Sonoff Touch Topic is solved
mayyam
Domoticz version: 4.11333
Re: Sonoff Touch
Post by mayyam »
Nice :)
Glad it's finally working.
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
tontze
Domoticz version: Beta Ch
Re: Sonoff Touch
Post by tontze »
Eddiever wrote:I have a Sonoff Touch wall switch. I would like to change it's firmware through ESP Easy. I have been searching but haven't found the right firmware. Due to the fact it is using the 8285 chip instead of 8266.
Does anyone have a suggestion?
Im very new on this esp stuff, can you tell me what hardware and how did you flash it, i have few of these sonoff touches coming :) I have done lots of googleing, and have some sort off idea how to do it, but none have been guide for this sonoff touch :)
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Eddiever
Domoticz version: 2022.1
Re: Sonoff Touch
Post by Eddiever »
Hi Tontze,
I am also very new to this but I will try to help you.
First I used this Youtube video on how to flash. This is about flashing the Sonoff wifi Switch but the basics is the same:
[youtube]https://youtu.be/fN_QKOWvG1s?list=FLEM2 ... sQ8L11mk9w[/youtube]
I used a TTL USB device, bought it from Aliexpress TTL + USB - TTL
But instead of flashing like Youtube you need to use the links provided by mayyam in this thread. Also you need to solder (with steady hands).
Click here to see how to solder.You do need to connect GPIO0 pin to GND to program. This connection can be on during programming.
tontze
Re: Sonoff Touch
Post by tontze »
Eddiever wrote:Hi Tontze,
Ok cool thanx, i do have one of these coming : http://www.ebay.com/itm/USB2-0-To-TTL-S ... SwBLlU7t8J
Would it work with this ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Eddiever
Re: Sonoff Touch
Post by Eddiever »
Looks fine to me. By the way my previous post has been edited with an extra link on how to solder
tontze
Re: Sonoff Touch
Post by tontze »
Nice, cant wait for my sonoff to arrive :P
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
mayyam
Re: Sonoff Touch
Post by mayyam »
Instead of solder, You can use pogo pins and do sort of flasher connector.
_______________
- 2x Xiaomi Gateway
Eddiever
Re: Sonoff Touch
Post by Eddiever »
Can you use that also to connect GPIO0 with ground (which is needed for flashing)?
mayyam
Re: Sonoff Touch
Post by mayyam »
I don't think so. Of course You can touch another (5) to GPIO0, but You have to break the connection after power on. So better use second hand with pin for that.
I've ordered those pins to do my flasher - https://pl.aliexpress.com/item/100pcs-s ... 0.0.3XBYZD
I have about 30 different ESPs (Sonoffs and bare bone ESPs)to flash, so soldering is not an option for me.
_______________
- 2x Xiaomi Gateway
tontze
Re: Sonoff Touch
Post by tontze »
mayyam wrote:I don't think so. Of course You can touch another (5) to GPIO0, but You have to break the connection after power on. So better use second hand with pin for that.
So its needed to ground gpio0 only when esp is booting to get it programming mode ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
mayyam
Re: Sonoff Touch
Post by mayyam »
Yes, won't work constantly connected with my Sonoff Touch.
_______________
- 2x Xiaomi Gateway
tontze
Re: Sonoff Touch
Post by tontze »
Thank you all, got it working :) Just one question, you have rules, where did you add them ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Eddiever
Re: Sonoff Touch
Post by Eddiever »
Hi tontze,
Great you have it working!. Rules need to be enabled. Do this by going to Tools -> Advanced. Then check the box Rules ;)
tontze
Re: Sonoff Touch
Post by tontze »
Eddiever wrote:Hi tontze,
Thanx :)
Do you know if there is a way to reverse blue background led ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
qwerk
Re: Sonoff Touch
Post by qwerk »
I have it working the switch <> domoticz
but no wifi light.
I assume that gpio 12 is the switch for the lamp.
but I also gpio 0 and 13 in this topic.
what is what?
I tried this script,
on button#state do
if [button#state]=1
gpio,12,1
gpio,13,0
endif
endon
on button#state do
if [button#state]=0
gpio,12,0
gpio,13,1
endif
endon
but then my light constantly going on and off ( yes according to the name it should :D )
but that is not what I want.
wifi light on when switched light is off and in reverse.
Westcott
Re: Sonoff Touch
Post by Westcott »
Hi Qwerk,
Is 'button' a Sonoff device, perhaps GPIO0?
You can combine the first 2 lines of your rules -
on button#state=0 do
qwerk
Re: Sonoff Touch
Post by qwerk »
Westcott wrote:Hi Qwerk,
my problem was some much more simpler .
I used the rules as found in this topic. but I was dutch enough to rename button to schakelaar and state to status.
so it would never work.
now it does. I just have to read ........
thanks your answer set me in the right direction
bryan241
Re: Sonoff Touch
Post by bryan241 »
Small hack to get control over the backlight for the touch button:
sonoff touch.jpg (226.81 KiB) Viewed 5097 times
Cut the copper between resistor 102 and pin 'Relay'.
Connect a wire from the cut off resistor to the esp. You can use several GPIO ports, but I used GPIO 9.
In the picture, the background led is now connected to GPIO 9 (pin 4 from bottom of the 8285 as seen in this picture).
Regards,
Bryan
tontze
Re: Sonoff Touch
Post by tontze »
I noticed that my sonoff touch does not change state if domoticz & rflink is down .. Can this be changed ? I have these rules :
on System#Boot do
    gpio,12,1
    timerSet,1,1
  endif
endon
on Rules#Timer=1 do
    gpio,12,0
endon
on button#state do
  if [button#state]=1
    gpio,12,1
    gpio,13,0
    endif
endon
on button#state do
  if [button#state]=0
    gpio,12,0
    gpio13,1
    endif
endon
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Eddiever
Re: Sonoff Touch
Post by Eddiever »
Do you also use the name state in the devices tab?
