Page 2 of 33
Re: Python Plugin : Broadlink RM2 V4
Posted: Tuesday 30 January 2018 18:07
by zak45
@titoz
hummm.. that's look ok.. do you have installed pyaes & pycrypto ??
Posted: Tuesday 30 January 2018 21:24
by titoz
@zak45
yes, i have installed both as described in the wiki:
For others
pip3 install broadlink --> mandatory
pip3 install pycrypto --> no more mandatory, pyaes will be used instead (this need to be double-checked)
...but i used the pip2 because i'm not able to install pip3 on my synology
Posted: Tuesday 30 January 2018 23:16
by zak45
titoz wrote: Tuesday 30 January 2018 21:24
@zak45
For others
So.. that's the problem.
See this link, hope could provide you some help:
https://zhougy0717.github.io/2017/07/31 ... on%20Echo/
Posted: Wednesday 31 January 2018 8:24
by titoz
zak45 wrote: Tuesday 30 January 2018 23:16
@zak45
For others
Thank you very much, i will try it for sure and i will let you know
Posted: Thursday 01 February 2018 19:21
by titoz
HI Zak45
i have try to reinstall all, following the link that u sent me, but nothing has changed and i still have the same issue.
I'm able to turn ON/OFF the spmini using this python script:
#!/usr/bin/python
import broadlink
import sys
device_ip="192.168.1.5"
device_port=80
device_mac="02XXXXXXDC61"
device_type="broadlink.sp2"
action = str(sys.argv[1])
device = broadlink.sp2(host=(device_ip,device_port), mac=bytearray.fromhex(device_mac))
device.auth()
#device.host
if action == "on":
device.set_power(True)
elif action == "off":
device.set_power(False)
elif action == "status":
print "on" if device.check_power() else "off"
Any other suggestion about?
Thanks in advance
titoz
Posted: Thursday 01 February 2018 21:45
by febalci
Wow @titoz,
Thank you very much for the bash script; my SP mini is at last working with a script. I was hopeless after failing from the @zak45 plugin; now at least i know that it is doable
Now i have to look for ways to make the plugin work.
Posted: Saturday 03 February 2018 21:27
by peterredl
Installation of Broadlink extension fails.
I run a Domoticz with Xiaomi devices which works perfectly. Now I would like to integrate my other devices which I steer with Broadlink RM2 into Domoticz. Unfortunately, the setup routine for Windows does not work. The routine turns red every time and ends.
Unfortunately, I can not continue and ask for help. If someone can help me please send me a message.
Broadlink RM2 python plugin install for Win"
" this need to be run with admin right "
"Search python version"
Python 3.6.4
" main module used by the plugin"
"Python version : " 36
Collecting broadlink
Using cached broadlink-0.6.tar.gz
Collecting pycrypto==2.6.1 (from broadlink)
Using cached pycrypto-2.6.1.tar.gz
Installing collected packages: pycrypto, broadlink
Running setup.py install for pycrypto ... error
Complete output from command c:\users\peter\appdata\local\programs\python\python36-32\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Users\\peter\\AppData\\Local\\Temp\\pip-build-2roclsga\\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\peter\AppData\Local\Temp\pip-79pbxumi-record\install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build\lib.win32-3.6
creating build\lib.win32-3.6\Crypto
copying lib\Crypto\pct_warnings.py -> build\lib.win32-3.6\Crypto
copying lib\Crypto\__init__.py -> build\lib.win32-3.6\Crypto
creating build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\hashalgo.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\HMAC.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\MD2.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\MD4.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\MD5.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\RIPEMD.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA224.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA256.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA384.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA512.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\__init__.py -> build\lib.win32-3.6\Crypto\Hash
creating build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\AES.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\ARC2.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\ARC4.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\blockalgo.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\Blowfish.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\CAST.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\DES.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\DES3.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_OAEP.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_v1_5.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\XOR.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\__init__.py -> build\lib.win32-3.6\Crypto\Cipher
creating build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\asn1.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\Counter.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\number.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\py3compat.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\randpool.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\RFC1751.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\winrandom.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\_number_new.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\__init__.py -> build\lib.win32-3.6\Crypto\Util
creating build\lib.win32-3.6\Crypto\Random
copying lib\Crypto\Random\random.py -> build\lib.win32-3.6\Crypto\Random
copying lib\Crypto\Random\_UserFriendlyRNG.py -> build\lib.win32-3.6\Crypto\Random
copying lib\Crypto\Random\__init__.py -> build\lib.win32-3.6\Crypto\Random
