Daily Energy usage cost
MikeF
- Domoticz version: V2022.2
Re: Daily Energy usage cost
Run it at the command line (e.g., python </path to script/>energy_cost.py ) and see if you get any errors.
- EdwinK
- Domoticz version: BETA
When I run the script from command line there are no errors.
- EdwinK
These are the costs I find at the Eneco site.
fixed = 0 # fixed cost in euro
unit = 0.2032 # unit cost in eurocents
MikeF
Wow, that's cheap!
My unit rate is 13.94p = 16.03 cents (approx.)
- are you sure your rate isn't 20.32 cents? (my script divides by 100, to convert to pounds / euros)
Mike
Mike
- EdwinK
Yes, you are right.
€ 0,2271 Per kwh High
€ 0,2130 Per kwh Low
Fixed costs € 3,46 month
astrapowerrr
- Target OS: -
Edwink
I have also toon can i copy your script so i can change it to my own costs.
I am very interested in using daily cost just like toon.
And use this in dashticz too.
Can you help me with this one?
garethiowc
Hi All,
recently rebuild my computer and have run into the following problem -
any ideas?
/usr/bin/python2.7 energy_cost.py
File "energy_cost.py", line 36, in <module>
kW = domoticzread(OwlIdx, 'CounterToday')
File "energy_cost.py", line 32, in domoticzread
jsonData = json.loads(response.text)
File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 364, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python2.7/json/decoder.py", line 382, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded-
simon_rb
- Target OS: -
This looks good.
I am looking for a way to calculate the cost which takes into account dual tariffs like Economy 7? Some how add a time calculation into the equation or rely on a dummy switch/VAR which could be timed with the ECO 7 timings?
Would also love the monthly cost also..
Any help would be great.
Many Thanks
Many Thanks
