Wow, nice work. Going to try it in a moment. You had a good vacation?
Just tested:
1) When clicking the settings icon and clicking save it saves so this is good
2) When going into EDIT mode my changes aren`t save to the config file and still have to this manually
It doesn't seem to save. If I change anything in settings and click 'save', the page refreshes, but no changes visible. I do believe I have PHP enabled on the webserver.
Nice job, did a quick test by changing the dashboard title, that works.
Changing contents of the dashboard by f.e. adding a clock is not saved (beta version downloaded today ("Latest commit 957b89e 2 days ago"))
I started from default installation with only the correct IP set. After the first test I also tried to change config['auto_positioning'] to 0 (was on 1 before), but that also did not solve the issue. Will it be possible to switch auto_positioning from the web-config-interface in the future?
(for users with issues, I'm running Dashticz on my Synology nas, made the file write-able for the 'http' user by right clicking on the file in 'File Station')
pvm wrote: Tuesday 03 October 2017 15:08
You mean, like this?
Screen Shot 2017-10-03 at 17.42.20.png (46.44 KiB) Viewed 6578 times
It does seem to change the config.js file, but doesn't show when page is reloaded. Something to figure out next time.
Reading through the config.js file, it looks like all config blocks are there at least twice (last count 5 times, because I tried it several times), one with the new settings, and below that are the old settings. So, first the title is defined as Control-Center, but... in the second (old) part the title is defined as ControlCenter. I think the latest read by the browser is what it is going to use for the page.
I do not see the effect of continuous adding of blocks. I'm not able to add any blocks however.
Do I need to specify columns or should everything be possible from within the web-interface?
(when setting auto positioning to 1 i see my favorites)
When I use the chrome web-interface nothing happens when pressing save after adding some blocks. The save button in the settings screen does generate a lot of calls and a refresh op the page.
Is there any more info I can provide?
in my system the save option doesn't work, before, when i pushed save, i got an page with the settings which i had to copy to the config.js but i don't get this anymore how can i get this back?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
i have installed the beta of dashticz on my ubuntu server. But when i lauch it the first time. the changed are not saved to config.js.
i did the following :
- installed ubuntu and comfiguratio
- installed php 7
- installed and configured domoticz (working adn using it)
- git clone https://github.com/robgeerts/dashticz_v2 --branch beta
- sudo chmod 777 -R domoticz/
- sudo cp CONFIG_DEFAULT.js CONFIG.js
- lauched the web browser and accessed the ip of my server http://192.168.116.80:8080/dashticz_v2/
can anyone help me ou?
Domoticz 3.8153 on linux laptop ubuntu 17.10 | Toon Thermostat | RFlink usb gateway
michaelm86 wrote: Monday 12 February 2018 10:04
Hi Guys,
- installed php 7