creating build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaAccumulator.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaGenerator.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\SHAd256.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\__init__.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
creating build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\fallback.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\nt.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\posix.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\rng_base.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\__init__.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
creating build\lib.win32-3.6\Crypto\SelfTest
copying lib\Crypto\SelfTest\st_common.py -> build\lib.win32-3.6\Crypto\SelfTest
copying lib\Crypto\SelfTest\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest
creating build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\common.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_AES.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC2.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC4.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_Blowfish.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_CAST.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES3.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_15.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_oaep.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_XOR.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
creating build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\common.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_HMAC.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD2.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD4.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD5.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_RIPEMD.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA224.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA256.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA384.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA512.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
creating build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_AllOrNothing.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_chaffing.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_KDF.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_rfc1751.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
creating build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_DSA.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_ElGamal.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_importKey.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_RSA.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
creating build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_random.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_rpoolcompat.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test__UserFriendlyRNG.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
creating build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaAccumulator.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaGenerator.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_SHAd256.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
creating build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_fallback.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_generic.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_nt.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_posix.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_winrandom.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
creating build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_asn1.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_Counter.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_number.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_winrandom.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
creating build\lib.win32-3.6\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_15.py -> build\lib.win32-3.6\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_pss.py -> build\lib.win32-3.6\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Signature
creating build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol\AllOrNothing.py -> build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol\Chaffing.py -> build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol\KDF.py -> build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol\__init__.py -> build\lib.win32-3.6\Crypto\Protocol
creating build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\DSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\ElGamal.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\pubkey.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\RSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\_DSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\_RSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\_slowmath.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\__init__.py -> build\lib.win32-3.6\Crypto\PublicKey
creating build\lib.win32-3.6\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_PSS.py -> build\lib.win32-3.6\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_v1_5.py -> build\lib.win32-3.6\Crypto\Signature
copying lib\Crypto\Signature\__init__.py -> build\lib.win32-3.6\Crypto\Signature
Skipping optional fixer: buffer
Skipping optional fixer: idioms
Skipping optional fixer: set_literal
Skipping optional fixer: ws_comma
running build_ext
warning: GMP or MPIR library not found; Not building Crypto.PublicKey._fastmath.
