Page 2 of 4
Re: Python Plugin: Broadlink RM2 V2
Posted: Wednesday 26 April 2017 23:46
by zak45
michaldobrotka wrote:
zak45
Hi zak45,
I downloaded, unzipped file from Dropbox. I rewrite files in plugins/BroadlinkRM2 but with
sudo pip3 install broadlink
Im still getting error with 0.4 version of tar.gz file. Can you please explain steps how to do it for Dummies?
Thanks and sorry for bothering
donwload python-broadlink-master.zip from dropbox
unzip it
go to unziped folder where you find setup.py
and just enter this command .. don't forget . (dot) at the end
pip install .
this should execute setup.py and install v0.3
Posted: Thursday 27 April 2017 17:47
by jlites00
Zak45- Any idea what this error is?
Is Python 3.5 still necessary? The documentation mentions Python 3.4.
pi@raspberrypi:~ $ sudo pip3 install broadlink
Downloading/unpacking broadlink
  Downloading broadlink-0.4.tar.gz
  Running setup.py (path:/tmp/pip-build-5filbj48/broadlink/setup.py) egg_info for package broadlink
      File "<string>", line 17, in <module>
      File "/tmp/pip-build-5filbj48/broadlink/setup.py", line 12
        except ImportError, e:
    SyntaxError: invalid syntax
    Complete output from command python setup.py egg_info:
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-5filbj48/broadlink
Storing debug log for failure in /root/.pip/pip.log
Posted: Thursday 27 April 2017 23:55
by zak45
jlites00 wrote:Zak45- Any idea what this error is?
Cleaning up...
This is due to a new release that has been pushed to pypi, version 0.4, of broadlink. This one has compatibility problem but hope should be solved soon.
In the meantime, see post just before.
Posted: Friday 28 April 2017 4:49
by jlites00
still getting an error after copying the BroadlinkRM2 folder into Plugins. Anyway, will wait for the fix. I couldn't get Discover to work so I included the IP & Mac manually.
2017-04-28 02:32:19.377 Domoticz V3.7377 (c)2012-2017 GizMoCuz
2017-04-28 02:32:19.378 Build Hash: a639bbe, Date: 2017-04-27 14:10:44
2017-04-28 02:32:19.378 System: Raspberry Pi
2017-04-28 02:32:19.378 Startup Path: /home/pi/domoticz/
2017-04-28 02:32:20.232 PluginSystem: Started, Python version '3.4.2'.
2017-04-28 02:32:20.254 Active notification Subsystems: gcm, http (2/12)
2017-04-28 02:32:20.341 WebServer(HTTP) started on address: :: with port 8080
2017-04-28 02:32:20.403 WebServer(SSL) started on address: :: with port 443
2017-04-28 02:32:20.404 Proxymanager started.
2017-04-28 02:32:20.405 Starting shared server on: :::6144
2017-04-28 02:32:20.406 TCPServer: shared server started...
2017-04-28 02:32:20.406 RxQueue: queue worker started...
2017-04-28 02:32:22.407 EventSystem: reset all events...
2017-04-28 02:32:22.426 EventSystem: reset all device statuses...
2017-04-28 02:32:22.427 EventSystem: Started
2017-04-28 02:32:22.769 PluginSystem: Entering work loop.
2017-04-28 02:32:32.461 Incoming connection from: 192.168.1.78
2017-04-28 02:40:25.596 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/BroadlinkRM2/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2017-04-28 02:40:25.596 Error: (Broadlink) Module Import failed, exception: 'ImportError'
2017-04-28 02:40:25.596 Error: (Broadlink) Module Import failed: ' Name: Crypto'
2017-04-28 02:41:30.773 Error: Broadlink hardware (2) thread seems to have ended unexpectedly
2017-04-28 02:42:00.779 Error: Broadlink hardware (2) thread seems to have ended unexpectedly
2017-04-28 02:42:30.784 Error: Broadlink hardware (2) thread seems to have ended unexpectedly
2017-04-28 02:43:00.790 Error: Broadlink hardware (2) thread seems to have ended unexpectedly
2017-04-28 02:43:30.797 Error: Broadlink hardware (2) thread seems to have ended unexpectedly
2017-04-28 02:44:00.803 Error: Broadlink hardware (2) thread seems to have ended unexpectedly
2017-04-28 02:44:26.757 (Broadlink) Stopped.
