Page 2 of 2
Re: Casambi and Domoticz
Posted: Sunday 12 July 2020 12:03
by FireWizard
Hi, @erikjanverweij
I only have it working for a short while, but it looks like it's working flawles.
That looks nice. I created a clean flow, wich you can use as an example.
1. As you see, the upper stream is from Casambi to Domoticz, while the lower is from Domoticz to Casambi.
2. In the upper stream the top is used for a dimmable lamp and the lower part is used for a dimmable lamp with adjustable color temperature.
3. If you have more lamps of a particular type, you can copy the two nodes (marked "Choose accessory/service" and "Set topic") and feed them to the function node.
4. You have to set your Domotixz IDX in the "Set topic" node.
5. In the lower stream, you have to set the Domoticz IDX in the node, called "Filter Idx", which you can expand to the number of lamps you have.
6. Dependent on the type of lamp (only dimmable or with color temperature) you copy the function node and the Homebridge output node and connect the function node to the corresponding output of the "Switch" node.
The corresponding flow, you will find below.
[{"id":"f969203d.64c2d","type":"hb-event","z":"8331ad68.1e8ba","name":"","Homebridge":"","Manufacturer":"","Service":"","device":"","conf":"ad94f0af.d9b61","x":230,"y":60,"wires":[["322df4f5.4e1f6c"]]},{"id":"72b367de.e52358","type":"function","z":"8331ad68.1e8ba","name":"","func":"if (msg.payload.On === true)\n\n{\n    msg.payload = {\n        \"command\": \"switchlight\",\n        \"idx\": msg.topic,\n        \"switchcmd\": \"Set Level\",\n        \"level\": msg.payload.Brightness\n        }\n}\n\nelse if (msg.payload.On  === false)\n\n{\n    msg.payload = {\n        \"command\": \"switchlight\",\n        \"idx\": msg.topic,\n        \"switchcmd\": \"Off\",\n        };\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":640,"y":60,"wires":[["67a7be59.c329b"]]},{"id":"387ae58a.a6af2a","type":"function","z":"8331ad68.1e8ba","name":"","func":"if (msg.payload.On === true)\n{\n    msg.payload = {\n        \"command\": \"setcolbrightnessvalue\",\n        \"idx\": msg.topic,\n        \"brightness\": msg.payload.Brightness,\n        \"color\": {\n            \"m\": 2,\n            \"t\": parseInt((msg.payload.ColorTemperature -222) * (255/232))\n        }\n    }\n}       \nelse if (msg.payload.On  === false)\n{\n    msg.payload = {\n        \"command\": \"switchlight\",\n        \"idx\": msg.topic,\n        \"switchcmd\": \"Off\"\n    };\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":640,"y":140,"wires":[["67a7be59.c329b"]]},{"id":"67a7be59.c329b","type":"mqtt out","z":"8331ad68.1e8ba","name":"Domoticz In","topic":"domoticz/in","qos":"","retain":"","broker":"c2d9657a.d81bf8","x":830,"y":100,"wires":[]},{"id":"3a2d0867.54c118","type":"mqtt in","z":"8331ad68.1e8ba","name":"Domoticz Out","topic":"domoticz/out","qos":"2","datatype":"json","broker":"c2d9657a.d81bf8","x":190,"y":259,"wires":[["ac0c58eb.b08dd8"]]},{"id":"ac0c58eb.b08dd8","type":"switch","z":"8331ad68.1e8ba","name":"Filter Idx","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"22","vt":"str"},{"t":"eq","v":"23","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":259,"wires":[["80d1d798.ab93c8"],["8def210e.ad7408"]]},{"id":"80d1d798.ab93c8","type":"function","z":"8331ad68.1e8ba","name":"","func":"switch (msg.payload.nvalue) {\n    \n    case 0: //Uit\n    msg.payload = {\"On\":false,\"Brightness\":0};\n    break;\n\n    case 1: //Aan\n    case 2: //Dimmer stand\n    msg.payload = {\"On\":true,\"Brightness\":parseInt(msg.payload.svalue1)};\n    break;\n\n    \n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":219,"wires":[["5f47300e.8d402"]]},{"id":"5f47300e.8d402","type":"hb-control","z":"8331ad68.1e8ba","name":"","Homebridge":"","Manufacturer":"","Service":"","device":"","conf":"361f342f.410a7c","x":790,"y":219,"wires":[]},{"id":"8def210e.ad7408","type":"function","z":"8331ad68.1e8ba","name":"","func":"switch (msg.payload.nvalue) {\n    \n    case 0: //Uit\n    msg.payload = {\"On\":false,\"Brightness\":0};\n    break;\n    \n    case 1: //Aan\n    case 10: //Color Temperature\n    case 15: //Dimmer stand\n    msg.payload = {\"On\":true,\"Brightness\":parseInt(msg.payload.svalue1),\"ColorTemperature\":parseInt((msg.payload.Color.t) * (232/255) + 222)};\n    break;\n\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":300,"wires":[["4f13924d.282e94"]]},{"id":"4f13924d.282e94","type":"hb-control","z":"8331ad68.1e8ba","name":"","Homebridge":"","Manufacturer":"","Service":"","device":"","conf":"361f342f.410a7c","x":790,"y":300,"wires":[]},{"id":"57a1bdf2.efbb6c","type":"hb-event","z":"8331ad68.1e8ba","name":"","Homebridge":"","Manufacturer":"","Service":"","device":"","conf":"ad94f0af.d9b61","x":230,"y":140,"wires":[["dcc781e6.6c7d5"]]},{"id":"322df4f5.4e1f6c","type":"change","z":"8331ad68.1e8ba","name":"Set topic","rules":[{"t":"set","p":"topic","pt":"msg","to":"22","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":60,"wires":[["72b367de.e52358"]]},{"id":"dcc781e6.6c7d5","type":"change","z":"8331ad68.1e8ba","name":"Set topic","rules":[{"t":"set","p":"topic","pt":"msg","to":"23","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":140,"wires":[["387ae58a.a6af2a"]]},{"id":"ad94f0af.d9b61","type":"hb-conf","z":"","username":"12345"},{"id":"c2d9657a.d81bf8","type":"mqtt-broker","z":"","name":"","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"361f342f.410a7c","type":"hb-conf","z":"","username":"12345"}]
Best regards
Posted: Tuesday 19 July 2022 2:37
by superkikim
Beware. I just requested an API key to Casambi. And I got following heads-up:
Please note that currently API keys are made valid until end of year, after which the key can be available against a fee. The exact details have not been released yet around the API key pricing.
Also, Casambi has announced he is backing up the forthcoming Matter standard which seems like a good news.
Posted: Thursday 09 January 2025 15:07
by mailgoe
An alternative for native support of Casambi devices is using [Atios SmartCore](https://atios.ch/en/produkt/atios-smartcore/) in conjunction with a [CBU-DCS Casambi module](https://www.casambi-onlineshop.de/p/dal ... cPId2jERa-). That allows you to control up to 64x Casambi Devices via Matter or HomeKit, including synchronization of the state with the official Casambi App. Tuneable White and Colour Control is working as well! And of course you could use the additional on-device outputs and inputs to integrate further devices into your Smart Home.