building 'Crypto.Random.OSRNG.winrandom' extension
creating build\temp.win32-3.6
creating build\temp.win32-3.6\Release
creating build\temp.win32-3.6\Release\src
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\BIN\cl.exe /c /nologo /Ox /W3 /GL /DNDEBUG /MD -Isrc/ -Isrc/inc-msvc/ -Ic:\users\peter\appdata\local\programs\python\python36-32\include -Ic:\users\peter\appdata\local\programs\python\python36-32\include "-IC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\shared" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\um" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\winrt" /Tcsrc/winrand.c /Fobuild\temp.win32-3.6\Release\src/winrand.obj
winrand.c
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(26): error C2061: syntax error: identifier 'intmax_t'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(27): error C2061: syntax error: identifier 'rem'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(27): error C2059: syntax error: ';'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(28): error C2059: syntax error: '}'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(30): error C2061: syntax error: identifier 'imaxdiv_t'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(30): error C2059: syntax error: ';'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(40): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(41): error C2146: syntax error: missing ')' before identifier '_Number'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(41): error C2061: syntax error: identifier '_Number'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(41): error C2059: syntax error: ';'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(42): error C2059: syntax error: ')'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(45): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2146: syntax error: missing ')' before identifier '_Numerator'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2061: syntax error: identifier '_Numerator'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2059: syntax error: ';'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2059: syntax error: ','
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(48): error C2059: syntax error: ')'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(50): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(56): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(63): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(69): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(76): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(82): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(89): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(95): error C2143: syntax error: missing '{' before '__cdecl'
error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\BIN\\cl.exe' failed with exit status 2
Command "c:\users\peter\appdata\local\programs\python\python36-32\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Users\\peter\\AppData\\Local\\Temp\\pip-build-2roclsga\\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\peter\AppData\Local\Temp\pip-79pbxumi-record\install-record.txt --single-version-externally-managed --compile" failed with error code 1 in C:\Users\peter\AppData\Local\Temp\pip-build-2roclsga\pycrypto\
"ERROR: broadlink installation error"
Drücken Sie eine beliebige Taste . . .
Posted: Sunday 04 February 2018 14:01
by zak45
@peterredl
I see you have python 3.6 : Python 3.6.4
Never has been able to have it running well...
If you do not depend of this version, I would recommend 3.5 x86.
Posted: Sunday 04 February 2018 22:47
by peterredl
Thanks, zak45.
I tried to use the version Python 3.5.4.
Now there is another mistake .....
Please help me again.
Here is the new error log.
"Broadlink RM2 python plugin install for Win"
Python 3.5.4
"Python version : " 35
Complete output from command c:\users\toshiba\appdata\local\programs\python\python35-32\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Users\\Toshiba\\AppData\\Local\\Temp\\pip-build-wlmt6a_i\\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\Toshiba\AppData\Local\Temp\pip-3uqwiou1-record\install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build\lib.win32-3.5
creating build\lib.win32-3.5\Crypto
copying lib\Crypto\pct_warnings.py -> build\lib.win32-3.5\Crypto
copying lib\Crypto\__init__.py -> build\lib.win32-3.5\Crypto
creating build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\hashalgo.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\HMAC.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD2.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD4.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD5.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\RIPEMD.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA224.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA256.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA384.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA512.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\__init__.py -> build\lib.win32-3.5\Crypto\Hash
creating build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\AES.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\ARC2.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\ARC4.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\blockalgo.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\Blowfish.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\CAST.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\DES.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\DES3.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_OAEP.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_v1_5.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\XOR.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\__init__.py -> build\lib.win32-3.5\Crypto\Cipher
creating build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\asn1.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\Counter.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\number.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\py3compat.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\randpool.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\RFC1751.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\winrandom.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\_number_new.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\__init__.py -> build\lib.win32-3.5\Crypto\Util
creating build\lib.win32-3.5\Crypto\Random
copying lib\Crypto\Random\random.py -> build\lib.win32-3.5\Crypto\Random
copying lib\Crypto\Random\_UserFriendlyRNG.py -> build\lib.win32-3.5\Crypto\Random
copying lib\Crypto\Random\__init__.py -> build\lib.win32-3.5\Crypto\Random
creating build\lib.win32-3.5\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaAccumulator.py -> build\lib.win32-3.5\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaGenerator.py -> build\lib.win32-3.5\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\SHAd256.py -> build\lib.win32-3.5\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\__init__.py -> build\lib.win32-3.5\Crypto\Random\Fortuna
creating build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\fallback.py -> build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\nt.py -> build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\posix.py -> build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\rng_base.py -> build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\__init__.py -> build\lib.win32-3.5\Crypto\Random\OSRNG
