Page 2 of 2
Re: Dashticz - Save CONFIG.js automatically with PHP
Posted: Monday 12 February 2018 10:40
by michaelm86
michaelm86 wrote: Monday 12 February 2018 10:36 Hi DewGew,
I tried this. but is does not work ... :(
when i add the ip and port is does not see it in the config. but when i add the user and ww it sees it.
any other options?
Hi DegGew,
correction.. when i make a change tot the files it work. but whenichange something in the browser the settings are not saved to the file.
Posted: Monday 12 February 2018 10:51
by michaelm86
I think it is something with the access rights on linux level.
domoticz folder:
drwxrwxrwx 5 domo domo 4096 Feb 9 13:39 domoticz
files in custom:
-rw-r--r-- 1 root root 230 Feb 12 10:32 custom.js
-rw-r--r-- 1 root root 21 Feb 12 10:32 custom.css
-rwxrwxrwx 1 root root 173 Feb 12 10:44 CONFIG.js
-rw-r--r-- 1 root root 2133 Feb 12 10:32 CONFIG_DEFAULT.js
any idea if this is correct?
Posted: Monday 12 February 2018 11:01
by DewGew
any other options?
You only have to peform a chmod 777 on CONFIG.js
Posted: Monday 12 February 2018 11:06
by DewGew
michaelm86 wrote: Monday 12 February 2018 10:51 I think it is something with the access rights on linux level.
domoticz folder:
files in custom:
Do have any errors in the browser consol? (hit F12)
Posted: Monday 12 February 2018 11:19
by DewGew
webpages with PHP is not working in domoticz webserver. Install apache or nginx, php and run dashticz_v2 in apache/nginx www folder instead
Posted: Monday 12 February 2018 11:26
by michaelm86
oke, how do i do that? :) is there a manual somewhere?
or is it just a "sudo git clone https://github.com/robgeerts/dashticz_v2 --branch beta" in the /var/www folder?
Posted: Monday 12 February 2018 11:39
by DewGew
Yes you can do that..
Posted: Monday 12 February 2018 11:47
by michaelm86
oke thanks it works. changes are saved now! :D
but..
when i remove the first /* (including the line with text) and last /* to use the default config it stops working :?
message
time out something is wrong check your config.js.
sorry for all the questions. it is the first time using it.
Posted: Monday 12 February 2018 12:42
by DewGew
Change :
columns[1]['blocks'] = ['currentweather_big','weather','garbage']
to
columns[1]['blocks'] = ['currentweather_big','weather']
You have to define 'garbage' settings before using it.
Then follow http://www.domoticz.com/wiki/Dashticz_V2.
Posted: Monday 12 February 2018 13:39
by michaelm86
Hi DewGew,
great it works!
do i need to do anything special to see my switches? i created a block with the idx of my light switch but is looks like it does not see it.
blocks[3] = {}
blocks[3]['width'] = 6;
blocks[3]['title'] = 'Spotjes Eettafel'
blocks[3]['hide_data'] = true;
blocks[3]['hide_lastupdate'] = true;
Posted: Monday 12 February 2018 14:18
by DewGew
You add you switches (blocks) in the columns like this:
columns[1]['blocks'] = ['weather', 3, 6, 7, 4];
Posted: Monday 12 February 2018 14:51
by michaelm86
Hi DewGew,
did i do anything wrong?
The switches and the ping devices aren't showing.
