Page 2 of 16
Re: Python Plugin: Broadlink RM2 V3
Posted: Wednesday 28 June 2017 20:43
by zak45
@Phantom
can you show the content of /usr/lib/python3.5 ?
Posted: Wednesday 28 June 2017 22:26
by Phantom
Sure, here is it:
pi@raspberrypi:/usr/lib/python3.5 $ ls
abc.py datetime.py lib2to3 __pycache__ symbol.py
aifc.py dbm lib-dynload pyclbr.py symtable.py
antigravity.py decimal.py LICENSE.txt py_compile.py _sysconfigdata.py
argparse.py difflib.py linecache.py _pydecimal.py sysconfig.py
ast.py dis.py locale.py pydoc_data tabnanny.py
asynchat.py distutils logging pydoc.py tarfile.py
asyncio doctest.py lzma.py _pyio.py telnetlib.py
asyncore.py dummy_threading.py macpath.py queue.py tempfile.py
base64.py _dummy_thread.py macurl2path.py quopri.py test
bdb.py email mailbox.py random.py textwrap.py
binhex.py encodings mailcap.py reprlib.py this.py
bisect.py enum.py _markupbase.py re.py _threading_local.py
_bootlocale.py filecmp.py mimetypes.py rlcompleter.py threading.py
broadlink fileinput.py modulefinder.py runpy.py timeit.py
bz2.py fnmatch.py multiprocessing sched.py tkinter
calendar.py formatter.py netrc.py selectors.py tokenize.py
cgi.py fractions.py nntplib.py shelve.py token.py
cgitb.py ftplib.py ntpath.py shlex.py traceback.py
chunk.py functools.py nturl2path.py shutil.py tracemalloc.py
cmd.py __future__.py numbers.py signal.py trace.py
codecs.py genericpath.py opcode.py _sitebuiltins.py tty.py
codeop.py getopt.py operator.py sitecustomize.py turtle.py
code.py getpass.py optparse.py site.py types.py
collections gettext.py os.py smtpd.py typing.py
_collections_abc.py glob.py _osx_support.py smtplib.py unittest
colorsys.py gzip.py pathlib.py sndhdr.py urllib
_compat_pickle.py hashlib.py pdb.py socket.py uuid.py
compileall.py heapq.py __phello__.foo.py socketserver.py uu.py
_compression.py hmac.py pickle.py sqlite3 venv
concurrent html pickletools.py sre_compile.py warnings.py
config-3.5m-arm-linux-gnueabihf http pipes.py sre_constants.py wave.py
configparser.py idlelib pkgutil.py sre_parse.py weakref.py
contextlib.py imaplib.py plat-arm-linux-gnueabihf ssl.py _weakrefset.py
copy.py imghdr.py platform.py statistics.py webbrowser.py
copyreg.py importlib plistlib.py stat.py wsgiref
cProfile.py imp.py poplib.py stringprep.py xdrlib.py
crypto inspect.py posixpath.py string.py xml
crypt.py io.py pprint.py _strptime.py xmlrpc
csv.py ipaddress.py profile.py struct.py zipapp.py
ctypes json pstats.py subprocess.py zipfile.py
curses keyword.py pty.py sunau.py
Posted: Wednesday 28 June 2017 23:24
by zak45
ok, looks all is there.. and do you have read the wiki and follow all instructions ?
http://www.domoticz.com/wiki/Using_Python_plugins
viewtopic.php?f=65&t=16116&p=119747
Posted: Thursday 29 June 2017 11:26
by Phantom
Thanks, the problem was that i installed it on python 3.4 and then updated to 3.5 when i got the device, so after doing all the step again the plugin starts now.
2017-06-29 11:20:55.890 (Remote M3 mini) Initialized version 3.0.0, author 'zak45'
BUt now i get this message:
2017-06-29 11:22:05.461 Error: (Remote M3 mini) Error Connecting to Broadlink device....
i dubbel checked the ip address and the mac and those are correct, i can control the device with the app.
Could it be because it is the "Broadlink RM Mini 3 Black Bean"?
Is there a way i can check something?
