Page 2 of 2
Re: Adding lan interface to RfxTrx433E
Posted: Monday 25 November 2019 23:05
by iganin
@ b_weijenberg
Have you got any other suggestion on how to move RFXtrx433 from the server away? For the moment I use Raspberry PI with Domoticz device sharing setup.
It works, but I don't trust Pi a lot due to an issue with SD cards.
Posted: Tuesday 26 November 2019 10:17
by b_weijenberg
ser2net does not execute many write actions to the SD card and a Raspberry PI runs OK.
There seems to be a TP-LINK LAN-USB interface that I don't know the type and if still available.
Posted: Thursday 07 May 2020 23:19
by frenchyyii
Hi, just a quick message from France to thank you for your topic and add the info it also works using an ESP8266/other , wemos etc ....
Eric
Posted: Thursday 16 July 2020 22:01
by nigels0
Well mine just stopped working and it is a puzzle why.
Domoticz recognises the port, but it doesn't communicate any more.
I disconnected the LAN interface from the RFX and the RFX worked fine - and using the software tool to check the LAN interface, that seems OK too. Maybe the LAN interface has broken...
Posted: Sunday 19 July 2020 10:38
by nigels0
I’ve found a workaround; I updated the firmware to the latest then I found that while the interface didn’t activate on boot - or when I disabled then enabled the hardware.
What did work though was to change the mode - in doing so, the interface started working with the log showing what was enabled and disabled. This suggests to me that it is an issue with Domoticz rather than with the hardware.
