Dashticz - Save option
Markgo88
Post by Markgo88 »
Hello All,
For a few weeks now i'm running domoticz on a rpi3.
I would like to place a screen with dashticz, but running into one problem.
When i try to save ( from webpage ) it doesn't do anything.
also tried chmod 777 CONFIG.js but no difference.
Anybody with a solution?
Zolka1984
Re: Dashticz - Save option
Post by Zolka1984 »
Same proble here. I have not find a way to save changes. I have also test the beta version with the same result.
htilburgs
Post by htilburgs »
The save option needs PHP running on your pi.
You’ve to install PHP, or change the config.JS manualy. See the wiki for how-to.
Hardware:
EdwinK
Post by EdwinK »
I've PHP working on my server the save button doesnt save anything Tried with both php5.6 and php7.0 are installed, using apache server 2.4
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
with 'no save button', you dont actually mean that right? Cause the save button is always there (bottom right in the settings popup, the green button).
EdwinK
Post by EdwinK »
Sorry, blaming it on getting the cold (or the drinks). There is a save button, but it doesn't save anything.
After hitting 'opslaan/save' there are no changes.
JeBlice
Domoticz version: 3.8153
Post by JeBlice »
When in edit mode, save button (red button in bottom right corner) does not save changes
thesystem
Post by thesystem »
I've got the same issue. I've tried with the latest stable and beta release.
Settings set in the webinterface via the Gear icon are not saved. After a refresh of the page, the filled in and changed values have been reset.
gjaa
Post by gjaa »
I've started from scratch and have the same problem
cdegroote
Post by cdegroote »
Same here. On both beta and stable dashticz. Running php7 ok
EdwinK
Post by EdwinK »
Take a look art your config.js. I found that it did save the settings, before the older settings, so all your new settings are overruled by the older ones.
cdegroote
Post by cdegroote »
Remove / and * at beginning and end of CONFIG.js and everything works normal
gjaa
Post by gjaa »
cdegroote wrote: Saturday 06 January 2018 19:55 Remove / and * at beginning and end of CONFIG.js and everything works normal
I get the latest version (Beta)
cp CONFIG_DEFAULT.js CONFIG.js
edit my IP
Saved
Start Dashticz and I can save but it does not change the CONFIG.js
When I remove the suggested lines I've got an error
So thats not the solution
andnyg
Domoticz version: 3.8389
Post by andnyg »
I got the same problem with not saving when pressing the save button in lower right corner when in Edit Mode.
All changes that are done in the setting popup is saved, and hence changed in the CONFIG.js file.
When having mouse over the save button Chrome says "javascript:void(0)
Running PHP5 on Apache server (in my case /var/www/dashticz-V2)
Any suggestions? :geek: :?:
marktn
Post by marktn »
Same problem here. Is there a solution?
I can't use the save button!
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
DewGew
Domoticz version: V4.10618
Post by DewGew »
andnyg wrote: Wednesday 10 January 2018 21:54 I got the same problem with not saving when pressing the save button in lower right corner when in Edit Mode.
marktn wrote: Tuesday 20 February 2018 21:23 Same problem here. Is there a solution?
Did you change write permisson on CONFIG.js? (chmod 777)
marktn
Post by marktn »
Thanks for helping!
Yes i did it with sudo chmod 777 * in the custom map.
In my browser i see this when pressing F12:
:8080/dashticz_v2/js/savesettings.php Failed to load resource: the server
responded with a status of 501 (Not Implemented)
DewGew
Post by DewGew »
marktn wrote: Wednesday 21 February 2018 21:14
Thanks for helping!
PHP is not enabled. Check your setting for PHP, Domoticz webserver cannot run php-script for webpages. Only php-scripts for domoticz event system.
marktn
Post by marktn »
DewGew wrote: Monday 26 February 2018 8:10
Thanks for helping!
Is there a wiki for it? I tried several website's, but no succes.
DewGew
Post by DewGew »
marktn wrote: Monday 26 February 2018 20:58
Thanks for helping!
https://www.raspberrypi.org/documentati ... /apache.md
https://www.raspberrypi.org/documentati ... r/nginx.md