creating build\lib.win32-3.5\Crypto\SelfTest
copying lib\Crypto\SelfTest\st_common.py -> build\lib.win32-3.5\Crypto\SelfTest
copying lib\Crypto\SelfTest\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest
creating build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\common.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_AES.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC2.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC4.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_Blowfish.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_CAST.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES3.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_15.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_oaep.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_XOR.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
creating build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\common.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_HMAC.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD2.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD4.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD5.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_RIPEMD.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA224.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA256.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA384.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA512.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
creating build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_AllOrNothing.py -> build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_chaffing.py -> build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_KDF.py -> build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_rfc1751.py -> build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Protocol
creating build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_DSA.py -> build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_ElGamal.py -> build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_importKey.py -> build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_RSA.py -> build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\PublicKey
creating build\lib.win32-3.5\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_random.py -> build\lib.win32-3.5\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_rpoolcompat.py -> build\lib.win32-3.5\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test__UserFriendlyRNG.py -> build\lib.win32-3.5\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Random
creating build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaAccumulator.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaGenerator.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_SHAd256.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
creating build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_fallback.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_generic.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_nt.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_posix.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_winrandom.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
creating build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_asn1.py -> build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_Counter.py -> build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_number.py -> build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_winrandom.py -> build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Util
creating build\lib.win32-3.5\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_15.py -> build\lib.win32-3.5\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_pss.py -> build\lib.win32-3.5\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Signature
creating build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\AllOrNothing.py -> build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\Chaffing.py -> build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\KDF.py -> build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\__init__.py -> build\lib.win32-3.5\Crypto\Protocol
creating build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\DSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\ElGamal.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\pubkey.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\RSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_DSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_RSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_slowmath.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\__init__.py -> build\lib.win32-3.5\Crypto\PublicKey
creating build\lib.win32-3.5\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_PSS.py -> build\lib.win32-3.5\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_v1_5.py -> build\lib.win32-3.5\Crypto\Signature
copying lib\Crypto\Signature\__init__.py -> build\lib.win32-3.5\Crypto\Signature
running build_ext
creating build\temp.win32-3.5
creating build\temp.win32-3.5\Release
creating build\temp.win32-3.5\Release\src
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\BIN\cl.exe /c /nologo /Ox /W3 /GL /DNDEBUG /MD -Isrc/ -Isrc/inc-msvc/ -Ic:\users\toshiba\appdata\local\programs\python\python35-32\include -Ic:\users\toshiba\appdata\local\programs\python\python35-32\include "-IC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\shared" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\um" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\winrt" /Tcsrc/winrand.c /Fobuild\temp.win32-3.5\Release\src/winrand.obj
winrand.c
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\BIN\link.exe /nologo /INCREMENTAL:NO /LTCG /DLL /MANIFEST:EMBED,ID=2 /MANIFESTUAC:NO /LIBPATH:c:\users\toshiba\appdata\local\programs\python\python35-32\libs /LIBPATH:c:\users\toshiba\appdata\local\programs\python\python35-32\PCbuild\win32 "/LIBPATH:C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\LIB" "/LIBPATH:C:\Program Files (x86)\Windows Kits\10\lib\10.0.16299.0\ucrt\x86" "/LIBPATH:C:\Program Files (x86)\Windows Kits\10\lib\10.0.16299.0\um\x86" ws2_32.lib advapi32.lib /EXPORT:PyInit_winrandom build\temp.win32-3.5\Release\src/winrand.obj /OUT:build\lib.win32-3.5\Crypto\Random\OSRNG\winrandom.cp35-win32.pyd /IMPLIB:build\temp.win32-3.5\Release\src\winrandom.cp35-win32.lib
Creating library build\temp.win32-3.5\Release\src\winrandom.cp35-win32.lib and object build\temp.win32-3.5\Release\src\winrandom.cp35-win32.exp
Generating code
Finished generating code
LINK : fatal error LNK1158: cannot run 'rc.exe'
error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\BIN\\link.exe' failed with exit status 1158
Command "c:\users\toshiba\appdata\local\programs\python\python35-32\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Users\\Toshiba\\AppData\\Local\\Temp\\pip-build-wlmt6a_i\\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\Toshiba\AppData\Local\Temp\pip-3uqwiou1-record\install-record.txt --single-version-externally-managed --compile" failed with error code 1 in C:\Users\Toshiba\AppData\Local\Temp\pip-build-wlmt6a_i\pycrypto\
Posted: Monday 05 February 2018 13:10
by zak45
peterredl wrote: Sunday 04 February 2018 22:47
Thanks, zak45.
