Re: Plugins are disabled?
Posted: Tuesday 16 January 2018 13:27
I'm on Stretch. Just updated to 8809.
Python plugins crash immediately
libpython-dev/stable,now 2.7.13-2 armhf [installed,automatic]
libpython-stdlib/stable,now 2.7.13-2 armhf [installed,automatic]
libpython2.7/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython2.7-dev/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython2.7-minimal/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython2.7-stdlib/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython3.4/stable,now 3.4.4-3 armhf [installed,automatic]
libpython3.4-dbg/stable,now 3.4.4-3 armhf [installed]
libpython3.4-dev/stable,now 3.4.4-3 armhf [installed,automatic]
libpython3.4-minimal/stable,now 3.4.4-3 armhf [installed,automatic]
libpython3.4-stdlib/stable,now 3.4.4-3 armhf [installed]
python/stable,now 2.7.13-2 armhf [installed]
python-apt/stable,now 1.1.0~beta5 armhf [installed]
python-apt-common/stable,now 1.1.0~beta5 all [installed]
python-bluez/stable,now 0.22-1 armhf [installed]
python-cffi-backend/stable,now 1.9.1-2 armhf [installed,automatic]
python-chardet/stable,now 2.3.0-2 all [installed]
python-colorama/stable,now 0.3.7-1 all [installed]
python-cryptography/stable,now 1.7.1-3+b2 armhf [installed,automatic]
python-dev/stable,now 2.7.13-2 armhf [installed]
python-distlib/stable,now 0.2.4-1 all [installed]
python-enum34/stable,now 1.1.6-1 all [installed,automatic]
python-html5lib/stable,now 0.999999999-1 all [installed]
python-idna/stable,now 2.2-1 all [installed,automatic]
python-ipaddress/stable,now 1.0.17-1 all [installed,automatic]
python-minimal/stable,now 2.7.13-2 armhf [installed,automatic]
python-openssl/stable,now 16.2.0-1 all [installed,automatic]
python-pkg-resources/stable,now 33.1.1-1 all [installed,automatic]
python-pyasn1/stable,now 0.1.9-2 all [installed,automatic]
python-requests/stable,now 2.12.4-1 all [installed]
python-rpi.gpio/stable,now 0.6.3~stretch-1 armhf [installed]
python-setuptools/stable,now 33.1.1-1 all [installed,automatic]
python-six/stable,now 1.10.0-3 all [installed,automatic]
python-urllib3/stable,now 1.19.1-1 all [installed,automatic]
python-webencodings/stable,now 0.5-2 all [installed,automatic]
python2.7-dev/stable,now 2.7.13-2+deb9u2 armhf [installed]
python3.4/stable,now 3.4.4-3 armhf [installed]
python3.4-dev/stable,now 3.4.4-3 armhf [installed]
Quax1507 wrote: Tuesday 16 January 2018 14:13 Success!
Removed python3.5* and libpython3.5*
At least no immediate crash after startup!!!![]()
sudo apt-get remove python3.5
sudo apt-get remove python3.5-minimal
sudo apt-get remove libpython3.5
sudo apt-get remove libpython3.5-minimalOK, thanks for the clarification. Too bad, it seemed like a credible hypothesisDnpwwo wrote: Thursday 18 January 2018 12:57 The plugin framework does seem way more stable on RPi for people who build from source but not for the reason you think. Domoticz does not link to Python during the build, it links to it at runtime to allow people without Python on their system to still run Domoticz.
2018-01-18 14:28:41.975 RxQueue: queue worker started...
2018-01-18 14:28:43.976 Hardware Monitor: Started
2018-01-18 14:28:43.997 Wunderground: Worker started...
2018-01-18 14:28:43.998 Kodi: Started
2018-01-18 14:28:43.998 DarkSky: Started...
2018-01-18 14:28:43.998 (Sonos) Started.
2018-01-18 14:28:43.999 (Wintergarten) Started.
2018-01-18 14:28:44.000 EventSystem: reset all events...
2018-01-18 14:28:44.005 EventSystem: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Check_Battery_Levels.lua
2018-01-18 14:28:44.019 EventSystem: reset all device statuses...
2018-01-18 14:28:44.100 Kodi: (Wohnzimmer) Starting thread.
2018-01-18 14:28:44.168 PluginSystem: Entering work loop.
2018-01-18 14:28:44.201 Kodi: Starting I/O service thread.
2018-01-18 14:28:44.543 Error: Domoticz received fatal signal 11 !...
2018-01-18 14:28:44.546 Error: /home/pi/domoticz/domoticz() [0x23753c]
2018-01-18 14:28:44.546 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x2375f4]
2018-01-18 14:28:44.546 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76bef6b0]
I just wonder then why i still run Jessie and plugins enabled and running fine.Dnpwwo wrote: Thursday 18 January 2018 12:57 @domoticzag,
Switching to Jessie won't make a difference.
This also worked for me !olicot wrote: Friday 26 January 2018 20:56 Hello
Same issue avec some latest beta...
not only python plugins, but all EventSystem (Lua/Blockly/Scripts).
So to enable :
go to : settings/others and enable ! EventSystem (Lua/Blockly/Scripts):
Domoticz should be restarted
and python plugins are back
It works for me
Hope this help
Same here for me, on Stretch it was impossible for me to run the beta with python plugins, i get segmentation fault direct when try to start domoticz or when i activate the plugin when domoticz is running.Siewert308SW wrote: Friday 26 January 2018 21:37I just wonder then why i still run Jessie and plugins enabled and running fine.Dnpwwo wrote: Thursday 18 January 2018 12:57 @domoticzag,
No matter what Domo build i use, Pre compiled binary or manually compiled on RPi3 with jessie and Python3.4 / libpython3.4 no issues.
If i upgrade to 3.5 or try the same on Stretch the entire system gets unstable and eventually ending in a Segmentation fault.
Something isn't right here.
Or you do or amend something so it runs where we have issues.
Or something is missing from our normal installation, my 2 cents![]()
