Thanks, that helped me a lot! I'm a developer although new to dzVents and LUA. Yesterday my dust sensor died although it was still providing humidity and temperature readings. What happened is that the temperature ended up in the PM2.5 sensor. So I decided to make the script more robuust and also check the value_type. Also earlier I noticed the dust sensor produces a lot of 99.9 values which were always odly out of bounds so I started to ignore these values as well.assenzuid wrote: ↑Tuesday 03 July 2018 21:34 I have created a dummy device and some virtual sensors and use a LUA script.
I'm also publishing the valuses at my site.Code: Select all
local FQDN = 'IP DOMOTICZ' return { active = true, on = { timer = { 'every minute' }, httpResponses = { 'luftdatenRetrieved' } -- matches callback string below }, execute = function(domoticz, item) if (item.isTimer) then domoticz.openURL({ url = 'http://' .. FQDN .. '/data.json', method = 'GET', callback = 'luftdatenRetrieved' }) elseif (item.isHTTPResponse) then if (item.ok and item.isJSON) then -- statusCode == 2xx if tonumber(item.json.age) < 60 then -- 1: SDS_P1 PM10, 2: SDS_P2 PM2.5, 3: DHT22 temp, 4: DHT22 hum, 5: BME280 temp, 6: BME280 hum, 7: BME280 baro domoticz.devices('Luftdaten PM10').updateCustomSensor(item.json.sensordatavalues[1].value) domoticz.devices('Luftdaten PM2.5').updateCustomSensor(item.json.sensordatavalues[2].value) domoticz.devices('Luftdaten DHT22').updateTempHum(item.json.sensordatavalues[3].value,item.json.sensordatavalues[4].value,0) domoticz.devices('Luftdaten BME280').updateTempHumBaro(item.json.sensordatavalues[5].value,item.json.sensordatavalues[6].value,0,(item.json.sensordatavalues[7].value/100),0) end else -- oops domoticz.log('Error fetching Luftdaten data', domoticz.LOG_ERROR) domoticz.log(item.data, domoticz.LOG_ERROR) end end end }
http://emmenzuidwest.nl/weather/index.p ... #data-area
It was a bit challenging to understand how to create functions inside functions but every language has its perks
Here is my code hope it proves handy for other people using dust sensor, it also is a bit easier to adapt if you have other kind or additional sensors.
Remember to change your device names and IP adres.
Now I can continue to investigate what is wrong with the dust sensor.
active = true,
logging = { level = domoticz.LOG_ERROR,
marker = "luftdaten" },
execute = function(dz, item)
local function FindValueFromArray(ValueArray, ValueName)
local emptyvar
for ArrayValueID = 1, #ValueArray do
if ValueArray[ArrayValueID].value_type == ValueName then
return ValueArray[ArrayValueID].value
return emptyvar
local function IsValidPMMeasurement(InputValue)
if (InputValue == nil) then
return false
if (InputValue == 99.9) then
return false
if (InputValue == 0) then
return false
return true
dz.openURL({
url = 'http://airrohr-14319147/data.json',
method = 'GET',
local temperature = tonumber(FindValueFromArray(item.json.sensordatavalues, 'temperature'))
local humidity = tonumber(FindValueFromArray(item.json.sensordatavalues, 'humidity'))
local PM100 = tonumber(FindValueFromArray(item.json.sensordatavalues, 'SDS_P1'))
local PM25 = tonumber(FindValueFromArray(item.json.sensordatavalues, 'SDS_P2'))
if IsValidPMMeasurement(PM100) then
dz.devices('Fijnstof PM10').updateCustomSensor(PM100)
if IsValidPMMeasurement(PM25) then
dz.devices('Fijnstof PM2.5').updateCustomSensor(PM25)
if (temperature < 100) then
dz.devices('Weerstation').updateTempHum(temperature, humidity, 0)
-- oops
dz.log('Error fetching Luftdaten data', dz.LOG_ERROR)
dz.log(item.data, dz.LOG_ERROR)