Posted: Thursday 29 June 2017 11:39
by rafal
i did some test on virtual machine and...
under Windows10 64bit the best way to get BroadlinkRM2 with kodi is:
1) Domoticz V3.8xxxx
2) Install python 3.4.0 (3.5, 3.6.1. doesnt't work)
https://www.python.org/downloads/release/python-340/ check "add python.exe.to path"
3) Install pyscrypto-2.6.1.win32-py3.4 with admin right
https://www.dropbox.com/sh/htyghey9e402 ... 3H36a?dl=0
4)Install setup.exe.
https://www.dropbox.com/sh/htyghey9e402 ... 3H36a?dl=0 with admin right
DONE!
Posted: Thursday 29 June 2017 15:20
by Andree
i'm becoming crazy.
Install same package and configuration of Rafal and now i have same problem of your previus post!
error: Unable to find vcvarsall.bat
Cleaning up...
Command C:\Python34\python.exe -c "import setuptools, tokenize;__file__='C:\\Users\\andre\\AppData\\Local\\Temp\\pip_build_andre\\pycrypto\\setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record C:\Users\andre\AppData\Local\Temp\pip-swj86p1y-record\install-record.txt --single-version-externally-managed --compile failed with error code 1 in C:\Users\andre\AppData\Local\Temp\pip_build_andre\pycrypto
Storing debug log for failure in C:\Users\andre\pip\pip.log
Posted: Thursday 29 June 2017 16:01
by Andree
Posted: Thursday 29 June 2017 17:30
by zak45
Phantom wrote:Thanks, the problem was that i installed it on python 3.4 and then updated to 3.5 when i got the device, so after doing all the step again the plugin starts now.
Just install another HW in Domoticz and do a discovery to see if the plugin retreive your device.
Posted: Thursday 29 June 2017 17:31
by zak45
Andree wrote:i'm becoming crazy.
Cleaning up...
Error look likes related to pycrypto. You should found in dropbox necessary files to install, depend of python version.
Posted: Thursday 29 June 2017 17:44
by zak45
Are you sure you have checked : install for all users ???
I would also reboot after all is done.
Posted: Thursday 29 June 2017 18:09
by Caribou
Hi zak45,
I have an issue with your Broadlink plugin, even with the v3 and previous version.
When this plugin is activated, my domoticz crashes randomly daily.
When this plugin is desactivated, my domoticz runs perfectly.
Here are some informations to help you to help me :)
My domoticz version:
- Spoiler: show
- Version: 3.8025
Build Hash: 37b51336
Compile Date: 2017-06-28 06:32:47
3 crash logs:
- Spoiler: show
- 2017-06-27 16:33:45.717 XiaomiGateway: stopped
2017-06-27 16:33:45.746 (Broadlink RM2) Calling message handler 'onStop'.
2017-06-27 16:33:45.746 (Broadlink RM2) onStop called
2017-06-27 16:33:45.847 (Broadlink RM2) Exiting work loop...
2017-06-27 16:33:45.847 (Broadlink RM2) Stopped.
2017-06-27 16:33:45.868 Error: Domoticz received fatal signal 6 !...
2017-06-27 16:33:45.875 Error: /home/caribou/domoticz/domoticz() [0x5d36e8]
2017-06-27 16:33:45.875 Error: /home/caribou/domoticz/domoticz(_Z14signal_handleri+0x50) [0x5d3790]
2017-06-27 16:33:45.875 Error: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f9986dea390]
2017-06-27 16:33:45.875 Error: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38) [0x7f99860ae428]
2017-06-27 16:33:45.875 Error: /lib/x86_64-linux-gnu/libc.so.6(abort+0x16a) [0x7f99860b002a]
2017-06-27 16:33:45.875 Error: /home/caribou/domoticz/domoticz(_ZN9__gnu_cxx27__verbose_terminate_handlerEv+0x155) [0xb328f5]
2017-06-27 16:33:45.875 Error: /home/caribou/domoticz/domoticz(_ZN10__cxxabiv111__terminateEPFvvE+0x6) [0xae7886]
2017-06-27 16:33:45.875 Error: /home/caribou/domoticz/domoticz() [0xae78b3]
2017-06-27 16:33:45.875 Error: /home/caribou/domoticz/domoticz() [0xae7e42]
2017-06-27 16:33:45.875 Error: /home/caribou/domoticz/domoticz(_ZN5boost15throw_exceptionINS_10lock_errorEEEvRKT_+0x114) [0x5d0494]
2017-06-27 16:33:45.875 Error: /home/caribou/domoticz/domoticz(_ZN5boost5mutex4lockEv+0x46) [0x5f7a56]
2017-06-27 16:33:45.875 Error: /home/caribou/domoticz/domoticz(_ZN7Plugins7CPlugin16IoThreadRequiredEv+0x1a) [0x8e278a]
2017-06-27 16:33:45.875 Error: /home/caribou/domoticz/domoticz(_ZN7Plugins13CPluginSystem7Do_WorkEv+0x115) [0x8eb925]
2017-06-27 16:33:45.875 Error: /home/caribou/domoticz/domoticz() [0xa07c4a]
2017-06-27 16:33:45.875 Error: /lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba) [0x7f9986de06ba]
2017-06-27 16:33:45.875 Error: /lib/x86_64-linux-gnu/libc.so.6(clone+0x6d) [0x7f99861803dd]
- Spoiler: show
- 2017-06-28 04:04:38.122 (Broadlink RM2) Calling message handler 'onHeartbeat'.
