Plugin: Travel Times
clubeddie
Re: Plugin: Travel Times
I am using Domoticz on a Synology. Any change to get it working there?
I placed the extracted zip folder in the plugins directory, /volume1/@appstore/domoticz/var/plugins
But hardware is not visible (also after restart), maybe i am doing something wrong, maybe it is not possible
febalci
@clubeddie:
You have to have the version with Python Plugin support Domoticz from jadahl. Also, do not forget to use "chmod +x plugin.py" on the file. Is Python3 package installed on your Synology?
@mastair:
When using onheartbeat more than 50 seconds, you will see this error. I use a counter variable and 10 seconds heartbeat, so when the counter reaches a certain value from the heartbeat, it then executes the necessary todo; then you will not see an error. I am writing a new plugin for my own use on travel times, once it is ready i will share it here.
@mastair:
clubeddie
I can confirm it is working after updating my domoticz with the python plugin update. So thank you, now waiting for the xiaomi gateway and check if i can build a blockly to change the color of the ring acoording to the percentage of the trafficfebalci wrote: Monday 05 February 2018 8:48 @clubeddie:
febalci
For those who have:
Errors due to long poll times; try this plugin.py:
Please note that polling period is converted into minutes instead of seconds. So now it goes to heartbeat every 10 seconds and check if polling period completed; if not just count; if completed then check google api.
Error: Travel (16) thread seems to have ended unexpectedlyCode: Select all
<plugin key="TravelTimes" name="Travel Times" author="mastair" version="1.0.0">
<params>
<param field="Mode1" label="From address" width="200px" required="true"/>
<param field="Mode2" label="To address" width="200px" required="true"/>
<param field="Mode5" label="Google API Key" width="200px" required="true"/>
<param field="Mode6" label="Polling interval (min)" width="40px" required="true"/>
</params>
</plugin>
import Domoticz
import json
import urllib.request
import urllib.parse
#variables
mode = "driving"
directionsURL = "https://maps.googleapis.com/maps/api/directions/json?origin=%s&destination=%s=&transit_mode=driving&departure_time=now&key=%s"
defaultPollingInterval = 2 #Changed From 120 seconds to 2 minutes
pollPeriod = 0 #Added
pollCount = 0 #Added
def onStart():
global pollCount, pollPeriod
Domoticz.Debug("onStart called")
if (len(Devices) == 0):
Domoticz.Device(Name="Travel time", Unit=1, TypeName="Custom", Options={"Custom": "1;minutes"}).Create()
Domoticz.Device(Name="Travel delay", Unit=2, TypeName="Custom", Options={"Custom": "1;%"}).Create()
pollPeriod = 6 * int(Parameters["Mode6"]) #Added, convert minutes to 10 sec periods
pollCount = pollPeriod - 1 #Added
Domoticz.Heartbeat(10) #Changed to 10 sec intervals
return True
def onHeartbeat():
if pollCount >= pollPeriod: #Added
updateSensors()
pollCount = 0 #Reset Pollcount Added
else: #Added
pollCount = pollCount + 1 #Added, count until full
return True
def updateSensors():
try:
Domoticz.Debug("getDelay called")
# Call Directions API
url = directionsURL % (urllib.parse.quote(fromAddress()), urllib.parse.quote(toAddress()), apiKey())
request = urllib.request.urlopen(url)
data = json.loads(request.read().decode('utf-8'))
if "error_message" in data:
Domoticz.Error("Error retrieving travel times from Google Maps API: %s" % data["error_message"])
return
# Get durations
normal_duration = int(data["routes"][0]["legs"][0]["duration"]["value"]/60.0)
current_duration = int(data["routes"][0]["legs"][0]["duration_in_traffic"]["value"]/60.0)
delay = round((float)(current_duration - normal_duration)/normal_duration*100)
# Update devices
if 1 in Devices:
Devices[1].Update(nValue = current_duration, sValue = str(current_duration))
if 2 in Devices:
Devices[2].Update(nValue = delay, sValue = str(delay))
except:
Domoticz.Error("Error retrieving travel times from Google Maps API")
####### GETTERS FOR PARAMETERS ########
def pollingInterval():
try:
return int(Parameters["Mode6"])
except:
Domoticz.Error("Error converting polling interval to integer, using %s seconds as polling interval" %defaultPollingInterval)
return defaultPollingInterval
def fromAddress():
return Parameters["Mode1"]
def toAddress():
return Parameters["Mode2"]
def apiKey():
return Parameters["Mode5"]
############## NOT USED ##############
def onStop():
return True
def onConnect(Status, Description):
return True
def onMessage(Data, Status, Extra):
return True
def onCommand(Unit, Command, Level, Hue):
return True
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
return True
def onDisconnect():
return True
Last edited by febalci on Saturday 10 February 2018 15:57, edited 1 time in total.
