Daily Energy usage cost
MikeF
Domoticz version: V2022.2
Re: Daily Energy usage cost
Post by MikeF »
Run it at the command line (e.g., python </path to script/>energy_cost.py ) and see if you get any errors.
EdwinK
Post by EdwinK »
When I run the script from command line there are no errors.
EdwinK
Post by EdwinK »
These are the costs I find at the Eneco site.
fixed = 0 # fixed cost in euro
unit = 0.2032 # unit cost in eurocents
MikeF
Post by MikeF »
Wow, that's cheap! :o
My unit rate is 13.94p = 16.03 cents (approx.)
- are you sure your rate isn't 20.32 cents? (my script divides by 100, to convert to pounds / euros)
Mike
EdwinK
Post by EdwinK »
Yes, you are right.
€ 0,2271 Per kwh High
€ 0,2130 Per kwh Low
Fixed costs € 3,46 month
astrapowerrr
Post by astrapowerrr »
Edwink
I have also toon can i copy your script so i can change it to my own costs.
I am very interested in using daily cost just like toon.
And use this in dashticz too.
Can you help me with this one?
garethiowc
Post by garethiowc »
Hi All,
recently rebuild my computer and have run into the following problem -
/usr/bin/python2.7  energy_cost.py
  File "energy_cost.py", line 36, in <module>
    kW = domoticzread(OwlIdx, 'CounterToday')
  File "energy_cost.py", line 32, in domoticzread
    jsonData = json.loads(response.text)
  File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
    return _default_decoder.decode(s)
  File "/usr/lib/python2.7/json/decoder.py", line 364, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/lib/python2.7/json/decoder.py", line 382, in raw_decode
    raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
any ideas?
simon_rb
Post by simon_rb »
This looks good.
I am looking for a way to calculate the cost which takes into account dual tariffs like Economy 7? Some how add a time calculation into the equation or rely on a dummy switch/VAR which could be timed with the ECO 7 timings?
Would also love the monthly cost also..
Any help would be great.
Many Thanks
Users browsing this forum: pfloryann and 1 guest
