 'nextF1'
				 --now get qualify
					domoticz.openURL({
					url = qualURL,
					method = 'GET',
				if Races > 0 then
					--get data for P1
						local P1Best = P1Q1
						local P2Best = P2Q1
					-- get data for P3
						local P3Best = P3Q1
						local P4Best = P4Q1
						local P5Best = P5Q1
						local P6Best = P4Q1
					print(Qresults)
				--end
I was trying to use this script.
i copy paste the script, but when i look at the error log i got the message
 2022-10-16 14:14:39.011 Error: dzVents: Error: (3.1.8) error loading module 'F1_Quali3' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/F1_Quali3.lua':
2022-10-16 14:14:39.011 ...domoticz/scripts/dzVents/generated_scripts/F1_Quali3.lua:165: 'end' expected (to close 'function' at line 10) near <eof>
It looks like there is missing a [END] but i don't see where i have to put the [END].
But I'm not sure about it, because i cant be the fist one in 2 your who notice this.
i hope someone with code skills can help me.
Posted: Saturday 29 October 2022 21:34
by elmortero
Looks like you missed some end to close the if loops (@lines 54, 164 and 165) and a closing } at the end of the script.
I haven't tried but this should fix it (moved the script to Python now)
        data = {
			domoticz.openURL({
				method = 'GET',
				callback = 'nextF1'
				 --now get qualify
					domoticz.openURL({
					url = qualURL,
					method = 'GET',
				if Races > 0 then
					--get data for P1
						local P1Best = P1Q1
						local P2Best = P2Q1
					-- get data for P3
						local P3Best = P3Q1
						local P4Best = P4Q1
						local P5Best = P5Q1
						local P6Best = P4Q1
					print(Qresults)
Posted: Sunday 27 November 2022 18:32
by HansieNL
Because there's no new F1 Race information yet I get the following errors every day now:
2022-11-27 10:00:04.459 Error: dzVents: Error: (3.1.8) An error occurred when calling event handler f1
2022-11-27 10:00:04.459 Error: dzVents: Error: (3.1.8) /home/pi/domoticz/scripts/dzVents/scripts/f1.lua:29: attempt to index a nil value (field '?')
I'm using the 1st script from the 1st page. Line 29 contains:
Can someone tell me how to get rid of the errors?
Thanks in advance.
Posted: Monday 28 November 2022 16:43
by waltervl
When I check if https://ergast.com/api/f1/current/next.json I get answer "Unable to select database" which is no json.
So line
should fail as response.isJSON is false.
Do you have response.isJSON in your script?
Posted: Monday 28 November 2022 23:20
by HansieNL
waltervl wrote: Monday 28 November 2022 16:43 When I check if https://ergast.com/api/f1/current/next.json I get answer "Unable to select database" which is no json.
I get the following info now when I check https://ergast.com/api/f1/current/next.json
{"MRData":{"xmlns":"http:\/\/ergast.com\/mrd\/1.5","series":"f1","url":"http://ergast.com/api/f1/current/next.json","limit":"30","offset":"0","total":"0","RaceTable":{"season":"2023","round":"1","Races":[]}}}
I have the following code in the script:
There's no next race data available right now. Can that be the reason for the error message?
Posted: Tuesday 28 March 2023 15:57
by JustDude
I extended the script yesterday evening with the Qualifying date/time information, the text is overwritten after Qualification with the results.
However I could not test that last bit ;) Any tips for improving or correction are welcome.
And it looks like this:
I added the code below after the F1 text update
followed by
			-- get Quali date / time (is re-used for Q results after the Qualification)
			local qdateraw = (response.json.MRData.RaceTable.Races[1].Qualifying.date)
				_,_,y,m,d = string.find(qdateraw, "(%d+)%-(%d+)%-(%d+)")
			local qdate = (d..'/'..m..'/'..y)
			local qtimeraw = (response.json.MRData.RaceTable.Races[1].Qualifying.time)
				_,_,h,mi = string.find(qtimeraw, "(%d+):(%d+)")
			local qtime = (math.floor(h + offset)..':'..mi)
			local quali = (name..'\n'..qdate..' Starting at '..qtime)
			if qboard ~= quali then              --Only update text sensor if current info is different from the stored info
				qboard.updateText(quali)
				domoticz.data.nextQF1 = qboard       --write the new info to global variable
Declare domoticz.data.nextQF1 at the top
Posted: Wednesday 06 May 2026 15:06
by madpatrick
I ran to this script and converted it to a python plugin
First setup is ready, but yet fully tested
Please share your comments or ideas for improvement
https://github.com/MadPatrick/domoticz_F1
2026-05-06 15_04_07-Greenshot.png (17.44 KiB) Viewed 6010 times
Thanks to the author of the initial script