2017-06-28 04:05:08.183 (Broadlink RM2) Calling message handler 'onHeartbeat'.
2017-06-28 04:05:38.240 (Broadlink RM2) Calling message handler 'onHeartbeat'.
2017-06-28 04:06:08.350 (Broadlink RM2) Calling message handler 'onHeartbeat'.
2017-06-28 04:06:08.351 Error: Domoticz received fatal signal 6 !...
2017-06-28 04:06:08.371 Error: /home/caribou/domoticz/domoticz() [0x5d36e8]
2017-06-28 04:06:08.371 Error: /home/caribou/domoticz/domoticz(_Z14signal_handleri+0x50) [0x5d3790]
2017-06-28 04:06:08.371 Error: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f0d949fb390]
2017-06-28 04:06:08.371 Error: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38) [0x7f0d93cbf428]
2017-06-28 04:06:08.371 Error: /lib/x86_64-linux-gnu/libc.so.6(abort+0x16a) [0x7f0d93cc102a]
2017-06-28 04:06:08.371 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(Py_FatalError+0x3f) [0x7f0d8f3bf6df]
2017-06-28 04:06:08.371 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(_Py_CheckRecursiveCall+0x90) [0x7f0d8f38b190]
2017-06-28 04:06:08.371 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyObject_Call+0x57) [0x7f0d8f3528d7]
2017-06-28 04:06:08.371 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(_PyObject_CallMethodId+0x124) [0x7f0d8f34e334]
2017-06-28 04:06:08.371 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0x1e664d) [0x7f0d8f3bf64d]
2017-06-28 04:06:08.371 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(Py_FatalError+0x1a8) [0x7f0d8f3bf848]
2017-06-28 04:06:08.371 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_EvalFrameEx+0x94c) [0x7f0d8f38c47c]
2017-06-28 04:06:08.371 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0x24ac0c) [0x7f0d8f423c0c]
2017-06-28 04:06:08.371 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_EvalFrameEx+0x62d9) [0x7f0d8f391e09]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_EvalCodeEx+0x23) [0x7f0d8f423ce3]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0xd2b95) [0x7f0d8f2abb95]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyObject_Call+0x6e) [0x7f0d8f3528ee]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_EvalFrameEx+0x2d8b) [0x7f0d8f38e8bb]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0x24ac0c) [0x7f0d8f423c0c]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0x225a4c) [0x7f0d8f3fea4c]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0x7e279) [0x7f0d8f257279]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0x83276) [0x7f0d8f25c276]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_EvalFrameEx+0x62d9) [0x7f0d8f391e09]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_EvalFrameEx+0x79d9) [0x7f0d8f393509]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0xd2a98) [0x7f0d8f2aba98]
2017-06-28 04:06:08.372 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_CallObjectWithKeywords+0x47) [0x7f0d8f422897]
2017-06-28 04:06:08.372 Error: /home/caribou/domoticz/domoticz(_ZN7Plugins7CPlugin8CallbackESsPv+0xb9) [0x8e17b9]
2017-06-28 04:06:08.372 Error: /home/caribou/domoticz/domoticz(_ZN7Plugins13CCallbackBase8CallbackEP7_object+0x42) [0x8e9022]
2017-06-28 04:06:08.372 Error: /home/caribou/domoticz/domoticz(_ZN7Plugins13CPluginSystem7Do_WorkEv+0x37c) [0x8ebb8c]
2017-06-28 04:06:08.372 Error: /home/caribou/domoticz/domoticz() [0xa07c4a]
2017-06-28 04:06:08.372 Error: /lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba) [0x7f0d949f16ba]
2017-06-28 04:06:08.372 Error: /lib/x86_64-linux-gnu/libc.so.6(clone+0x6d) [0x7f0d93d913dd]
- Spoiler: show
- 2017-06-29 02:48:38.178 (Broadlink RM2) Calling message handler 'onHeartbeat'.
