Python Plugin: Network Pinger (Native ICMP) Topic is solved
gerardwr
Re: Python Plugin: Network Pinger (Native ICMP)
Post by gerardwr »
Dnpwwo wrote: Tuesday 14 November 2017 22:18 @gerardwr,
You can change the name of the device in Domoticz to anything you want using the normal "Edit" button in the "Switches" tab. The plugin sets a default name but does not rely on it remaining the same.
Yes I understand.
But suppose I would like to Ping 20 devices, you would have to edit the names of these devices individually. Defining the relation between name and IP in 1 place sounded appealing to me.
Dnpwwo
Post by Dnpwwo »
November 29th, 2017, version 3.0.1:
  • Devices are created in Domoticz the first time the plugin runs, one to show if the device is found and one to show the response time.
  • Devices that are not found are optionally shown with a red banner in the devices tab (if configured to do so)
  • New version handles DNS names where the IP addresses changes (e.g www.google.com) without creating new devices in Domoticz
Users of the previous version should 'Delete' then 'Add' the plugin via the Hardware page.
Requires recent beta for the response time devices to be updated.
gerardwr
Post by gerardwr »
Dnpwwo wrote: Wednesday 29 November 2017 12:49 November 29th, 2017, version 3.0.1:
Just installed the updated plugin, works excellent!
Defined 3 addresses to ping in setting up, and for every address a "switch" and a "utility" is created automagically.
Schermafbeelding 2017-11-29 om 15.37.52.png (58.08 KiB) Viewed 4854 times
Schermafbeelding 2017-11-29 om 15.38.08.png (46.96 KiB) Viewed 4854 times
For each "utility" sensor a graph is made by Domoticz, picture below after 6+ hours.
Schermafbeelding 2017-11-29 om 22.25.10.png (118.68 KiB) Viewed 4844 times
Just as I wanted, well done, I'm happy :-)
schulpr
Post by schulpr »
I'm getting errors on the last version (3.01):
2017-12-01 12:18:17.675 Error: (Pinger) 'onHeartbeat' failed 'IndexError':'list index out of range'.
2017-12-01 12:18:17.675 Error: (Pinger) ----> Line 181 in /home/pi/domoticz/plugins/pinger/plugin.py, function onHeartbeat
2017-12-01 12:18:17.675 Error: (Pinger) ----> Line 157 in /home/pi/domoticz/plugins/pinger/plugin.py, function onHeartbeat
Any idea what could be wrong?
Regards, Rob
Dnpwwo
Post by Dnpwwo »
@schulpr,
Yes I do have an idea. I have been testing the plugin with multiple addresses lately and broke it for when only a single address is specified (which I'm guessing you have) :oops:
I've pushed an update to the Pinger example. Version 3.0.3 is here: https://github.com/domoticz/domoticz/bl ... /Pinger.py
schulpr
Post by schulpr »
Hi Dnpwwo,
Thank you for the update, the script does work now but I still get an (different) error:
" 2017-12-02 08:27:45.743 Error: (Pinger) Transport not initialized, write directive to '192.168.2.12' ignored. Connectionless transport should be Listening."
I was indeed testing with only one IP-address. I'm trying different plugins to see which one of them fits best for my needs. I like this one because it's easy to install en managed within Domoticz. There is another one (Ultimate Wifi and Bluetooth Presence Detection) that also pings the bluetooth mac-address but this is another type of script.
So I was wondering if it is possible to ping the bluetooth device also in a Python script. (Combine the best of both worlds sort of speak :-).
Thanks for all your work in the Domoticz community. A lot of people are doing a great job here so people with less knowledge can benefit from this.
Kind regards, Rob
gerardwr
Post by gerardwr »
schulpr wrote: Saturday 02 December 2017 8:39 Hi Dnpwwo,
Yes, I've got this error too, exactly ON the hour, but not EVERY hour. Error log says
2017-12-02 14:00:36.358 Error: (pinger) Transport not initialized, write directive to '192.168.0.222' ignored. Connectionless transport should be Listening.
2017-12-02 16:00:36.310 Error: (pinger) Transport not initialized, write directive to '192.168.0.222' ignored. Connectionless transport should be Listening.
2017-12-02 17:01:05.180 Error: (pinger) Transport not initialized, write directive to '192.168.0.222' ignored. Connectionless transport should be Listening.
2017-12-02 18:00:37.015 Error: (pinger) Transport not initialized, write directive to '192.168.0.32' ignored. Connectionless transport should be Listening.
no more this error till 22:45
In addition my error log contains this error EVERY hour
2017-12-02 22:00:41.612 Error: (pinger) 'onHeartbeat' failed 'KeyError'.
2017-12-02 22:00:41.612 Error: (pinger) ----> Line 181 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onHeartbeat
2017-12-02 22:00:41.612 Error: (pinger) ----> Line 149 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onHeartbeat
schulpr wrote: Saturday 02 December 2017 8:39 Thanks for all your work in the Domoticz community. A lot of people are doing a great job here so people with less knowledge can benefit from this.
+1 Excellent work!
Despite the errors the plugin works fine !
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
I cannot get it to work, also not with the latest version of the plugin
2017-12-06 13:22:04.895 (Ping Status) Started.
2017-12-06 13:22:05.064 (Ping Status) Entering work loop.
2017-12-06 13:22:05.065 (Ping Status) Initialized version 3.0.3, author 'dnpwwo'
2017-12-06 13:22:05.122 Error: (Ping Status) 'onStart' failed 'AttributeError':''Domoticz.Device' object has no attribute 'TimedOut''.
