Page 2 of 2
Re: Dashticz - Save option
Posted: Tuesday 06 March 2018 21:41
by marktn
Still not working, the same error.
Posted: Thursday 26 April 2018 21:06
by marktn
I have just made a update to a last version, but the websettings still do not save.
Posted: Sunday 23 December 2018 22:32
by ESFnl
Any news on this? I did chmod 777 the config file but still cannot save anything.
Posted: Wednesday 16 January 2019 8:00
by Lokonli
Maybe you are using it already, but I would advise to use the latest beta version of Dashticz.
First check whether Dashticz indeed finds PHP support: (only works on beta...)
If you press the settings-button (upper right) and then the 'Info' tab, Dashticz should report the PHP version that is being used.
If no PHP version is reported then first you have to fix the PHP installation. See the Wiki for some info:
https://www.domoticz.com/wiki/Dashticz_ ... structions
(don't forget to install the php-xml and php-curl modules)
In case the PHP version is reported correctly already, then try to save the settings. If this still doesn't work, look in the Apache error log.
(I assume you are running the Apache web server). Normally the location is /var/log/apache2/error.log