2017-04-28 02:44:27.005 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/BroadlinkRM2/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2017-04-28 02:44:27.005 Error: (Broadlink) Module Import failed, exception: 'ImportError'
2017-04-28 02:44:27.005 Error: (Broadlink) Module Import failed: ' Name: Crypto'
2017-04-28 02:45:30.838 Error: Broadlink hardware (2) thread seems to have ended unexpectedly
2017-04-28 02:45:56.905 (Broadlink) Stopped.
2017-04-28 02:45:57.133 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/BroadlinkRM2/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2017-04-28 02:45:57.133 Error: (Broadlink) Module Import failed, exception: 'ImportError'
2017-04-28 02:45:57.133 Error: (Broadlink) Module Import failed: ' Name: Crypto'
2017-04-28 02:46:49.289 EventSystem: reset all device statuses...
2017-04-28 02:47:00.853 Error: Broadlink hardware (2) thread seems to have ended unexpectedly
Posted: Friday 28 April 2017 6:46
by michaldobrotka
zak45
Thanks man, great plugin! Can now turn of my rm-bridge :D
Posted: Friday 28 April 2017 9:03
by jlites00
zak45
Hi zak45,
unzip it
pip install .
do you mean like this "setup.py.."
"sudo pip3 install. broadlink"
Posted: Friday 28 April 2017 12:00
by zak45
zak45
great you like it, enjoy!
Posted: Friday 28 April 2017 12:02
by zak45
jlites00 wrote:
zak45 wrote:
michaldobrotka wrote: Hi zak45,
unzip it
pip install .
go to the unzipped folder where you can find setup.py
enter this command:
pip3 install .
do not forget . (dot) at the end
Posted: Friday 28 April 2017 16:06
by jlites00
Zak45-
enter this command:
pip3 install .
Gave it a shot but I get the following even though I see setup.py in the folder.
pi@raspberrypi:~ $ pip3 install .
Directory '.' is not installable. File 'setup.py' not found.
pi@raspberrypi:~ $
[img]
Screen Shot 2017-04-28 at 10.07.58 PM.png (396.22 KiB) Viewed 4687 times
[/img]
Re: RE: Re: Python Plugin: Broadlink RM2 V2
Posted: Friday 28 April 2017 20:38
by shoyboom
shoyboom wrote:Hi, i installed it and can learn new switch but I cannot manage to start smart web server.
I get this message on log.
Am i doing something wrong? Image
Sent from my ONEPLUS A3000 using Tapatalk
Hi, could someone help I cannot activate smart web server?
Posted: Friday 28 April 2017 21:33
by zak45
enter this command:
pip3 install .
pi@raspberrypi:~ $
[img]Screen%20Shot%202017-04-28%20at%2010.07.58%20PM.png[/img]
strange as this work on my windows version.
do not have any linux, so not able to test but this is what i have seen on the web and that you can try :
pip install /full/path/of/your/broadlink/folder
Have seen your screenshot and just FYI: there is too much files on the plugins folder, see wiki.
You should put others files somewhere else, will be better.
Posted: Friday 28 April 2017 21:34
by zak45
can you post full log file, please ?
Posted: Friday 28 April 2017 21:49
by zak45
try with port number > 1024
Posted: Friday 28 April 2017 21:52
by shoyboom
I tried with 9000. Same error.
Where can I find full log?
Posted: Saturday 29 April 2017 11:03
by zak45
@shoyboom
put the plugin on debug mode, apply update.
execute the web server.
go to domoticz log, copy and paste all informations.
FYI: the webserver is not required for import, it's here only to provide a file transfert feature, but this can be done by any other way.
Posted: Saturday 29 April 2017 15:06
by DrJS
zak45
Hi zak45,
unzip it
pip install .
Hi, I was having this exact problem too, so was very grateful for your advice! I downloaded the setup.py for 0.3 as you suggest - however, although Python tells me Broadlink is installed as a package, there's no broadlink folder under the python dist-packages folder so doing the
"sudo cp -r /usr/local/lib/python3.4/dist-packages/broadlink /usr/lib/python3.4/" fails.
Any idea why I'm not getting that folder created? Obviously my system isn't working... :cry: Thanks in advance. Jeremy.
Posted: Saturday 29 April 2017 18:06
by zak45
@DrJS
hi, maybe you have mixed python version i.e; 2.7.x & 3.x ?? !!
if this is the case, pip command would install on the default one, which is probable 2.7.
you need to use pip3 if i'm not wrong, but first I would uninstall broadlink from 2.7 (pip uninstall broadlink)
Posted: Saturday 29 April 2017 19:44
by shoyboom
zak45 wrote:@shoyboom
Hi, here's the log.