2017-06-29 02:49:08.319 (Broadlink RM2) Calling message handler 'onHeartbeat'.
2017-06-29 02:49:38.369 (Broadlink RM2) Calling message handler 'onHeartbeat'.
2017-06-29 02:50:08.441 (Broadlink RM2) Calling message handler 'onHeartbeat'.
2017-06-29 02:50:08.450 Error: Domoticz received fatal signal 6 !...
2017-06-29 02:50:08.455 Error: /home/caribou/domoticz/domoticz() [0x5d36e8]
2017-06-29 02:50:08.455 Error: /home/caribou/domoticz/domoticz(_Z14signal_handleri+0x50) [0x5d3790]
2017-06-29 02:50:08.455 Error: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f9a7b0a7390]
2017-06-29 02:50:08.455 Error: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38) [0x7f9a7a36b428]
2017-06-29 02:50:08.455 Error: /lib/x86_64-linux-gnu/libc.so.6(abort+0x16a) [0x7f9a7a36d02a]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(Py_FatalError+0x3f) [0x7f9a75a6b6df]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(_Py_CheckRecursiveCall+0x90) [0x7f9a75a37190]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyObject_Call+0x57) [0x7f9a759fe8d7]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(_PyObject_CallMethodId+0x124) [0x7f9a759fa334]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0x1e664d) [0x7f9a75a6b64d]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(Py_FatalError+0x1a8) [0x7f9a75a6b848]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_EvalFrameEx+0x94c) [0x7f9a75a3847c]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0x24ac0c) [0x7f9a75acfc0c]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_EvalFrameEx+0x62d9) [0x7f9a75a3de09]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_EvalCodeEx+0x23) [0x7f9a75acfce3]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0xd2b95) [0x7f9a75957b95]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyObject_Call+0x6e) [0x7f9a759fe8ee]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_EvalFrameEx+0x2d8b) [0x7f9a75a3a8bb]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0x225a4c) [0x7f9a75aaaa4c]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0x7e279) [0x7f9a75903279]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0x83276) [0x7f9a75908276]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_EvalFrameEx+0x79d9) [0x7f9a75a3f509]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(+0xd2a98) [0x7f9a75957a98]
2017-06-29 02:50:08.455 Error: /usr/lib/x86_64-linux-gnu/libpython3.5m.so(PyEval_CallObjectWithKeywords+0x47) [0x7f9a75ace897]
2017-06-29 02:50:08.455 Error: /home/caribou/domoticz/domoticz(_ZN7Plugins7CPlugin8CallbackESsPv+0xb9) [0x8e1759]
2017-06-29 02:50:08.455 Error: /home/caribou/domoticz/domoticz(_ZN7Plugins13CCallbackBase8CallbackEP7_object+0x42) [0x8e8fc2]
2017-06-29 02:50:08.455 Error: /home/caribou/domoticz/domoticz(_ZN7Plugins13CPluginSystem7Do_WorkEv+0x37c) [0x8ebb2c]
2017-06-29 02:50:08.455 Error: /home/caribou/domoticz/domoticz() [0xa07bea]
2017-06-29 02:50:08.455 Error: /lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba) [0x7f9a7b09d6ba]
2017-06-29 02:50:08.455 Error: /lib/x86_64-linux-gnu/libc.so.6(clone+0x6d) [0x7f9a7a43d3dd]
Any idea to solve this issue? Except that it's working perfectly with my 433Mhz sockets :)
Posted: Thursday 29 June 2017 19:01
by zak45
@caribou
woow... looks like python problem...
