A little Small Lua Telegram Library
- emme
- Domoticz version: latest
Re: A little Small Lua Telegram Library
WOW!!! this is awesome!!!
And probably will fix my connection problem I do have (fix date for my internet connection is March 29th.... )
I'm actually running a 3G (10Mbit) connection and my domoticz system is under pressure for a lot of queued messages and external connection.
I'll try this immediately and see if this solve that issue!!!
Ciao
M
Ciao
M
"We always done this way"
- emme
Created page on the Wiki about the library
Hi Emme,
you need to rename the page so it is easer to find
Telegra lua library
The M is missing, I guess I will never forget your forum name now
Telegra lua library
- emme
I'm totally unfamiliar with mediawiki.....
And with the alphabet
- Domoticz version: 2023.1+
Found the wiki, nice job.
ps
If you update it with the simple addons i posted a couple of messages back you make sure it does not slow down domoticz when the network is lagging
ps
- Domoticz version: Stable
Guys,
Can you please help me ?
I have copied the library Telegram.lua and put it in /home/pi/domoticz/scripts/lua.
but now... where do I put this code ? :
package.path = package.path .. ';' .. '/home/pi/domoticz/scripts/lua/?.lua'
local telegram = require('Telegram')
and would just like to exe
telegram.sendText(123456789,'Hallo World!')
many thanks for your time ,
Frank
Frank
- emme
put the
on top of your script where you want to send the
Cool script, exactly what I was looking for. I only have one question left:
Can I send the message to multiple IDs in one line?
I have tried:
Which is not working. Or is the only method to copy the telegram send line each time?
telegram.sendText(telegram.getId('rik'), 'This is a *TEST* Message')
telegram.sendText(telegram.getId('rik', 'name2'), 'This is a *TEST* Message')
- emme
You have ti duplicate the line at the Moment
I moved back to domoticz After a while into another system
I could have a look into it and duplicate It
Ciao
M
Ciao
M
Thanks for your quick reply. I'll duplicate the lines for now. Please let me know when you have found another solution!
- Xenomes
- Domoticz version: 2024.7
I have add sendvideo support to your script and embedded the addressbook function.
local teleTok = 'Enter your Bot Token here'
local snapFile = '/home/pi/domoticzSnap'
local snapVideo = '/var/tmp/video.mp4'
local domoReq = 'http://localhost:8080/camsnapshot.jpg'
local tgAb = {}
tgAb['myName1'] = 222222222
tgAb['myName2'] = 111111111
tgAb['myGroup'] = -00000000
local cameraUri = {}
cameraUri['cam1'] = 'rtsp://user:password@ip-cam/channel'
cameraUri['cam2'] = 'rtsp://admin:[email protected]/12'
cameraUri['cam3'] = 'rtsp://admin:[email protected]/1'
local telegram ={};
function getId(name)
return tgAb[name]
function getCam(num)
return cameraUri[num]
-- example: telegram.sendText('myName1', 'Test message')
function telegram.sendText(chatId, message)
return os.execute('curl --data chat_id='..getId(chatId)..' --data parse_mode=Markdown --data-urlencode "text='..message..'" "https://api.telegram.org/bot'..teleTok..'/sendMessage" ')
-- example: telegram.sendImage('myName1', 1, 'Test message')
function telegram.sendImage(chatId, camChannel, message)
os.execute('wget -O "'..snapFile..camChannel..'.jpg" "'..domoReq..'?idx='..camChannel..'"')
return os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendPhoto?chat_id='..getId(chatId)..'" -F photo="@'..snapFile..camChannel..'.jpg" -F caption="'..message..'"')
-- example: telegram.sendDoc('myName1', '/home/pi/file.pdf', 'Test message')
function telegram.sendDoc(chatId, filePath, message)
return os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendDocument?chat_id='..getId(chatId)..'" -F document="@'..filePath..'" -F caption="'..message..'"')
-- example: telegram.sendVideo('myName1', 'cam1', 10, 'Test message')
function telegram.sendVideo(chatId, cameraNum, recTime, message)
os.execute('ffmpeg -y -i "'..getCam(cameraNum)..'" -r 30 -vcodec copy -an -t '..recTime..' "'..snapVideo..'"')
return os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendVideo?chat_id='..getId(chatId)..'" -F video="@'..snapVideo..'" -F caption="'..message..'"')
return telegram
HP T630 (32GB SSD/8GB Mem) - Ubuntu 22.04.4 LTS (64Bit) - Domoticz 2024.7 with Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
- emme
that's great!!!
thenk you
thenk you
Very good library. This inspired to me to make it one similar for sending message & pictures to Pushbullet.
One downside of a pure-Lua approach for this problem is that it makes the dzVent event handling loop busy for a few seconds, the time it takes to capture the picture from the camera and call the APIs on Pushbullet backend.
As far as I understand the event handling loop will be unable to handle any other events in those few seconds, and you may see the following messages in the domoticz log that warn you about that.
To fix this I have decided to still use the library, but spawn a separate Lua process like this:
dzVents: !Info: ------ Finished myscript.lua after >9 seconds. (using 0.871 seconds CPU time !)
os.execute('cd /home/pi/domoticz/scripts/dzVents/scripts/modules/ ; /usr/bin/lua tgsendpic.lua ' .. '"' .. cameraId .. '"' .. ' "' .. message .. '" &')
