Page 2 of 2
Re: Python Plugin Domoticz-Enigma2
Posted: Sunday 02 December 2018 0:24
by djksage
NoProfesor wrote: Monday 26 November 2018 22:49
is in pathOfPackages = '/home/pi/.local/lib/python3.5/site-packages'
what is wrong?
LOG:
2018-11-26 22:37:39.662 Error: (Enigma2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Enigma2/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-11-26 22:37:39.662 Error: (VUplus) Module Import failed, exception: 'ImportError'
2018-11-26 22:37:39.662 Error: (VUplus) Module Import failed: ' Name: xmltodict'
2018-11-26 22:37:39.662 Error: (VUplus) Error Line details not available.
2018-11-26 22:38:40.667 Error: (Enigma2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Enigma2/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-11-26 22:38:40.667 Error: (VUplus) Module Import failed, exception: 'ImportError'
2018-11-26 22:38:40.667 Error: (VUplus) Module Import failed: ' Name: xmltodict'
2018-11-26 22:38:40.667 Error: (VUplus) Error Line details not available.
2018-11-26 22:40:01.038 Error: VUplus hardware (8) thread seems to have ended unexpectedly
2018-11-26 22:40:30.043 Error: VUplus hardware (8) thread seems to have ended unexpectedly
Hello, i have exactly same problem
2018-12-02 00:08:13.209 Error: (Enigma2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Enigma2/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-12-02 00:08:13.209 Error: (VU+ Salon) Module Import failed, exception: 'ImportError'
2018-12-02 00:08:13.209 Error: (VU+ Salon) Module Import failed: ' Name: xmltodict'
2018-12-02 00:08:13.209 Error: (VU+ Salon) Error Line details not available.
do you find a solution?
thanks
Posted: Sunday 09 December 2018 14:20
by NoProfesor
Plugin is not working,
I have simple script for checking engma2 status
#!/bin/bash
curl http://192.168.0.xxe/web/powerstate > /home/pi/domoticz/scripts/enigma2/powerstate_enigma2_living3.xml
enigma2LivingStatus=`xmlstarlet sel -t -m '//e2instandby' -v . -n </home/pi/domoticz/scripts/enigma2/powerstate_enigma2_living3.xml`
if [ $enigma2LivingStatus = "true" ]
then
curl 'http://192.168.0.xxr:8080/json.htm?type=command¶m=switchlight&idx=13&switchcmd=Off'
echo "$enigma2LivingStatus"
echo enigma2 Living is in standby
elif [ $enigma2LivingStatus = "false" ]
then
curl 'http://192.168.0.xxr:8080/json.htm?type=command¶m=switchlight&idx=13&switchcmd=On'
echo enigma2 Living is not in standby
echo enigma2 Living not found
fi
and file
<?xml version="1.0" encoding="UTF-8"?>
<e2powerstate>
<e2instandby>
true </e2instandby>
</e2powerstate>
Does anyone know how to run this script in domoticz to check status for 10 seconds?
Posted: Thursday 21 February 2019 9:11
by keson
I have latest beta version 4.10427, installed python 3.4 (using it for Yamaha AVR) and it all seems to work.
I have installed the enigma2 plugin and needed to install the pip3 and xmltodict python package, all seemed to go OK.
Restarting the Domoticz I can select and add the new Hardware.
However here it ends. No new device is added and after restarting Domoticz a complete crash happens. USB GW stops working, Yamaha Receiver stops working, Enigma stops working and the whole domoticz go to offline completely. Until I remove the enigma plugin from plugins folder.
Seems to be a complete fail.
Has anybody the enigma plugin working? It would be highly appreciated as it is the last bit of my home entertainment HW I am unable to control from Domoticz (thus unable to integrate into automation).
Thanks anyone for some helpful feedback
Posted: Thursday 21 February 2019 14:39
by kofec
Try now - I have updated the repository. Turn on debug
Posted: Saturday 23 February 2019 9:16
by brbr
I have this error on my RPI3:
2019-02-23 09:12:07.441 Error: (Enigma2) failed to load 'plugin.py', Python Path used was ':/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2019-02-23 09:12:07.441 Error: (E2) Module Import failed, exception: 'ImportError'
2019-02-23 09:12:07.441 Error: (E2) Module Import failed: ' Name: plugin'
2019-02-23 09:12:07.441 Error: (E2) Error Line details not available.
Posted: Saturday 23 February 2019 9:25
by kofec
Please update to latest version. And install missing module
Posted: Saturday 23 February 2019 10:50
by brbr
same error.
2019-02-23 10:49:39.732 Error: (Enigma2) failed to load 'plugin.py', Python Path used was ':/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2019-02-23 10:49:39.732 Error: (E2) Module Import failed, exception: 'ImportError'
2019-02-23 10:49:39.732 Error: (E2) Module Import failed: ' Name: plugin'
Posted: Saturday 23 February 2019 13:12
by kofec
Is the script "enigma2.sh" working?
Posted: Saturday 23 February 2019 16:51
by brbr
enigma2.py yes it works.
Wait 5 seconds
Standby:
Connect via wget to website: wget -q -O -
http://192.168.1.6/web/powerstate?newstate=5
b'<?xml version="1.0" encoding="UTF-8"?>\n<e2powerstate>\n\t<e2instandby>true</e2instandby>\n</e2powerstate>\n'
OrderedDict([('e2powerstate', OrderedDict([('e2instandby', 'true')]))])
Posted: Saturday 23 February 2019 16:53
by brbr
plugin.py same error
2019-02-23 16:52:14.970 Error: (Enigma2) failed to load 'plugin.py', Python Path used was ':/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2019-02-23 16:52:14.970 Error: (ee) Module Import failed, exception: 'ImportError'
2019-02-23 16:52:14.970 Error: (ee) Module Import failed: ' Name: plugin'
Posted: Saturday 23 February 2019 17:42
by kofec
find location of "xmltodict" and add/correct this path in plugin.py
pathOfPackages = '/usr/lib/python3.4/site-packages/' <- correct this
by NoProfesor
brbr wrote:plugin.py same error
Check where the packages are installed with
$ python3 -m site
