Re: "Hack" eBay camera to get access to videostream?
Posted: Wednesday 28 June 2017 18:36
good work, i actually have ipcam viewer pro for Android on my phone will give it a shot, cheers
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
root:$6$msTRRedr$e7Fw3JVflNlRZrIbR1f0qlKLpDnbvd4OuyEJEKBIYs04vylb9IrSKUO4Ldg56tdR1Qk5YPUeV/8PjFLiUFRVM1:0:0::/root:/bin/shCode: Select all
# telnet 192.168.x.x
Trying 192.168.x.x...
Connected to 192.168.x.x.
Escape character is '^]'.
IPC365 login: root
Password:
login: can't chdir to home directory '/root'
Welcome to
_____ __ ___ __ ___ _ _ _
| ___| / \ / __ \ / \ | _ \ / \ \ \ / /
| |___ / /\ \ | /__\ \ / /\ \ | | \ | / /\ \ \ V /
| ___|| |__| | | _ / | |__| | | | | | | |__| | \ /
| | | __ | | | \ \ | __ | | |_/ / | __ | | |
|_| |_| |_| |_| \_\|_| |_| |___ / |_| |_| |_|
For further information check:
http://www.faraday.com/
BusyBox v1.19.4 (2014-12-19 12:49:44 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
[root@GM]#Code: Select all
Name: (What you want, you'll need it later, I put IPC365)
url: dvrip://admin:123456@<IP Address of the camera>?channel=0&subtype=0Code: Select all
type: custom:webrtc-camera
url: IPC365 <---- The name you had to put in before
ui: true
digital_ptz:
mouse_drag_pan: true
mouse_wheel_zoom: true
mouse_double_click_zoom: true
touch_drag_pan: true
touch_pinch_zoom: true
touch_tap_drag_zoom: true
persist: true
title: What you want
muted: true
intersection: 0."?"75
background: false
shortcuts:
- name: Record
icon: mdi:record-circle-outline
service: switch."?"toggle
service_data:
entity_id: switch."?"camera_record
mode: webrtc,mse,hls,mjpeg