2017-04-29 20:37:55.718 (RM PRO) Device Name: 'RM PRO - 12-28 yes'
2017-04-29 20:37:55.719 (RM PRO) Device nValue: 0
2017-04-29 20:37:55.719 (RM PRO) Device sValue: ''
2017-04-29 20:37:55.719 (RM PRO) Device LastLevel: 0
2017-04-29 20:37:55.719 (RM PRO) Device: 29 - ID: 102, Name: 'RM PRO - 12-29 yes', nValue: 0, sValue: ''
2017-04-29 20:37:55.719 (RM PRO) Device ID: '102'
2017-04-29 20:37:55.719 (RM PRO) Device Name: 'RM PRO - 12-29 yes'
2017-04-29 20:37:55.719 (RM PRO) Device: 30 - ID: 103, Name: 'RM PRO - 12-30 yes', nValue: 0, sValue: ''
2017-04-29 20:37:55.719 (RM PRO) Device ID: '103'
2017-04-29 20:37:55.719 (RM PRO) Device Name: 'RM PRO - 12-30 yes'
2017-04-29 20:37:55.719 (RM PRO) Device: 31 - ID: 104, Name: 'RM PRO - 12-31 yes', nValue: 0, sValue: ''
2017-04-29 20:37:55.719 (RM PRO) Device ID: '104'
2017-04-29 20:37:55.719 (RM PRO) Device Name: 'RM PRO - 12-31 yes'
2017-04-29 20:37:55.719 (RM PRO) Device: 32 - ID: 105, Name: 'RM PRO - 12-32 TV', nValue: 0, sValue: ''
2017-04-29 20:37:55.719 (RM PRO) Device ID: '105'
2017-04-29 20:37:55.719 (RM PRO) Device Name: 'RM PRO - 12-32 TV'
2017-04-29 20:37:55.719 (RM PRO) Device: 33 - ID: 106, Name: 'RM PRO - 12-33 Wohnzimmer Wohnzimmer hoch', nValue: 1, sValue: 'On-7'
2017-04-29 20:37:55.719 (RM PRO) Device ID: '106'
2017-04-29 20:37:55.719 (RM PRO) Device Name: 'RM PRO - 12-33 Wohnzimmer Wohnzimmer hoch'
2017-04-29 20:37:55.719 (RM PRO) Device nValue: 1
2017-04-29 20:37:55.719 (RM PRO) Device sValue: 'On-7'
2017-04-29 20:37:55.719 (RM PRO) Device: 34 - ID: 107, Name: 'RM PRO - 12-34 yes', nValue: 0, sValue: ''
2017-04-29 20:37:55.719 (RM PRO) Device ID: '107'
2017-04-29 20:37:55.719 (RM PRO) Device Name: 'RM PRO - 12-34 yes'
2017-04-29 20:37:55.720 (RM PRO) Device: 35 - ID: 108, Name: 'RM PRO - 12-35 yes', nValue: 0, sValue: ''
2017-04-29 20:37:55.720 (RM PRO) Device ID: '108'
2017-04-29 20:37:55.720 (RM PRO) Device Name: 'RM PRO - 12-35 yes'
2017-04-29 20:37:55.720 (RM PRO) Device nValue: 0
2017-04-29 20:37:55.720 (RM PRO) Device sValue: ''
2017-04-29 20:37:55.720 (RM PRO) Device LastLevel: 0
2017-04-29 20:37:55.720 (RM PRO) Device: 36 - ID: 109, Name: 'RM PRO - 12-36 yes', nValue: 0, sValue: ''
2017-04-29 20:37:55.720 (RM PRO) Device ID: '109'
2017-04-29 20:37:55.720 (RM PRO) Device Name: 'RM PRO - 12-36 yes'
2017-04-29 20:37:55.720 (RM PRO) Device: 37 - ID: 110, Name: 'RM PRO - 12-37 Wohnzimmer Wohnzimmer runter', nValue: 1, sValue: 'On-11'
2017-04-29 20:37:55.720 (RM PRO) Device ID: '110'
2017-04-29 20:37:55.720 (RM PRO) Device Name: 'RM PRO - 12-37 Wohnzimmer Wohnzimmer runter'
2017-04-29 20:37:55.720 (RM PRO) Device nValue: 1
2017-04-29 20:37:55.720 (RM PRO) Device sValue: 'On-11'
2017-04-29 20:37:55.720 (RM PRO) Device: 38 - ID: 111, Name: 'מזגן סלון קירור', nValue: 1, sValue: 'On-8'