can you provide the output of:
pip --version
Posted: Monday 05 February 2018 14:23
by peterredl
Sorry, I do not know how to do it
Unfortunately, I'm not a programmer, I'm just a user. Everything I know, I only know from the domoticz wiki.
I try to connect to Broadlink based on this directive.
https://www.domoticz.com/wiki/Plugins/B ... dows_users
I think I've come a long way. See the picture. It was not a problem with the Xiaomi Gateway. But integrating Broadlink into Domoticz just does not work for me.
For further advice or instructions I would be very grateful.
[img]http://C:My Domoticz.png]
Posted: Monday 05 February 2018 17:29
by zak45
peterredl wrote: Monday 05 February 2018 14:23
No problem...
open a cmd prompt (start/execute/cmd)
type :
pip --version
Posted: Monday 05 February 2018 17:35
by peterredl
Got it.
Microsoft Windows [Version 10.0.16299.192]
(c) 2017 Microsoft Corporation. Alle Rechte vorbehalten.
C:\WINDOWS\system32>pip --version
pip 9.0.1 from c:\users\toshiba\appdata\local\programs\python\python35-32\lib\site-packages (python 3.5)
Posted: Monday 05 February 2018 17:51
by zak45
ok, you need to install python x86, just forget x64...
during installation, you need also to say that you want it for all users & include into path...
If you search on the forum, you will be able to find even some screenshot.
this is my output :
C:\Users\Z>pip --version
pip 9.0.1 from c:\program files (x86)\python35-32\lib\site-packages (python 3.5)
Posted: Monday 05 February 2018 20:16
by Kruu
I just can manage to get my Bean mini to work with domoticz, always this message.
2018-02-05 20:12:19.720 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/domoticz/domoticz/plugins/BroadlinkRM2/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-02-05 20:12:19.720 Error: (Bean) Module Import failed, exception: 'ImportError'
2018-02-05 20:12:19.720 Error: (Bean) Module Import failed: ' Name: pyaes'
2018-02-05 20:13:30.240 Error: Bean hardware (24) thread seems to have ended unexpectedly
2018-02-05 20:14:00.247 Error: Bean hardware (24) thread seems to have ended unexpectedly
2018-02-05 20:14:30.254 Error: Bean hardware (24) thread seems to have ended unexpectedly
2018-02-05 20:14:56.556 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/domoticz/domoticz/plugins/BroadlinkRM2/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-02-05 20:14:56.556 Error: (Bean) Module Import failed, exception: 'ImportError'
2018-02-05 20:14:56.556 Error: (Bean) Module Import failed: ' Name: pyaes'
Posted: Monday 05 February 2018 20:43
by zak45
Kruu wrote: Monday 05 February 2018 20:16
Do you have installed pyaes ?