this is my screen:
this is my config:
config['garbage_maxitems'] = '7';
config['garbage_width'] = '';
config['loginEnabled'] = 1;
config['no_rgb'] = '0';
config['auto_positioning'] = 1;
config['use_favorites'] = 1;
config['disable_googleanalytics'] = '0';
config['last_update'] = 1;
config['hide_topbar'] = '0';
config['edit_mode'] = '0';
config['hide_seconds'] = '0';
config['hide_seconds_stationclock'] = '0';
config['use_fahrenheit'] = '0';
config['use_beaufort'] = '0';
config['translate_windspeed'] = 1;
config['static_weathericons'] = '0';
config['hide_mediaplayer'] = '0';
config['garbage_hideicon'] = '0';
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = '0';
config['garbage_use_names'] = '0';
config['garbage_use_cors_prefix'] = 1;
//var trashnames = {}
//trashnames['Gft'] = 'GFT';
//trashnames['Pmd'] = 'Plastic';
//trashnames['Rest'] = 'Rest'; //LEAVE EMPTY IF YOU WANT TO HIDE IT
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:12, channels: [1,2,3,4,31,46,92], maxitems: 8 }
var _STREAMPLAYER_TRACKS  	= [
	{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
	{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
	{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
	{"track":4,"name":"BBC Radio 1","file":"http://radiofeeds.co.uk/bbcradio1.pls"},  ];
////////////////////// FRAMES ///////////////////////////
var frames = {}
frames.weather = {refreshiframe:10000,height:230,frameurl:"//forecast.io/embed/#lat=52.1924&lon=5.3901&name=Amersfoort&color=#00aaff&font=Helvetica&fontcolor=#ffffff&units=si&text-color=#fff",width:12}
////////////////////// BUTTONS /////////////////////////
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image:'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url:'https://gadgets.buienradar.nl/gadget/zoommap/?lat=52.06022&lng=4.39288&overname=2&zoom=13&naam=2493bj&size=3&voor=1'}
////////////////////// BLOCK TITLES /////////////////////////
var blocks = {}
blocks['blocktitle_tv'] = {}
blocks['blocktitle_tv']['key'] = 'blocktitle_tv';
blocks['blocktitle_tv']['type'] = 'blocktitle';
blocks['blocktitle_tv']['title'] = 'TV and Nieuws';
blocks['blocktitle_switches'] = {}
blocks['blocktitle_switches']['key'] = 'blocktitle_switches';
blocks['blocktitle_switches']['type'] = 'blocktitle';
blocks['blocktitle_switches']['title'] = 'Schakelaars';
blocks['blocktitle_temp'] = {}
blocks['blocktitle_temp']['key'] = 'blocktitle_temp';
blocks['blocktitle_temp']['type'] = 'blocktitle';
blocks['blocktitle_temp']['title'] = 'Verwarming en Temperatuur';
blocks['blocktitle_vijver'] = {}
blocks['blocktitle_vijver']['key'] = 'blocktitle_vijver';
blocks['blocktitle_vijver']['type'] = 'blocktitle';
blocks['blocktitle_vijver']['title'] = 'Koi Vijver';
blocks['blocktitle_spotify'] = {}
blocks['blocktitle_spotify']['key'] = 'blocktitle_spotify';
blocks['blocktitle_spotify']['type'] = 'blocktitle';
blocks['blocktitle_spotify']['title'] = 'Spotify';
// custom block width for switches
blocks['news_2'] = {}
blocks['news_2']['feed'] = 'http://feeds.bbci.co.uk/news/world/europe/rss.xml';
blocks['s1'] = {} //Scene Front room all off
blocks['s1']['hide_data'] = true;
blocks['s1']['hide_lastupdate'] = true;
blocks['s1']['icon'] = 'fa-times-circle';
blocks['s2'] = {} //Movie scene
blocks['s2']['hide_data'] = true;
blocks['s2']['hide_lastupdate'] = true;
blocks['s2']['icon'] = 'fa-video-camera';
blocks['s3'] = {} //Evening scene
blocks['s3']['hide_data'] = true;
blocks['s3']['hide_lastupdate'] = true;
blocks['s3']['icon'] = 'fa-image';
blocks[3] = {}
blocks[1] = {}
blocks[1]['width'] = 6;
blocks[1]['title'] = 'Woonkamer lampen'
blocks[1]['hide_data'] = true;
blocks[1]['hide_lastupdate'] = true;
blocks[4] = {}
blocks[4]['width'] = 6;
blocks[4]['title'] = 'Vijververlichting'
blocks[4]['hide_data'] = true;
blocks[4]['hide_lastupdate'] = true;
blocks[2] = {}
blocks[2]['width'] = 6;
blocks[2]['title'] = 'Buitenlampe Achterdeur'
blocks[2]['hide_data'] = true;
blocks[2]['hide_lastupdate'] = true;
// DOORBELL
blocks[89] = {}
blocks[89]['width'] = 1;
blocks[89]['title'] = ''
blocks[89]['hide_data'] = true;
blocks[89]['hide_lastupdate'] = true;
blocks[89]['playsound'] = 'sounds/doorbell.mp3';
blocks[89]['protected'] = true;
blocks[89]['icon'] = 'fa-bell-o';
//change temp blocks size
blocks[5] = {}
blocks[5]['width'] = 3;
blocks[52] = {}
blocks[52]['width'] = 3;
blocks[54] = {}
blocks[54]['width'] = 3;
blocks[81] = {}
blocks[81]['width'] = 3;
blocks[81]['title'] = 'Change temp.'