2017-12-06 13:22:05.123 Error: (Ping Status) ----> Line 172 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onStart
2017-12-06 13:22:05.123 Error: (Ping Status) ----> Line 106 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onStart
2017-12-06 13:22:05.123 Error: (Ping Status) ----> Line 189 in /home/pi/domoticz/plugins/Pinger/plugin.py, function UpdateDevice
I'm running Domoticz Version: 3.8337 on a Raspberry Pi 3 with Raspbian Jessie.
The python plugin subsystem seems to be working. Buienradar plugin and NUT UPS plugin are working without any problems.
Dnpwwo
Post by Dnpwwo »
@bizziebis,
ICMP and timed out devices are new features, you will need to be on a very recent beta. I'm on 3.8746
bizziebis
Post by bizziebis »
Thanks, I was to quick with trying and not reading first.. I'm on V3.8775 now and it's working great.
bizziebis
Post by bizziebis »
I noticed that this plugin was the root cause of my memory leak which I also mentioned in the Bug forum. Every hour it will take 0,6MB of memory which will result in almost 20MB memory increase of the Domoticz process each day.
Does anyone else have this problem too?
Velly
Post by Velly »
Confirm memory leak
+ getting thessev errors:
018-02-04 21:31:56.039 Error: (Pinger) 'onHeartbeat' failed 'KeyError'.
2018-02-04 21:31:56.039 Error: (Pinger) ----> Line 184 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onHeartbeat
2018-02-04 21:31:56.040 Error: (Pinger) ----> Line 149 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onHeartbeat
Dnpwwo
Post by Dnpwwo »
@Velly,
Can you have a look at the plugin.py and make sure you are running version 3.x.x?
I've looked at the code for 3.0.0 on github and can't see how you can get an error at line 149 without getting one at 148 first (which you don't)
Velly
Post by Velly »
@Dpnwwo
<plugin key="ICMP" name="Pinger (ICMP)" author="dnpwwo" version="3.0.3">
Dnpwwo
Post by Dnpwwo »
@Velly,
Can you try the version here: https://github.com/dnpwwo/Domoticz-Pinger-Plugin and let me know
That is the one I run successfully. Looks like I need to update the example version that ships with Domoticz
Velly
Post by Velly »
@Dnpwwo
Still same:
2018-02-14 19:22:23.264 Error: (Pinger) 'onHeartbeat' failed 'KeyError'.
2018-02-14 19:22:23.264 Error: (Pinger) ----> Line 180 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onHeartbeat
2018-02-14 19:22:23.264 Error: (Pinger) ----> Line 148 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onHeartbeat
NB: however Lines are changed - I did not compare by myself yet with previous plugin version.
I have about 8-10 python plugins working fine: - the second giving same looking errors is PiMonitor:
2018-02-14 19:21:53.663 Error: (PiMonitor) 'onStart' failed 'KeyError'.
2018-02-14 19:21:53.663 Error: (PiMonitor) ----> Line 162 in /home/pi/domoticz/plugins/PiMonitor/plugin.py, function onStart
2018-02-14 19:21:53.663 Error: (PiMonitor) ----> Line 56 in /home/pi/domoticz/plugins/PiMonitor/plugin.py, function onStart
I am on Jessie pi3 python 3.4
Dnpwwo
Post by Dnpwwo »
@Velly,
Line 148 makes more sense and I think I understand the problem but I can't understand why I never see it because I think I should as well.
Anyway, I pushed a new version to github that has better handling for the Options dictionary and should resolve this.
Velly
Post by Velly »
old (3.0.3):
2018-03-24 21:47:10.421 Error: (Pinger) ----> Line 184 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onHeartbeat
string is : "_plugin.onHeartbeat()"
2018-03-24 21:47:10.421 Error: (Pinger) ----> Line 149 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onHeartbeat
string is : " if (Devices[Device].Options["Name"] == self.icmpConn.Name):"
Current up-to-date plugin (3.0.5):
2018-03-24 21:47:10.421 Error: (Pinger) ----> Line 180 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onHeartbeat
+ 2018-03-24 22:16:27.496 Error: (Pinger) 'onHeartbeat' failed 'AttributeError':''IcmpDevice' object has no attribute 'Name''.
2018-03-24 21:47:10.421 Error: (Pinger) ----> Line 148 in /home/pi/domoticz/plugins/Pinger/plugin.py, function onHeartbeat
string is : " if (("Name" in Devices[Device].Options) and (Devices[Device].Options["Name"] == self.icmpConn.Name)):"
Could you pls take a look onto? - my knowledges in python are near zero level..
nanno
Post by nanno »
Hello !
Same problem for me :(
2018-04-12 15:13:09.970 Error: (TEST42) 'onHeartbeat' failed 'AttributeError':''IcmpDevice' object has no attribute 'Name''.
2018-04-12 15:13:09.970 Error: (TEST42) ----> Line 187 in /home/pi/domoticz/plugins/PINGER/plugin.py, function onHeartbeat
2018-04-12 15:13:09.970 Error: (TEST42) ----> Line 155 in /home/pi/domoticz/plugins/PINGER/plugin.py, function onHeartbeat
Running on :
Version: 3.9208
Build Hash: ff40091a
Compile Date: 2018-04-08 17:15:17
dzVents Version: 2.4.4
Python Version: 3.4.2 (default, Oct 19 2014, 14:03:53) [GCC 4.9.1]
Do you have a solution?
Thx !
nanno
Post by nanno »
I still have this trouble after updating Python and Domoticz.
What can I do to fix that ?
Thanks !