2017-04-29 20:37:55.720 (RM PRO) Device ID: '111'
2017-04-29 20:37:55.720 (RM PRO) Device Name: 'מזגן סלון קירור'
2017-04-29 20:37:55.720 (RM PRO) Device sValue: 'On-8'
2017-04-29 20:37:55.720 (RM PRO) Device: 39 - ID: 112, Name: 'מזגן סלון חום', nValue: 1, sValue: 'On-7'
2017-04-29 20:37:55.720 (RM PRO) Device ID: '112'
2017-04-29 20:37:55.720 (RM PRO) Device Name: 'מזגן סלון חום'
2017-04-29 20:37:55.720 (RM PRO) Device sValue: 'On-7'
2017-04-29 20:37:55.720 (RM PRO) Device: 40 - ID: 113, Name: 'מזגן סלון כיבוי', nValue: 1, sValue: 'On-9'
2017-04-29 20:37:55.720 (RM PRO) Device ID: '113'
2017-04-29 20:37:55.720 (RM PRO) Device Name: 'מזגן סלון כיבוי'
2017-04-29 20:37:55.720 (RM PRO) Device sValue: 'On-9'
2017-04-29 20:37:55.720 (RM PRO) Device: 255 - ID: 73, Name: 'RM PRO - Import', nValue: 0, sValue: 'Off'
2017-04-29 20:37:55.720 (RM PRO) Device ID: '73'
2017-04-29 20:37:55.720 (RM PRO) Device Name: 'RM PRO - Import'
2017-04-29 20:37:55.721 (RM PRO) Device nValue: 0
2017-04-29 20:37:55.721 (RM PRO) Device sValue: 'Off'
2017-04-29 20:37:55.721 (RM PRO) Device LastLevel: 40
2017-04-29 20:37:55.721 (RM PRO) Connecting to: 192.168.31.92:34EA34E7E481
2017-04-29 20:37:55.761 (RM PRO) Connected to Broadlink device.
2017-04-29 20:37:55.761 (RM PRO) Device Number begin to : 39
2017-04-29 20:37:55.761 (RM PRO) Heartbeat interval set to: 30.
2017-04-29 20:38:00.338 LUA: pingTV success
2017-04-29 20:38:02.456 LUA: pingMEMIR success
2017-04-29 20:38:00.355 (dummy) Lighting 1 (Pingtv)
2017-04-29 20:38:02.502 (dummy) Lighting 1 (pingmemeir)
2017-04-29 20:38:05.228 (RM PRO) Calling message handler 'onHeartbeat'.
2017-04-29 20:38:05.269 (RM PRO - Temp) Updating device from 1:'26.0' to have values 1:'25.4'.
2017-04-29 20:38:05.271 (RM PRO) Update 1:'25.4' (RM PRO - Temp)
2017-04-29 20:38:05.289 User: shoyboom initiated a switch command (73/RM PRO - Import/Set Level)
2017-04-29 20:38:05.321 (RM PRO) Calling message handler 'onCommand'.
2017-04-29 20:38:05.322 (RM PRO) onCommand called for Unit 255: Parameter 'Set Level', Level: 10 , Connected : True
2017-04-29 20:38:05.343 Error: (RM PRO) 126
2017-04-29 20:38:05.343 Error: (RM PRO) /home/pi/domoticz/plugins/BroadlinkRM2/plugin_http.sh 0.0.0.0 9000 /usr/local/lib/python3.4/dist-packages/
2017-04-29 20:38:05.343 Error: (RM PRO) None
2017-04-29 20:38:05.343 Error: (RM PRO) Not able to start Web server
2017-04-29 20:38:25.076 Hardware Monitor: Fetching data (System sensors)
2017-04-29 20:38:35.247 (RM PRO) Calling message handler 'onHeartbeat'.
2017-04-29 20:38:55.125 Hardware Monitor: Fetching data (System sensors)
Posted: Saturday 29 April 2017 20:50
by zak45
@shoyboom
need your configuration page and content of /home/pi/domoticz/plugins/BroadlinkRM2/plugin_http.sh
Posted: Saturday 29 April 2017 20:56
by shoyboom
Here it is. Thank you. ImageImage