You're in Linux so ...Do you have installed the python-dev as explain on this forum ???
I would try another plugin just to see what's happened.. and maybe open a bug !!!
I would not be able to provide any help in this case... sorry.
Posted: Thursday 29 June 2017 19:18
by Phantom
zak45 wrote:Phantom wrote:Thanks, the problem was that i installed it on python 3.4 and then updated to 3.5 when i got the device, so after doing all the step again the plugin starts now.
Tried it, sadly the same result.
- Spoiler: show
- 2017-06-29 19:57:35.202 (Remote RM3 mini) Initialized version 3.0.0, author 'zak45'
2017-06-29 19:57:35.257 (Remote RM3 mini) Debug log level set to: 'true'.
2017-06-29 19:57:35.257 (Remote RM3 mini) Creating device 'Command'.
2017-06-29 19:57:35.260 (Remote RM3 mini) Creating device 'Remote'.
2017-06-29 19:57:35.261 (Remote RM3 mini) Creating device 'Import'.
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Name':'Remote RM3 mini'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Mode3':'no'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Port':'0'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Key':'BroadlinkRM2'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'HomeFolder':'/home/pi/domoticz/plugins/BroadlinkRM2/'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Mode4':'yes'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Mode2':'/home/pi/broadlink/ini'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Version':'3.0.0'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Author':'zak45'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Mode6':'Debug'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Address':'192.168.150.143'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'HardwareID':'9'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Mode5':'9000'
2017-06-29 19:57:35.264 (Remote RM3 mini) 'Mode1':'34ea34b302a5'
2017-06-29 19:57:35.264 (Remote RM3 mini) Device count: 3
2017-06-29 19:57:35.264 (Remote RM3 mini) Device: 1 - ID: 126, Name: 'Remote RM3 mini - Command', nValue: 0, sValue: ''
2017-06-29 19:57:35.264 (Remote RM3 mini) Device ID: '126'
2017-06-29 19:57:35.265 (Remote RM3 mini) Device Name: 'Remote RM3 mini - Command'
2017-06-29 19:57:35.265 (Remote RM3 mini) Device nValue: 0
2017-06-29 19:57:35.265 (Remote RM3 mini) Device sValue: ''
2017-06-29 19:57:35.265 (Remote RM3 mini) Device LastLevel: 0
2017-06-29 19:57:35.265 (Remote RM3 mini) Device: 254 - ID: 127, Name: 'Remote RM3 mini - Remote', nValue: 0, sValue: ''
2017-06-29 19:57:35.265 (Remote RM3 mini) Device ID: '127'
2017-06-29 19:57:35.265 (Remote RM3 mini) Device Name: 'Remote RM3 mini - Remote'
2017-06-29 19:57:35.265 (Remote RM3 mini) Device: 255 - ID: 128, Name: 'Remote RM3 mini - Import', nValue: 0, sValue: ''
2017-06-29 19:57:35.265 (Remote RM3 mini) Device ID: '128'
2017-06-29 19:57:35.265 (Remote RM3 mini) Device Name: 'Remote RM3 mini - Import'
2017-06-29 19:57:35.265 (Remote RM3 mini - Import) Updating device from 0:'' to have values 0:'Off'.
2017-06-29 19:57:35.271 Python: Changed: ID: 128 Name: Remote RM3 mini - Import, Type: 244, subType: 62, switchType: 18, s_value: Off, n_value: 0, n_value_string: Off, last_update_string: 2017-06-29 19:57:35
2017-06-29 19:57:35.271 Python: Number of user_variables: 0
2017-06-29 19:57:35.277 (Remote RM3 mini) Update 0:'Off' (Remote RM3 mini - Import)
2017-06-29 19:57:35.277 (Remote RM3 mini) Connecting to: 192.168.150.143:34ea34b302a5
2017-06-29 19:57:35.289 Error: (Remote RM3 mini) Error Connecting to Broadlink device....
2017-06-29 19:57:35.289 (Remote RM3 mini - Command) Updating device from 0:'' to have values 0:'Off'.
