A little Small Lua Telegram Library
emme
Domoticz version: latest
Re: A little Small Lua Telegram Library
Post by emme »
WOW!!! this is awesome!!!
And probably will fix my connection problem I do have (fix date for my internet connection is March 29th.... :evil: :evil: :evil: :evil: )
I'm actually running a 3G (10Mbit) connection and my domoticz system is under pressure for a lot of queued messages and external connection.
I'll try this immediately and see if this solve that issue!!!
Ciao
M
"We always done this way"
emme
Post by emme »
Created page on the Wiki about the library
snuiter
Post by snuiter »
Hi Emme,
you need to rename the page so it is easer to find ;)
Telegra lua library
The M is missing, I guess I will never forget your forum name now ;)
emme
Post by emme »
:o :o :o :o :o :o :o
I'm totally unfamiliar with mediawiki.....
And with the alphabet :D :D
zicht
Domoticz version: 2023.1+
Post by zicht »
Found the wiki, nice job.
ps
If you update it with the simple addons i posted a couple of messages back you make sure it does not slow down domoticz when the network is lagging
freijn
Domoticz version: Stable
Post by freijn »
Guys,
Can you please help me ?
I have copied the library Telegram.lua and put it in /home/pi/domoticz/scripts/lua.
but now... where do I put this code ? :
package.path = package.path .. ';' .. '/home/pi/domoticz/scripts/lua/?.lua'
local telegram = require('Telegram')
and would just like to exe
telegram.sendText(123456789,'Hallo World!')
many thanks for your time ,
Frank
emme
Post by emme »
freijn wrote: Tuesday 30 April 2019 22:06 but now... where do I put this code ? :
put the
on top of your script where you want to send the
that's all
riko
Post by riko »
Cool script, exactly what I was looking for. I only have one question left:
Can I send the message to multiple IDs in one line?
telegram.sendText(telegram.getId('rik'), 'This is a *TEST* Message')
I have tried:
telegram.sendText(telegram.getId('rik', 'name2'), 'This is a *TEST* Message')
Which is not working. Or is the only method to copy the telegram send line each time?
emme
Post by emme »
You have ti duplicate the line at the Moment
I moved back to domoticz After a while into another system
I could have a look into it and duplicate It
Ciao
M
riko
Post by riko »
emme wrote: Monday 21 September 2020 21:28 You have ti duplicate the line at the Moment
Ciao
M
Thanks for your quick reply. I'll duplicate the lines for now. Please let me know when you have found another solution!
Xenomes
Domoticz version: 2025.1
Post by Xenomes »
emme wrote: Monday 08 January 2018 21:46 added function to send docs and a chatid addressbook to fast references in your code
I have add sendvideo support to your script and embedded the addressbook function.
local teleTok   = 'Enter your Bot Token here'
local snapFile  = '/home/pi/domoticzSnap'
local snapVideo = '/var/tmp/video.mp4'
local domoReq   = 'http://localhost:8080/camsnapshot.jpg'
local tgAb = {}
tgAb['myName1'] = 222222222
tgAb['myName2'] = 111111111
tgAb['myGroup'] = -00000000
local cameraUri = {}
cameraUri['cam1'] = 'rtsp://user:password@ip-cam/channel'
cameraUri['cam2'] = 'rtsp://admin:[email protected]/12'
cameraUri['cam3'] = 'rtsp://admin:[email protected]/1'
local telegram ={};
    function getId(name)
        return tgAb[name]
    function getCam(num)
        return cameraUri[num]
	-- example: telegram.sendText('myName1', 'Test message')
    function telegram.sendText(chatId, message)
        return os.execute('curl --data chat_id='..getId(chatId)..' --data parse_mode=Markdown --data-urlencode "text='..message..'"  "https://api.telegram.org/bot'..teleTok..'/sendMessage" ')
	-- example: telegram.sendImage('myName1', 1, 'Test message')
    function telegram.sendImage(chatId, camChannel, message)
        os.execute('wget -O "'..snapFile..camChannel..'.jpg" "'..domoReq..'?idx='..camChannel..'"')
        return os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendPhoto?chat_id='..getId(chatId)..'" -F photo="@'..snapFile..camChannel..'.jpg" -F caption="'..message..'"')
	-- example: telegram.sendDoc('myName1', '/home/pi/file.pdf', 'Test message')
    function telegram.sendDoc(chatId, filePath, message)
        return os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendDocument?chat_id='..getId(chatId)..'" -F document="@'..filePath..'" -F caption="'..message..'"')
	-- example: telegram.sendVideo('myName1', 'cam1', 10, 'Test message')
    function telegram.sendVideo(chatId, cameraNum, recTime, message)
        os.execute('ffmpeg -y -i "'..getCam(cameraNum)..'" -r 30 -vcodec copy -an -t '..recTime..' "'..snapVideo..'"')
        return os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendVideo?chat_id='..getId(chatId)..'" -F video="@'..snapVideo..'" -F caption="'..message..'"')
return telegram
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.2 LTS (64Bit) - Domoticz 2025.1 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
emme
Post by emme »
that's great!!!
thenk you
cimbali
Post by cimbali »
Very good library. This inspired to me to make it one similar for sending message & pictures to Pushbullet.
One downside of a pure-Lua approach for this problem is that it makes the dzVent event handling loop busy for a few seconds, the time it takes to capture the picture from the camera and call the APIs on Pushbullet backend.
As far as I understand the event handling loop will be unable to handle any other events in those few seconds, and you may see the following messages in the domoticz log that warn you about that.
    dzVents: !Info: ------ Finished myscript.lua after >9 seconds. (using 0.871 seconds CPU time !)
To fix this I have decided to still use the library, but spawn a separate Lua process like this:
os.execute('cd /home/pi/domoticz/scripts/dzVents/scripts/modules/ ; /usr/bin/lua tgsendpic.lua ' .. '"' .. cameraId .. '"' .. ' "' .. message .. '" &')
