Page 2 of 9
Re: Dashticz - Module - Spotify
Posted: Tuesday 11 July 2017 21:36
by EdwinK
Btw.. Nice it doesn't require a premium account
Posted: Wednesday 12 July 2017 11:28
by jmvdijk
vgr2 wrote:I mean, empty playlist
I have the same problem. Is there a solution for this problem?
Re: Dashticz - [BETA]Module - Spotify
Posted: Thursday 13 July 2017 11:08
by barbaar
I got around this by opening Spotify itself once on the same machine..
But later I found I cannot get this to work in my Tablet using Fully Kiosk Browser. I keep seeing the "INVALID_CLIENT: Invalid redirect URL" error, even after I logged in op developer.spotify.com.
It would be very cool if we got this module to work, and extend a little (play music on other device!)
Posted: Thursday 13 July 2017 11:12
by vgr2
barbaar wrote:I got around this by opening Spotify itself once on the same machine..
would be nice also for me......
Posted: Thursday 13 July 2017 11:31
by robgeerts
I assume you're using the same url on windows and tablet?
For example, some people are using
http://localhost/dashticz on windows and
http://192.168.1.3/dashticz on another device.
Posted: Thursday 13 July 2017 11:47
by vgr2
Maybe there is a missunderstanding on my side. At the moment I have to open / or the spotify web api opens Spotify in parallel. Means I have to install on all of the tablets spotify also. My understanding from spotify web api is that should be normaly not needed.
Posted: Thursday 13 July 2017 12:03
by robgeerts
Indeed, it opens Spotify, but I agree it should play in webbrowser...
Let me get into this!
Posted: Monday 17 July 2017 11:54
by Derik
mmm looks very great...
Only on what speakers do you play this music??
On the tablet very bad...
Other options?
xxx
Posted: Monday 17 July 2017 11:55
by robgeerts
Well, it should open Spotify-app (at least on windows, didnt test on tablet yet).
Playing via browser is not supported by the Spotify API...
Posted: Monday 17 July 2017 12:02
by pollefinario
Rob, pointed me to this thread. I will check it tonight. Also using Fully Kiosk Browser, did you check any (advanced) settings also?
Posted: Tuesday 18 July 2017 9:16
by konix
vgr2 wrote:Rob, now I have to loging to Spotify parallel, otherwise it will not work.
Hi vgr2,
How did you do to see your playlist finally? I have the button "show playlist" but no popup that opens anything?
- Capture.PNG (44.08 KiB) Viewed 5943 times
- Capture01.PNG (51.85 KiB) Viewed 5940 times
Posted: Tuesday 18 July 2017 20:21
by vgr2
Have you installed last beta?
Posted: Thursday 20 July 2017 10:05
by konix
vgr2 wrote:Have you installed last beta?
Hi vgr2,
I try again and now it's works .....
Posted: Wednesday 26 July 2017 23:18
by D'rMorris
Just so that it might help others: if you only created a Spotify account so that you could test this plugin (like I did), please be aware that you indeed first have to actually play something. I created an account, enabled the developer API, created 2 playlists, got the Spotify login page when refresjng Dashticz, but nothing showed when I clicked playlists. Then I installed the Spotify app on my Android tablet (from which I'm now accessing Dashticz), played a song and all of a sudden the plugin appeared in Dashticz!
Posted: Wednesday 09 August 2017 10:14
by ArieKanarie
Is it still necessary to install spotify on the domoticz device?
Because as far as i know spotify cannot be installed on raspberry..
Posted: Wednesday 09 August 2017 10:15
by robgeerts
Yes, i'm sorry, it is.
Posted: Wednesday 09 August 2017 13:22
by freakshock
A possible alternative is using Logitech media server with a Spotify plugin (I use Spotty).
This way you can use a standard mediaplayer block in Dashticz. That way you can use back, stop, play/pause and next buttons.
I also made a selector switch that can choose playlist within Spotty (all manual config unfortunately).
Of course you would need a server to run LMS.
Posted: Wednesday 09 August 2017 14:12
by nvb1989
Amazing plugin!
Is it possible to have the following features:
- If you click on "Select Playlists", also show the playlist label (name). Now there is only a album picture showing.
- Is it possible to show the available songs within a playlist? So you can navigate directly to the correct song?
- Is it possible to have a search field to use the search library within Spotify? So we can play songs outside our playlists?
Very pleased to have spotify now within Domoticz, thanks!!
Posted: Wednesday 09 August 2017 16:30
by robgeerts
First 2 suggestions are new in latest version, check it out!!
Posted: Wednesday 09 August 2017 16:58
by nvb1989
robgeerts wrote: Wednesday 09 August 2017 16:30
Great!! It is working.
