Telegram custom keyboards
jvdz
Domoticz version: 4.107
Re: Telegram custom keyboards
Post by jvdz »
hoeby wrote: Saturday 15 August 2020 12:49 But simple change the chat-id in the url didn't work.
Do you also know the url api for inline keyboard?
I have used your exact url and that is working so it should work for you too when you put in your botxxxx:yyyy token and chart_id and use that url in your browser.
EDIT: I guess we are mixing 2 things here: Your url is the KEYBOARD option, not the inline..... but I like to understand whether that works before making it inline..... and yes I know how to make the inline as I wrote the dtgbot part doing that.
jvdz
Post by jvdz »
This inline version of your keyboard version works for me opened from chrome:
https://api.telegram.org/botToken/sendMessage?chat_id=-1&text=Choose&reply_markup={"inline_keyboard":[[{"text":"Yes","callback_data":"optYES"},{"text":"No","callback_data":"optNO"}]]}
hoeby
Domoticz version: V2022.1
Post by hoeby »
The reason why i asked for the inline api. Because that works. Then i am not at a hold for the script i am building.
Will not say that i will keep it with inline. Because i like the keyboard option (the not inline)
This one works:
This one not, but don't know why:
https://api.telegram.org/botToken/sendMessage?chat_id=-1&text=Choose&reply_markup={"keyboard":[["Yes"],["No"]]}
it replies this:
{"ok":false,"error_code":400,"description":"Bad Request: inline keyboard expected"}
Tried:
- enabled the privacy mode, no luck
- disabled the privacy mode, no luck
Tried to replace the chat-id to my own chat-id, this is the response
{"ok":false,"error_code":403,"description":"Forbidden: bot was blocked by the user"}
jvdz
Post by jvdz »
hoeby wrote: Saturday 15 August 2020 13:24 This one works:
it replies this:
Are you sure it is a group and not a channel?
hoeby wrote: Saturday 15 August 2020 13:24 Tried to replace the chat-id to my own chat-id, this is the response
Have you first tried to send a command from your phone to the bot and read that with the BOT to establish connectivity?
Jos
hoeby
Post by hoeby »
jvdz wrote: Saturday 15 August 2020 13:38 Are you sure it is a group and not a channel?
I think you made a point there.
When i read my small instructions how i made a few years back. I have written that i needed to make a channel.
Looked in the app, and it says private-channel
jvdz wrote: Saturday 15 August 2020 13:38 Have you first tried to send a command from your phone to the bot and read that with the BOT to establish connectivity?
That i have to look over tonight. This goes to quick for me what you mean. Will have a look on telegram instructions, how to get that information out my bot
jvdz
Post by jvdz »
That is the reason it doen't work as Keyboard only works with persons and groups and will not work with channels. :)
hoeby
Post by hoeby »
Made a group with the bot in it.
Finding the chat-id was the biggest challenge. But found it with some help from google, how to do it.
Now the reply keyboard works.
Only one thing. When i choose an option, it still stays visible.
There is a way to add a true command, so it disapears when an option is chosen. But how to add that in the https line?
Tried this, but i didn't work
https://api.telegram.org/bot:token/sendMessage?chat_id=-1&text=Choose&reply_markup={"keyboard":[["Yes"],["No"]],"one_time_keyboard":["true"]}
Already thanks JVDZ, for all the support
hoeby
Post by hoeby »
hoeby wrote: Saturday 15 August 2020 19:12 Tried this, but i didn't work
I think i found it.
https://api.telegram.org/bot:token/sendMessage?chat_id=-1&text=Choose&reply_markup={"keyboard":[["Yes"],["No"]],"one_time_keyboard":true}
Is this correct?
It works, but don't know if i made it how it designed
jvdz
Post by jvdz »
hoeby wrote: Saturday 15 August 2020 19:42 I think i found it.
Is this correct?
That looks correct to me.... It will just hide the custom keyboard till you hit the keyboard icon again.
To fully remove it you can send this in a response message:
text=done&&reply_markup={"remove_keyboard":true}
Jos
hoeby
Post by hoeby »
Thanks,
The remove functie is made for the https, that worked
Making the remove function work for the ESP took a little more time.
Because the library didn't know the remove_keyboard function, which first needed to add in UniversalTelegramBot
But it is added and works. Only one option for the remove needs to be added to make the story complete. Not needed, but when added i prefer to add all options for that function. Maybe something for tomorrow.
hoeby
Post by hoeby »
jvdz wrote: Saturday 15 August 2020 11:37 I am sure I can help you with that. :)
Do you have any advice, which manual to follow for dgtbot?
jvdz
Post by jvdz »
Just enable the debugging as described in the installation page and have a look at the generated dtg.log. mail me the file in case you need help. :)
EDIT: I was reffering to this Wiki page: https://www.domoticz.com/wiki/Remote_Co ... leshooting
... and it helps when you set the Uservariable TelegramBotLoglevel to 9 in case more detailed log entries are required.
hoeby
Post by hoeby »
The dgtbot has to wait.