//Device status - ping results
blocks[18] = {}
blocks[18]['width'] = 12;
blocks[18]['title'] = 'Internet'
blocks[18]['hide_data'] = true;
blocks[18]['hide_lastupdate'] = true;
blocks[18]['icon'] = 'fa-circle';
blocks[18]['protected'] = true;
blocks[19] = {}
blocks[19]['width'] = 12;
blocks[19]['title'] = 'QNAP'
blocks[19]['hide_data'] = true;
blocks[19]['hide_lastupdate'] = true;
blocks[19]['icon'] = 'fa-circle';
blocks[19]['protected'] = true;
blocks[22] = {}
blocks[22]['width'] = 12;
blocks[22]['title'] = 'QNAP'
blocks[22]['hide_data'] = true;
blocks[22]['hide_lastupdate'] = true;
blocks[22]['icon'] = 'fa-circle';
blocks[22]['protected'] = true;
blocks[21] = {}
blocks[21]['width'] = 12;
blocks[21]['title'] = 'PC Mike'
blocks[21]['hide_data'] = true;
blocks[21]['hide_lastupdate'] = true;
blocks[21]['icon'] = 'fa-circle';
blocks[21]['protected'] = true;
//blocks['sunrise'] = {}
//blocks['sunrise']['width'] = 1;
//blocks['miniclock'] = {}
//blocks['miniclock']['width'] = 7;
// My IDX list
// 00 = omschrijving
////////////////////// COLUMNS /////////////////////////
var columns = {}
columns['bar'] = {}
columns['bar']['blocks'] = ['sunrise','miniclock',89]
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_switches',4,3,2,1]
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = [frames.weather,'blocktitle_temp',5,82,'54_1','52_1','blocktitle_vijver',104,'news','trafficmap']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [18,19,21,22,buttons.buienradar,'news_2',tvguide.dutch,'traffic','blocktitle_spotify','spotify']
columns[3]['width'] = 2;
////////////////////// STANDBY /////////////////////////
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
Posted: Monday 12 February 2018 16:00
by DewGew
michaelm86 wrote: Monday 12 February 2018 14:51 Hi DewGew,
this is my screen:
this is my config:
var tvguide = {}
var frames = {}
var buttons = {}
var blocks = {}
blocks[3] = {}
blocks[1] = {}
blocks[4] = {}
blocks[2] = {}
// DOORBELL
blocks[89] = {}
blocks[5] = {}
blocks[52] = {}
blocks[54] = {}
blocks[81] = {}
blocks[18] = {}
blocks[19] = {}
blocks[22] = {}
blocks[21] = {}
// My IDX list
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
Disable those:
Posted: Monday 12 February 2018 16:10
by michaelm86
Thanks, but that didn't do the trick..
I set both the values to '0'. still nothing to see :P
got some more suggestions?
Posted: Thursday 21 June 2018 11:11
by FrankVZ
This is an older thread in the meantime, but did cost me a lot of time to find out.
So I share my information here, it might be usefull for others.
(on a Synology DSM with webserver Apache/PHP7 active):
I got the info and files here: https://github.com/Dashticz/dashticz_v2, but some minor adjustments were needed for me.
Logged in with WinSCP (for me the easiest way)
Moved the content of the /domoticz/www/Dashticz folder to a webfolder (for my webserver) in this case /web/DasticzV2.
Delete the compete Dashticz folder from /domoticz/www/
right-click on the file /<your web dashticz folder>/custom/CONFIG.js and give permissions to other users to write
Logged in with SSH (putty) to my synology, changed to user "root".
Make a simlink with the command
ln -s /volume1/web/DashticzV2/ /volume1/@appstore/domoticz/www/Dashticz
(ln -s <your webfolder> <a new Dashticzfolder for Domoticz to create>)
Now I can change the settings from the Dashticz webpage, with the link
http://<MY WEBSERVER DOMOTICZ IP ADRES>:7000
You can access the Dashticz page like this, but the settings will not be saved then:
http://<MY DOMOTICZ IP>:<DomoticzPORT>/Dashticz/index.html
Anyway, as the settings from the menu will work, the position for the e.g. icons still does not work - the icons jump all over the screen. At the bottom of the screen a remark "save to see the results" (or similar) but no way to save it. The shown red "edit button" gives a code that is almost empty with "undefined" buttons, so there has still to be done some work here :shock:
hth,