tezzlicious
On the latest beta:febalci wrote: Saturday 10 February 2018 12:29 For those who have:Errors due to long poll times; try this plugin.py:Code: Select all
Please note that polling period is converted into minutes instead of seconds. So now it goes to heartbeat every 10 seconds and check if polling period completed; if not just count; if completed then check google api.Code: Select all
""" <plugin key="TravelTimes" name="Travel Times" author="mastair" version="1.0.0"> <params> <param field="Mode1" label="From address" width="200px" required="true"/> <param field="Mode2" label="To address" width="200px" required="true"/> <param field="Mode5" label="Google API Key" width="200px" required="true"/> <param field="Mode6" label="Polling interval (min)" width="40px" required="true"/> </params> </plugin> """ import Domoticz import json import urllib.request import urllib.parse #variables mode = "driving" directionsURL = "https://maps.googleapis.com/maps/api/directions/json?origin=%s&destination=%s=&transit_mode=driving&departure_time=now&key=%s" defaultPollingInterval = 2 #Changed From 120 seconds to 2 minutes pollPeriod = 0 #Added pollCount = 0 #Added def onStart(): Domoticz.Debug("onStart called") if (len(Devices) == 0): Domoticz.Device(Name="Travel time", Unit=1, TypeName="Custom", Options={"Custom": "1;minutes"}).Create() Domoticz.Device(Name="Travel delay", Unit=2, TypeName="Custom", Options={"Custom": "1;%"}).Create() self.pollPeriod = 6 * int(Parameters["Mode6"]) #Added, convert minutes to 10 sec periods self.pollCount = self.pollPeriod - 1 #Added Domoticz.Heartbeat(10) #Changed to 10 sec intervals return True def onHeartbeat(): if self.pollCount >= self.pollPeriod: #Added updateSensors() self.pollCount = 0 #Reset Pollcount Added else: #Added self.pollCount = self.pollCount + 1 #Added, count until full return True def updateSensors(): try: Domoticz.Debug("getDelay called") # Call Directions API url = directionsURL % (urllib.parse.quote(fromAddress()), urllib.parse.quote(toAddress()), apiKey()) request = urllib.request.urlopen(url) data = json.loads(request.read().decode('utf-8')) if "error_message" in data: Domoticz.Error("Error retrieving travel times from Google Maps API: %s" % data["error_message"]) return # Get durations normal_duration = int(data["routes"][0]["legs"][0]["duration"]["value"]/60.0) current_duration = int(data["routes"][0]["legs"][0]["duration_in_traffic"]["value"]/60.0) delay = round((float)(current_duration - normal_duration)/normal_duration*100) # Update devices if 1 in Devices: Devices[1].Update(nValue = current_duration, sValue = str(current_duration)) if 2 in Devices: Devices[2].Update(nValue = delay, sValue = str(delay)) except: Domoticz.Error("Error retrieving travel times from Google Maps API") ####### GETTERS FOR PARAMETERS ######## def pollingInterval(): try: return int(Parameters["Mode6"]) except: Domoticz.Error("Error converting polling interval to integer, using %s seconds as polling interval" %defaultPollingInterval) return defaultPollingInterval def fromAddress(): return Parameters["Mode1"] def toAddress(): return Parameters["Mode2"] def apiKey(): return Parameters["Mode5"] ############## NOT USED ############## def onStop(): return True def onConnect(Status, Description): return True def onMessage(Data, Status, Extra): return True def onCommand(Unit, Command, Level, Hue): return True def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile): return True def onDisconnect(): return True
'onStart' failed 'NameError':'name 'self' is not defined'.
febalci
Sorry, corrected in the previous message code section.tezzlicious wrote: Saturday 10 February 2018 14:02
On the latest beta:Code: Select all
tezzlicious
Works like a charm nowfebalci wrote: Saturday 10 February 2018 15:58Sorry, corrected in the previous message code section.tezzlicious wrote: Saturday 10 February 2018 14:02
maryannlee9
I am not a topic starter, but had just the same issue. Everything works greatly now due to advices from this thread, I wanted to create a similar topic about travel times, too.
- Dnpwwo
Not a bug in Domoticz, it is a behavior designed to pick up 'hardware' related processes (including Python plugins) that have hung or are not responding and is required for troubleshooting.
The plugin wiki documents the 'Heartbeat' functionality and states:
If the plugin only needs to take action every 5 or 10 minutes then it can be modified to check if is time to act every 10 seconds during a heartbeat using a timer or countdown
If you want to ensure you never get the message, set the value to less than 30.Set the heartbeat interval in seconds, default 10 seconds. Values greater than 30 seconds will cause a message to be regularly logged about the plugin not responding. The plugin will actually function correctly with values greater than 30 though.