try:
sudo pip3 install pyaes
Posted: Monday 05 February 2018 21:03
by Kruu
HM, dont know why I have missed that, but now I get error
2018-02-05 21:14:36.391 Error: (bean) check power error
2018-02-05 21:15:15.849 Error: (bean) Error getting temperature data from Broadlink device....Timeout
2018-02-05 21:15:15.850 Error: (bean) Error Connecting to Broadlink device....127.0.0.1
2018-02-05 21:16:06.270 Error: (bean) check power error
2018-02-05 21:16:57.488 Error: (bean) check power error
2018-02-05 21:18:30.732 Error: (bean2) check power error
2018-02-05 21:20:10.270 Error: (bean2) Error getting temperature data from Broadlink device....Timeout
2018-02-05 21:20:10.270 Error: (bean2) Error Connecting to Broadlink device....192.168.1.196
2018-02-05 21:23:29.605 Error: (bean2) check power error
2018-02-05 21:23:48.453 Error: (bean2) check power error
2018-02-05 21:25:28.010 Error: (bean2) Error getting temperature data from Broadlink device....Timeout
2018-02-05 21:25:28.010 Error: (bean2) Error Connecting to Broadlink device....192.168.1.196
2018-02-05 21:23:29.296 (bean2) Exiting work loop...
2018-02-05 21:23:29.296 (bean2) Stopped.
2018-02-05 21:23:29.602 (bean2) Initialized version 4.0.0, author 'zak45'
2018-02-05 21:23:48.104 (bean2) Exiting work loop...
2018-02-05 21:23:48.105 (bean2) Stopped.
2018-02-05 21:23:48.450 (bean2) Initialized version 4.0.0, author 'zak45'
And under hardware type it shows me 2 same Broadlink RM2 with KODI Remote
Posted: Monday 05 February 2018 23:19
by peterredl
zak45 wrote: Monday 05 February 2018 17:51
this is my output :
[/quote
Now i have the same version as you....
C:\Users\Toshiba>pip --version
C:\Users\Toshiba>
But the installation continued to fail...
running build_ext
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\BIN\cl.exe /c /nologo /Ox /W3 /GL /DNDEBUG /MD -Isrc/ -Isrc/inc-msvc/ "-Ic:\program files (x86)\python35-32\include" "-Ic:\program files (x86)\python35-32\include" "-IC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\shared" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\um" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\winrt" /Tcsrc/winrand.c /Fobuild\temp.win32-3.5\Release\src/winrand.obj
winrand.c
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\BIN\link.exe /nologo /INCREMENTAL:NO /LTCG /DLL /MANIFEST:EMBED,ID=2 /MANIFESTUAC:NO "/LIBPATH:c:\program files (x86)\python35-32\libs" "/LIBPATH:c:\program files (x86)\python35-32\PCbuild\win32" "/LIBPATH:C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\LIB" "/LIBPATH:C:\Program Files (x86)\Windows Kits\10\lib\10.0.16299.0\ucrt\x86" "/LIBPATH:C:\Program Files (x86)\Windows Kits\10\lib\10.0.16299.0\um\x86" ws2_32.lib advapi32.lib /EXPORT:PyInit_winrandom build\temp.win32-3.5\Release\src/winrand.obj /OUT:build\lib.win32-3.5\Crypto\Random\OSRNG\winrandom.cp35-win32.pyd /IMPLIB:build\temp.win32-3.5\Release\src\winrandom.cp35-win32.lib
Generating code
Command ""c:\program files (x86)\python35-32\python.exe" -u -c "import setuptools, tokenize;__file__='C:\\Users\\Toshiba\\AppData\\Local\\Temp\\pip-build-mhsnv81k\\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\Toshiba\AppData\Local\Temp\pip-6kcmw4p5-record\install-record.txt --single-version-externally-managed --compile" failed with error code 1 in C:\Users\Toshiba\AppData\Local\Temp\pip-build-mhsnv81k\pycrypto\
Posted: Tuesday 06 February 2018 15:51
by zak45
@peterredl
Download pycrypto-2.6.1-cp35-none-win32.whl from dropbox and install it manually
open cmd with admin right
go to the folder where pycrypto-2.6.1-cp35-none-win32.whl is located and type:
pip install pycrypto-2.6.1-cp35-none-win32.whl
Posted: Tuesday 06 February 2018 17:01
by zak45
@Kruu
do you have selected the right device type ??
- Capture.JPG (34.09 KiB) Viewed 5463 times