I started with it today. Which start with update/upgrade.
But on the upgrade i got an error.
loading files list file for package 'gpg-agent': cannot open /var/lib/dpkg/info/gpg-agent.list (Structure needs cleaning)
When i posted this on google. It looks like a corrupt sd-section.
The system is still running without issues. But i think my sd card is not that great.
I am running a sd card with the name of a local company on it. It says that it is class 10, but i have my questions about the quality of this card.
Last i needed to shutdown the pi because i need to work on the electricity in house. After that the sd was corrupt. And i was sure i did a normal shutdown and waited 5 minutes before cutting the power.
A new sd-card is ordered. Have to wait for it and put a backup on it.
hoeby
Post by hoeby »
Because with the SD-card problems,
I can't find problems in working of domoticz, so i tried it with dzvents
When doing this in putty, it works
curl -s -X POST "https://api.telegram.org/bottoken/sendMessage?chat_id=1" -F text="Kies een van de opties." -F reply_markup="{\"keyboard\":[[{\"text\":\"Yes\"},{\"text\":\"No\"}]]}"
But when doing it this way in dzvents, it doesn't work
os.execute('curl -s -X POST "https://api.telegram.org/bottoken/sendMessage?chat_id=1" -F text="Kies een van de opties." -F reply_markup="{\"keyboard\":[[{\"text\":\"Yes\"},{\"text\":\"No\"}]]}"')
any idea's ?
jvdz
Post by jvdz »
Try:
os.execute('curl -s -X POST "https://api.telegram.org/bottoken/sendMessage?chat_id=1" -F text="Kies een van de opties." -F reply_markup="{\\\"keyboard\\\":[[{\\\"text\":\\\"Yes\\\"},{\\\"text\\\":\\\"No\\\"}]]}"')
hoeby
Post by hoeby »
I will try it later this day, thanks for the option.
I moved the script over from os.execute to dz.openurl
Than it was possible to use the https api without issues
Made this script. This is the start to use it for:
- Doorbell is pushed, camera image is send to telegram and a question (telegram keyboard) is posted undernead it, if you would like to get a new (extra) camera image
- After X time (for me 30 seconds) the keyboard is removed again. Because i couldn't send a remove without text. I will take a callback on the remove keyboard to get the message-id out of it. Then remove the message which is send for the remove-keyboard. This also with no notification.
       customEvents = { 'myCustomEvent',},
       --devices         = {'Trigger device'},                             -- De switch die dit scripts triggerd
       httpResponses   = { "Telegram_Callback"}                          -- Niet aanpassen
Custom event trigger json:
192.168.XXX.XXX:8080/json.htm?type=command&param=customevent&event=myCustomEvent&data=myData
    execute = function(dz, item)
    local teleTok        = 'xxxxxxxxxxxxxx:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'    -- Jouw telegram token
    local chatId         = 'xxxxxxxxx'                                        -- Jouw telegram ChatId
    local tekstpost      = 'Kies een optie.'                                  -- De tekst voor het telegram tekst bericht
    local tekstremove    = 'KeuzeMenuWeg'
    local disable_notify = 'true'                                             -- Als het telegram bericht geen geluid mag maken, dan 'true'
        -- Anders op 'false' zetten
    local KeuzeMenuWeg   = 30                                  -- Aantal seconden, waarna het keuzemenu verwijdert dient te worden.
    debug = false                                                             -- Als debug nodig is, deze op true zetten, anders false
        if item.isHTTPResponse then
            if (item.ok) then
                local id_message   = item.json.result.message_id
                if debug then
                    print (id_message)
                os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/deleteMessage?chat_id='..chatId..'&message_id='..id_message..'"')
                if debug then
                print ('niet goed')
            local myurl1 = 'https://api.telegram.org/bot'..teleTok..'/sendMessage?chat_id='..chatId..'&text='..tekstpost..'&reply_markup={"keyboard":[["Yes"],["No"]],"one_time_keyboard":true,"resize_keyboard":true}'
            if debug then
                print (myurl1)
            dz.openURL(
                url         = myurl1,
                method      = "POST",
            local myurl2 = 'https://api.telegram.org/bot'..teleTok..'/sendMessage?chat_id='..chatId..'&text='..tekstremove..'&reply_markup={"remove_keyboard":true}&disable_notification='..disable_notify..''
            if debug then
                print (myurl2)
            dz.openURL(
                url         = myurl2,
                method      = "GET",
                callback    = "Telegram_Callback",
                }).afterSec(KeuzeMenuWeg)