2017-06-29 19:57:35.295 Python: Changed: ID: 126 Name: Remote RM3 mini - Command, Type: 244, subType: 62, switchType: 18, s_value: Off, n_value: 0, n_value_string: Off, last_update_string: 2017-06-29 19:57:35
2017-06-29 19:57:35.295 Python: Number of user_variables: 0
2017-06-29 19:57:35.301 (Remote RM3 mini) Update 0:'Off' (Remote RM3 mini - Command)
2017-06-29 19:57:35.301 (Remote RM3 mini) Device Number begin to : 1
2017-06-29 19:57:35.301 (Remote RM3 mini) No ini file :/home/pi/broadlink/ini/remote/plugin_remote_9.ini
2017-06-29 19:57:35.301 (Remote RM3 mini) Custom Commands for Remote not managed
2017-06-29 19:57:35.301 (Remote RM3 mini) Heartbeat interval set to: 30.
2017-06-29 19:57:44.716 (Remote RM3 mini) Calling message handler 'onHeartbeat'.
2017-06-29 19:57:53.654 Hardware Monitor: Fetching data (System sensors)
2017-06-29 19:57:53.669 Python: Changed: ID: 98 Name: Memory Usage, Type: 243, subType: 6, switchType: 0, s_value: 8.97, n_value: 0, n_value_string: 8.97, last_update_string: 2017-06-29 19:57:53
- Spoiler: show
- 2017-06-29 20:05:09.713 (Remote RM3 mini) Initialized version 3.0.0, author 'zak45'
2017-06-29 20:05:09.719 (Remote RM3 mini) Debug log level set to: 'true'.
2017-06-29 20:05:09.719 (Remote RM3 mini) 'Name':'Remote RM3 mini'
2017-06-29 20:05:09.719 (Remote RM3 mini) 'Mode3':'no'
2017-06-29 20:05:09.719 (Remote RM3 mini) 'Port':'0'
2017-06-29 20:05:09.719 (Remote RM3 mini) 'Key':'BroadlinkRM2'
2017-06-29 20:05:09.719 (Remote RM3 mini) 'HomeFolder':'/home/pi/domoticz/plugins/BroadlinkRM2/'
2017-06-29 20:05:09.719 (Remote RM3 mini) 'Mode4':'yes'
2017-06-29 20:05:09.719 (Remote RM3 mini) 'Mode2':'/home/pi/broadlink/ini'
2017-06-29 20:05:09.719 (Remote RM3 mini) 'Version':'3.0.0'
2017-06-29 20:05:09.719 (Remote RM3 mini) 'Author':'zak45'
2017-06-29 20:05:09.720 (Remote RM3 mini) 'Mode6':'Debug'
2017-06-29 20:05:09.720 (Remote RM3 mini) 'Address':'127.0.0.1'
2017-06-29 20:05:09.720 (Remote RM3 mini) 'HardwareID':'9'
2017-06-29 20:05:09.720 (Remote RM3 mini) 'Mode5':'9000'
2017-06-29 20:05:09.720 (Remote RM3 mini) 'Mode1':'000000000000'
2017-06-29 20:05:09.720 (Remote RM3 mini) Device count: 3
2017-06-29 20:05:09.720 (Remote RM3 mini) Device: 1 - ID: 126, Name: 'Remote RM3 mini - Command', nValue: 0, sValue: 'Off'
2017-06-29 20:05:09.720 (Remote RM3 mini) Device ID: '126'
2017-06-29 20:05:09.720 (Remote RM3 mini) Device Name: 'Remote RM3 mini - Command'
2017-06-29 20:05:09.720 (Remote RM3 mini) Device nValue: 0
2017-06-29 20:05:09.720 (Remote RM3 mini) Device sValue: 'Off'
2017-06-29 20:05:09.720 (Remote RM3 mini) Device LastLevel: 0
2017-06-29 20:05:09.720 (Remote RM3 mini) Device: 254 - ID: 127, Name: 'Remote RM3 mini - Remote', nValue: 0, sValue: ''
2017-06-29 20:05:09.720 (Remote RM3 mini) Device ID: '127'
2017-06-29 20:05:09.720 (Remote RM3 mini) Device Name: 'Remote RM3 mini - Remote'
2017-06-29 20:05:09.720 (Remote RM3 mini) Device sValue: ''
2017-06-29 20:05:09.720 (Remote RM3 mini) Device: 255 - ID: 128, Name: 'Remote RM3 mini - Import', nValue: 0, sValue: 'Off'
2017-06-29 20:05:09.720 (Remote RM3 mini) Device ID: '128'
2017-06-29 20:05:09.721 (Remote RM3 mini) Device Name: 'Remote RM3 mini - Import'
2017-06-29 20:05:09.721 (Remote RM3 mini) Device nValue: 0
2017-06-29 20:05:09.721 (Remote RM3 mini) Device sValue: 'Off'
2017-06-29 20:05:09.721 (Remote RM3 mini) Device LastLevel: 0
2017-06-29 20:05:09.721 (Remote RM3 mini) Connecting to: 127.0.0.1:000000000000
2017-06-29 20:05:09.733 Error: (Remote RM3 mini) Error Connecting to Broadlink device....
