Plugin: Travel Times
clubeddie
Re: Plugin: Travel Times
Post by clubeddie »
I am using Domoticz on a Synology. Any change to get it working there?
I placed the extracted zip folder in the plugins directory, /volume1/@appstore/domoticz/var/plugins
But hardware is not visible (also after restart), maybe i am doing something wrong, maybe it is not possible
febalci
Post by febalci »
@clubeddie:
You have to have the version with Python Plugin support Domoticz from jadahl. Also, do not forget to use "chmod +x plugin.py" on the file. Is Python3 package installed on your Synology?
@mastair:
When using onheartbeat more than 50 seconds, you will see this error. I use a counter variable and 10 seconds heartbeat, so when the counter reaches a certain value from the heartbeat, it then executes the necessary todo; then you will not see an error. I am writing a new plugin for my own use on travel times, once it is ready i will share it here.
clubeddie
Post by clubeddie »
febalci wrote: Monday 05 February 2018 8:48 @clubeddie:
I can confirm it is working after updating my domoticz with the python plugin update. So thank you, now waiting for the xiaomi gateway and check if i can build a blockly to change the color of the ring acoording to the percentage of the traffic :lol:
febalci
Post by febalci »
For those who have:
Error: Travel (16) thread seems to have ended unexpectedly
Errors due to long poll times; try this plugin.py:
<plugin key="TravelTimes" name="Travel Times" author="mastair" version="1.0.0">
    <params>
        <param field="Mode1" label="From address" width="200px" required="true"/>
        <param field="Mode2" label="To address" width="200px" required="true"/>
        <param field="Mode5" label="Google API Key" width="200px" required="true"/>
        <param field="Mode6" label="Polling interval (min)" width="40px" required="true"/>
    </params>
</plugin>
import Domoticz
import json
import urllib.request
import urllib.parse
#variables
mode            = "driving"
directionsURL   = "https://maps.googleapis.com/maps/api/directions/json?origin=%s&destination=%s=&transit_mode=driving&departure_time=now&key=%s"
defaultPollingInterval = 2 #Changed From 120 seconds to 2 minutes
pollPeriod = 0 #Added
pollCount = 0 #Added
def onStart():
    global pollCount, pollPeriod
    Domoticz.Debug("onStart called")
    if (len(Devices) == 0):
        Domoticz.Device(Name="Travel time", Unit=1, TypeName="Custom", Options={"Custom": "1;minutes"}).Create()
        Domoticz.Device(Name="Travel delay", Unit=2, TypeName="Custom", Options={"Custom": "1;%"}).Create()
    pollPeriod = 6 * int(Parameters["Mode6"]) #Added, convert minutes to 10 sec periods
    pollCount = pollPeriod - 1 #Added
    Domoticz.Heartbeat(10) #Changed to 10 sec intervals
    return True
def onHeartbeat():
    if pollCount >= pollPeriod: #Added
        updateSensors()
        pollCount = 0 #Reset Pollcount Added
    else: #Added
        pollCount = pollCount + 1 #Added, count until full
    return True
def updateSensors():
    try:
        Domoticz.Debug("getDelay called")
        # Call Directions API
        url = directionsURL % (urllib.parse.quote(fromAddress()), urllib.parse.quote(toAddress()), apiKey())
        request = urllib.request.urlopen(url)
        data = json.loads(request.read().decode('utf-8'))
        if "error_message" in data:
            Domoticz.Error("Error retrieving travel times from Google Maps API: %s" % data["error_message"])
            return
        # Get durations
        normal_duration = int(data["routes"][0]["legs"][0]["duration"]["value"]/60.0)
        current_duration = int(data["routes"][0]["legs"][0]["duration_in_traffic"]["value"]/60.0)
        delay = round((float)(current_duration - normal_duration)/normal_duration*100)
        # Update devices
        if 1 in Devices:
            Devices[1].Update(nValue = current_duration, sValue = str(current_duration))
        if 2 in Devices:
            Devices[2].Update(nValue = delay, sValue = str(delay))
    except:
        Domoticz.Error("Error retrieving travel times from Google Maps API")
####### GETTERS FOR PARAMETERS ########
def pollingInterval():
    try:
        return int(Parameters["Mode6"])
    except:
        Domoticz.Error("Error converting polling interval to integer, using %s seconds as polling interval" %defaultPollingInterval)
        return defaultPollingInterval
def fromAddress():
    return Parameters["Mode1"]
def toAddress():
    return Parameters["Mode2"]
def apiKey():
    return Parameters["Mode5"]
############## NOT USED ##############
def onStop():
    return True
def onConnect(Status, Description):
    return True
def onMessage(Data, Status, Extra):
    return True
def onCommand(Unit, Command, Level, Hue):
    return True
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
    return True
def onDisconnect():
    return True
Please note that polling period is converted into minutes instead of seconds. So now it goes to heartbeat every 10 seconds and check if polling period completed; if not just count; if completed then check google api.
Last edited by febalci on Saturday 10 February 2018 15:57, edited 1 time in total.
tezzlicious
Post by tezzlicious »
febalci wrote: Saturday 10 February 2018 12:29 For those who have:
    <params>
    </params>
</plugin>
import Domoticz
import json
import urllib.parse
#variables
mode            = "driving"
def onStart():
    self.pollPeriod = 6 * int(Parameters["Mode6"]) #Added, convert minutes to 10 sec periods
    self.pollCount = self.pollPeriod - 1 #Added
    return True
def onHeartbeat():
    if self.pollCount >= self.pollPeriod: #Added
        updateSensors()
        self.pollCount = 0 #Reset Pollcount Added
    else: #Added
        self.pollCount = self.pollCount + 1 #Added, count until full
    return True
    try:
            return
        # Get durations
        # Update devices
        if 1 in Devices:
        if 2 in Devices:
    except:
    try:
    except:
def fromAddress():
def toAddress():
def apiKey():
def onStop():
    return True
    return True
    return True
    return True
    return True
def onDisconnect():
    return True
On the latest beta:
'onStart' failed 'NameError':'name 'self' is not defined'.
febalci
Post by febalci »
tezzlicious wrote: Saturday 10 February 2018 14:02
On the latest beta:
Sorry, corrected in the previous message code section.
tezzlicious
febalci wrote: Saturday 10 February 2018 15:58
On the latest beta:
Works like a charm now :D Thanks!
maryannlee9
Post by maryannlee9 »
I am not a topic starter, but had just the same issue. Everything works greatly now due to advices from this thread, I wanted to create a similar topic about travel times, too.
Dnpwwo
Post by Dnpwwo »
Not a bug in Domoticz, it is a behavior designed to pick up 'hardware' related processes (including Python plugins) that have hung or are not responding and is required for troubleshooting.
The plugin wiki documents the 'Heartbeat' functionality and states:
Set the heartbeat interval in seconds, default 10 seconds. Values greater than 30 seconds will cause a message to be regularly logged about the plugin not responding. The plugin will actually function correctly with values greater than 30 though.
If you want to ensure you never get the message, set the value to less than 30.
If the plugin only needs to take action every 5 or 10 minutes then it can be modified to check if is time to act every 10 seconds during a heartbeat using a timer or countdown
