Telegram custom keyboards
bigpea
Post by bigpea »
I'm trying to create a custom keyboard with telegram in order to have a simple way to do more action.
Like this (detail: https://core.telegram.org/bots#keyboards):
In detail if I use this link to send a message all works fine:
https://api.telegram.org/botMyToken/sendMessage?chat_id=myId&text=test
But if I try to add the custom keuboard with this URL (adding only this part "&reply_markup={"keyboard":[[{%20text:%20"Si"%20}]]}"):
https://api.telegram.org/botMyToken/sendMessage?chat_id=myId&text=test&reply_markup={"keyboard":[[{%20text:%20"Si"%20}]]}
I receive this error:
{"ok":false,"error_code":400,"description":"Bad Request: can't parse reply keyboard markup JSON object"}
I tryied also with serialized JSON but the result is the same.
Somebody use this function in telegram?
Thanks.
jvdz
Domoticz version: 4.107
Re: Telegram custom keyboards
Post by jvdz »
You mean like this?
http://www.domoticz.com/forum/viewtopic ... enu#p52245
This is implemented in DTGBOT. ;)
Jos
bigpea
Post by bigpea »
yes, I had seen this script, but I just wanted to have the correct url string.
But in the code you indicated I can not find the url track.
jvdz
Post by jvdz »
There is no one single answer to your question as it depends on the functionality you want but generically this is the format i've used:
reply_markup={"keyboard":[["opt 1","opt 2","opt 3"],["menu"]],"resize_keyboard":true}
The url syntax is defined in the telegram website and I've used that to develop all LUA script functions: https://core.telegram.org/bots/api#replykeyboardmarkup
There is also a version of DTGBOT available that uses the inline keyboard option.
Jos
bigpea
Post by bigpea »
The inline version works fine, for example:
https://api.telegram.org/bot/sendMessag ... e_keyboard":[[{"text":"Visualizza spoiler!","url":"http://google.com/"}]]}
But when I try a replykeyboardmarkup, for example your url I receive this error:
{"ok":false,"error_code":400,"description":"Bad Request: inline keyboard expected"}
jvdz
Post by jvdz »
Show me the total URL (without the personal info like API key) so I can have a look please.
Jos
bigpea
Post by bigpea »
Yes, sure, the link is:
https://api.telegram.org/botToken/sendMessage?chat_id=-1&text=Choose&reply_markup={"keyboard":[[{"Yes"}],[{"No"}]]}
jvdz
Post by jvdz »
I can't test it untill the evening, but shouldn't that be like this?:
https://api.telegram.org/botToken/sendMessage?chat_id=-1&text=Choose&reply_markup={"keyboard":[["Yes"],["No"]]}
Jos
bigpea
Post by bigpea »
The message is sent but the keyboard not appear.
jvdz
Post by jvdz »
Just tried your modified command from my previous post with only putting in my bottoken and chat_ID and it shows the Yes/No buttons nicely underneath each other.
Not sure why it doesn't for you.
Jos
bigpea
Post by bigpea »
I have am IPhone, and you? Maine the problem is this.
jvdz
Post by jvdz »
I opened the URL to send the telegram in a Chrome browser on my win10 laptop and run Telegram on multiple platforms, but honestly that shouldn't really matter I would think.
Jos
bigpea
Post by bigpea »
Mmhh ok I will try tomorrow. Thanks for your time.
hoeby
Domoticz version: V2022.1
Post by hoeby »
Sorry for putting up this older thread.
But i want to use the HTTP api
I know that there is dtgbot.
But i don't get it to work. I find it to difficult to setup. Can't find a way to get it to work.
Maybe someone has a great manual, how to do this step by step.
I the meantime i have taken another route.
The route with ESP8266 with telegram. I got it working. But would love to use the option reply keyboard.
But on the esp it didn't work. So i went looking for a HTTP api, just to test and see. But the api also doesn't work and gives this error back
I used this line and filled in the token and chat id
Is the reply keyboard not supported anymore?
I am sending it to a telegram group, could that be the problem. That with groups this function isn't supported?
jvdz
Post by jvdz »
hoeby wrote: Saturday 15 August 2020 10:42 I know that there is dtgbot.
I am sure I can help you with that. :)
hoeby wrote: Saturday 15 August 2020 10:42 I the meantime i have taken another route.
That url works fine for me when I use my ID or a test group. When using it with a group you need to check the privacy mode for the group: (From the Telegram FAQ page https://core.telegram.org/bots/faq#will ... he-bot-api )
What messages will my bot get?
1. All bots, regardless of settings, will receive:
All service messages.
All messages from private chats with users.
All messages from channels where they are a member.
2. Bot admins and bots with privacy mode disabled will receive all messages except messages sent by other bots.
3. Bots with privacy mode enabled will receive:
Commands explicitly meant for them (e.g., /command@this_bot).
General commands from users (e.g. /start) if the bot was the last bot to send a message to the group.
Messages sent via this bot.
Replies to any messages implicitly or explicitly meant for this bot.
Note that each particular message can only be available to one privacy-enabled bot at a time, i.e., a reply to bot A containing an explicit command for bot B or sent via bot C will only be available to bot A. Replies have the highest
Jos
hoeby
Post by hoeby »
I enabled and disabled the privacy mode for group.
Do i have to wait a X-periode?
Because in both privacy modes it doesn't work, still the same error returns
jvdz
Post by jvdz »
As far as I remember setting the group privacy is a onetime thing working immediately....but it is a long time ago I did that. :)
Have you tried the url from the browser just to see what happens? That is what I did and is working fine with my BOTTOKEN & GroupID.
Does the URL work with your own chat_id?
Jos
hoeby
Post by hoeby »
at this moment i only have the group id, not a non group id. With a minus in front.
With that it doesn't work. When i post the url in the webbrowser i get the response that it expects an inline command
jvdz
Post by jvdz »
Nah ... you do have your own phone's chat_id or else you couldn't use Telegram on your phone. ;)
hoeby
Post by hoeby »
Yes my chat-id i have.
But simple change the chat-id in the url didn't work.
Do you also know the url api for inline keyboard?