2017-06-29 20:05:09.733 (Remote RM3 mini) Device Number begin to : 1
2017-06-29 20:05:09.738 (Remote RM3 mini) No ini file :/home/pi/broadlink/ini/remote/plugin_remote_9.ini
2017-06-29 20:05:09.738 (Remote RM3 mini) Custom Commands for Remote not managed
2017-06-29 20:05:09.738 (Remote RM3 mini) Heartbeat interval set to: 30.
Posted: Thursday 29 June 2017 22:50
by zak45
@Phantom
according your log...
you have used the same Hardware (ID 9) and changed parameters...
please, create another HW using the plugin and click on the discover device to see if it found something.
Posted: Thursday 29 June 2017 23:04
by Phantom
I deleted the old one and made a new one, that is why it has the same nr.
i checked the logging when running the discover and this is what i found:
2017-06-29 22:59:33.608 User: Admin initiated a switch command (126/RM3 Mini - Discover/On)
2017-06-29 22:59:33.627 (RM3 Mini) Calling message handler 'onCommand'.
2017-06-29 22:59:33.628 (RM3 Mini) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2017-06-29 22:59:33.628 (RM3 Mini) All plugin system is on pause for 5s...
2017-06-29 22:59:36.615 Hardware Monitor: Fetching data (System sensors)
2017-06-29 22:59:38.635 (RM3 Mini) Found 1 broadlink devices
2017-06-29 22:59:38.647 Error: (RM3 Mini) 'onCommand' failed 'TypeError':'sequence item 0: expected str instance, bytes found'.
2017-06-29 22:59:38.647 Error: (RM3 Mini) ----> Line 210 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function onCommand
2017-06-29 22:59:38.647 Error: (RM3 Mini) ----> Line 397 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function Discover
2017-06-29 22:59:38.647 Error: (RM3 Mini) ----> Line 203 in /usr/lib/python3.5/broadlink/__init__.py, function auth
2017-06-29 22:59:38.647 Error: (RM3 Mini) ----> Line 258 in /usr/lib/python3.5/broadlink/__init__.py, function send_packet
2017-06-29 22:59:38.647 Error: (RM3 Mini) ----> Line 162 in /usr/lib/python3.5/broadlink/__init__.py, function encrypt_pyaes
Posted: Thursday 29 June 2017 23:49
by zak45
Phantom wrote:I deleted the old one and made a new one, that is why it has the same nr.
2017-06-29 22:59:38.647 Error: (RM3 Mini) ----> Line 162 in /usr/lib/python3.5/broadlink/__init__.py, function encrypt_pyaes[/code]
Ok, looks like the broadlink module had some problem. If you have used one on the dropbox, please forget it.
Uninstall broadlink, and re-install it using pip3 install broadlink plus all extra step for linux
Posted: Friday 30 June 2017 8:04
by rafal
Cleaning up...
Uninstall ALL version of python, then restart windows and with admin right install python 3.4.0 then with admin right pycrypto and setup. If dosen't work try do the same configuration on different windows or machine
Posted: Friday 30 June 2017 11:06
by zak45
@caribou
looks like same problem as you :
viewtopic.php?f=6&t=17905
Posted: Friday 30 June 2017 11:33
by rafal
zak45
Thank You for Broadlink plugin for windows and Your hard work!
Posted: Friday 30 June 2017 12:10
by zak45
rafal wrote:zak45
Thanks a lot Rafal... really appreciate
