Page 2 of 11
Re: framb0ise v2 - awesome new dashboard!
Posted: Sunday 23 April 2017 11:44
by safi78
Hi Guys,
It's probably more efficient if you add your suggestions, requests, etc to the 'issues' page of the project:
https://github.com/safi78/framb0ise/issues
Posted: Sunday 23 April 2017 12:21
by kniazio
I'll add the 'PushButton On' in a minute
Please add
Posted: Sunday 23 April 2017 12:25
by safi78
kniazio wrote:
Please add
done
Posted: Sunday 23 April 2017 12:26
by safi78
The certificate issue with crossorigin.me is fixed as well, so Darksky should work as normal.
Posted: Sunday 23 April 2017 12:59
by jvdz
tontze wrote:
But, on my setup, blinds just shows its tate, no control buttons
I had a try today as well and really like this approach!
I've made a fix for the Blinds as I saw the same thing and this also takes the device.MaxDimLevel into account to avoid getting a percentage problem.
Just edit framboise.js and replace/insert these lines:
case "Dimmer":
if (device.Data == 'Off') {
switchClass = 'btn btn-success btn-primary glyphicon glyphicon-off active';
} else {
switchClass = 'btn btn-warning btn-primary glyphicon glyphicon-off active';
$("#td-" + device.idx).html('<div class="slider-div"><input type="text" id="slider-' + device.idx + '" data-slider-value="' + device.LevelInt + '" data-slider-min="0" data-slider-max="' + device.MaxDimLevel + '" data-slider-tooltip="hide" /> <button class="'+switchClass+'" Onclick="switchLight(' + device.idx + ')"></button></div>');
$("#slider-" + device.idx).slider();
$("#slider-" + device.idx).on("slideStop", function(slideEvt) {
setDimmer(device.idx, slideEvt.value);
break;
case "Blinds Percentage":
if (device.Data == 'Open') {
} else {
$("#td-" + device.idx).html('<div class="slider-div"><input type="text" id="slider-' + device.idx + '" data-slider-value="' + device.LevelInt + '" data-slider-min="0" data-slider-max="' + device.MaxDimLevel + '" data-slider-step="1" data-slider-tooltip="hide" /> <button class="'+switchClass+'" Onclick="switchLight(' + device.idx + ')"></button></div>');
break;
case "Motion Sensor":
@safi78, maybe you can update your version or do you want me to create a pull request? (I am new to git, but used to CVS/SVN)
Jos
Posted: Sunday 23 April 2017 13:06
by safi78
Hi jvdz,
Thanks, added!
I think in the future pull requests are better. Still trying to get used to Github myself as well
Posted: Sunday 23 April 2017 13:29
by jvdz
Will do some searching for a dummies guide to GIT and reading on how this needs to be done as it seems to work quite differently from CVS/SVN versioning.
Jos
Posted: Sunday 23 April 2017 13:31
by safi78
Jos
This was useful for me:
https://github.com/Roshanjossey/first-c ... /README.md
It's a 'devious' process for starters ... lol
Posted: Sunday 23 April 2017 14:31
by safi78
added 'Smoke Detectors'.
Posted: Sunday 23 April 2017 15:47
by Maikie
It could be me but I cannot get it to work. This is what I did to install
1. Open a putty connection to raspberry and browse to my domoticz / www folder
2. From there I ran the command - git clone
3. After that finished I opened the framb0ise folder and nano the config.js file. (The file was ampty and I added the link to my domoticz)
When I now browse to my domoticz url with /framb0ise I get the domoticz offline message.
What did I do wrong?
Posted: Sunday 23 April 2017 16:04
by andi216
I have a FA20RF smoke detector.
In page icon smoke detector does not change the status (is red) even if the sensor is on or off.
Posted: Sunday 23 April 2017 16:24
by jvdz
I had the same and had to add /index.html to the end of the url.
Jos
Posted: Sunday 23 April 2017 16:27
by Maikie
Jos
That indeed did the trick, thanks!
Posted: Sunday 23 April 2017 17:03
by safi78
andi216 wrote:I have a FA20RF smoke detector.
Hmm. that's weird. What doest the 'Status' in domoticz say?
Doest it say "Normal" or "On"? Maybe I made a mistake there.
Posted: Sunday 23 April 2017 17:07
by kniazio
Gentlemen.
Do not you think it should be the other way round
Button XBox-1 should be green
Posted: Sunday 23 April 2017 17:18
by safi78
kniazio wrote:Gentlemen.
makes sense. Try the new update
Posted: Sunday 23 April 2017 17:20
by andi216
I've refreshed the page too
Posted: Sunday 23 April 2017 17:22
by safi78
Thanks, mine say "Normal' instead of 'Off', i'll change that right away.
Posted: Sunday 23 April 2017 17:25
by safi78
can you test the new version?
Posted: Sunday 23 April 2017 17:33
by andi216
Nothing changed
