Adding lan interface to RfxTrx433E
iganin
Re: Adding lan interface to RfxTrx433E
Post by iganin »
@ b_weijenberg
Have you got any other suggestion on how to move RFXtrx433 from the server away? For the moment I use Raspberry PI with Domoticz device sharing setup.
It works, but I don't trust Pi a lot due to an issue with SD cards.
b_weijenberg
Post by b_weijenberg »
ser2net does not execute many write actions to the SD card and a Raspberry PI runs OK.
There seems to be a TP-LINK LAN-USB interface that I don't know the type and if still available.
RFX-433, RFX-433EMC, RFX-868
frenchyyii
Post by frenchyyii »
Hi, just a quick message from France to thank you for your topic and add the info it also works using an ESP8266/other , wemos etc ....
Eric
nigels0
Domoticz version: 3.8153
Post by nigels0 »
Well mine just stopped working and it is a puzzle why.
Domoticz recognises the port, but it doesn't communicate any more.
I disconnected the LAN interface from the RFX and the RFX worked fine - and using the software tool to check the LAN interface, that seems OK too. Maybe the LAN interface has broken...
nigels0
Post by nigels0 »
I’ve found a workaround; I updated the firmware to the latest then I found that while the interface didn’t activate on boot - or when I disabled then enabled the hardware.
What did work though was to change the mode - in doing so, the interface started working with the log showing what was enabled and disabled. This suggests to me that it is an issue with Domoticz rather than with the hardware.
