Python Plugin: Samsung TV
EdwinK
Re: Python Plugin: Samsung TV
Post by EdwinK »
Thanks. Going to try this.
root@DiskStation:/volume3/@appstore/domoticz/var/scripts/python# pip3 intall samsungctl
-ash: pip3: command not found
Before that I already did a 'sudo -i' (something that Synology wants instead of just plain sudo'.
DennisD
Post by DennisD »
Python 3.x is installed?
EdwinK
Post by EdwinK »
DennisD wrote:Python 3.x is installed?
I thought I had. But now it says 2.7.12
But on the Synology paackage screen I get this
Python versions installed
Screen Shot 2017-05-14 at 17.45.20.png (41.87 KiB) Viewed 5733 times
DennisD
Post by DennisD »
Not sure then on the Synology, i'm working with a raspberry pi 3 so slightly different
EdwinK
Post by EdwinK »
Thanks anyway.
kingoifsnake74
Post by kingoifsnake74 »
Anyone? synology python is driving me nuts. 017-05-14 19:32:48.485 Error: (SamsungTV) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/samsungctl/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.
2017-05-14 19:32:48.485 Error: (samsung tv) Module Import failed, exception: 'ImportError'
2017-05-14 19:32:48.485 Error: (samsung tv) Module Import failed: ' Name: samsungctl'
EdwinK
Post by EdwinK »
kingoifsnake74 wrote:Anyone? synology python is driving me nuts. 017-05-14 19:32:48.485 Error: (SamsungTV) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/samsungctl/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.
Got the same settings (minus the python35.zip). Still driving me nuts too. As you see a few posts up, having problems with the 'test' phase. i do have various Python packages, but still it failed. With python --version I get Python 2.7.12 Why has Synology have to make it so difficult to instal this
kingoifsnake74
I completely reinstalled everything in my synology. Firtst the python 3.5 module then domoticz. Pip etc. At the end still the same problems. Synology and python is a no go for me. Perhaps i will install domoticz on a rpi this weekeind thanx dor the tips btw.
EdwinK
Post by EdwinK »
kingoifsnake74 wrote:I completely reinstalled everything in my synology. Firtst the python 3.5 module then domoticz. Pip etc. At the end still the same problems. Synology and python is a no go for me. Perhaps i will install domoticz on a rpi this weekeind thanx dor the tips btw.
Just my idea. Now... where did I put that spare RPi
DennisD
Post by DennisD »
Keep in mind that the samsungctl doens't work on all types of samsung smart tv's. Mine is a ue55JU7000 and although the plugin, receives the on/off status, i cannot control my tv with it.
bertbigb
Post by bertbigb »
I have a nice Samsung TV and want to control it from Domoticz.
I followed the wiki and have the following problems at this moment:
bert@DS1515:~$ samsungctl -i --host 192.168.2.15 --method websocket
  File "/bin/samsungctl", line 11, in <module>
    sys.exit(main())
  File "/usr/lib/python2.7/site-packages/samsungctl/__main__.py", line 93, in main
    config = _read_config()
  File "/usr/lib/python2.7/site-packages/samsungctl/__main__.py", line 37, in _read_config
    except FileNotFoundError:
NameError: global name 'FileNotFoundError' is not defined
Anyone an idea what I can / have to do to get this solved? Help is appreciated.
Best regards Bert
Synology DS1517+ - DSM 6.2
zak45
Domoticz version: V2024.4
Post by zak45 »
bertbigb wrote:Hello,
    sys.exit(main())
/usr/lib/python2.7/site-packages/samsungctl/ --> this show that you have installed on python version 2.7
Plugin system need python 3.x !
bertbigb
Post by bertbigb »
zak45 wrote: /usr/lib/python2.7/site-packages/samsungctl/ --> this show that you have installed on python version 2.7
Hi Zak,
Thanks for your answer. I have a synology and on that one python 2.7 and 3.5 is installed.
Ok, now i know this is the trouble I'm going to switch over too another forum (Synology) to ask there how I can achieve that Synology will run with Python 3.5.
Best regards Bert
Drikus
Post by Drikus »
Got it work on my Synology. Originally I got the same error, then I had a quick look in the plugin.py:
if sys.platform.startswith('linux'):
    # linux specific code here
    sys.path.append(os.path.dirname(os.__file__) + '/diste-packages')
change this to:
    sys.path.append(os.path.dirname(os.__file__) + '/site-packages')
zak45
Post by zak45 »
@Drikus
thanks for this TIP.
if someone else using Synology can confirm.. then will add that to the wiki.
kingoifsnake74
Sorry can't confirm stopped with synology, rpi now....
pablolassalle
Post by pablolassalle »
Zak, I could not get the interactive control from the command line to work.
I have a Samsung J model from 2016, and I use this command line to test it:
sudo samsungctl -i --host 192.168.0.8 --port 8001 --method websocket
but when i use any key, the TV does not respond to any of them.
Do you know what can be the issue?
This is the log from the plugin
2017-08-07 19:44:39.448 User: Admin initiated a switch command (41/Samsung TV - Volume/Set Level)
2017-08-07 19:44:39.456 (Samsung TV) Calling message handler 'onCommand'.
2017-08-07 19:44:39.457 (Samsung TV) onCommand called for Unit 3: Parameter 'Off', Level: 0, Connected: True
2017-08-07 19:44:39.460 Error: (Samsung TV) 'onCommand' failed 'ImportError'.
2017-08-07 19:44:39.460 Error: (Samsung TV) ----> Line 177 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function onCommand
2017-08-07 19:44:39.460 Error: (Samsung TV) ----> Line 287 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function SamsungSend
2017-08-07 19:44:39.460 Error: (Samsung TV) ----> Line 10 in /usr/lib/python3.4/samsungctl/remote.py, function __init__
2017-08-07 19:44:39.460 Error: (Samsung TV) ----> Line 13 in /usr/lib/python3.4/samsungctl/remote_websocket.py, function __init__
2017-08-07 19:44:39.511 (Samsung TV) Calling message handler 'onHeartbeat'.
2017-08-07 19:44:39.514 (Samsung TV) isAlive status :True
If someone has an idea of what can be happening, I'll be glad to hear from you.
gijsje
Domoticz version: Stable
Post by gijsje »
Did you find a solution for this?
I do have the same problem
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
zak45
Post by zak45 »
pablolassalle wrote: Tuesday 08 August 2017 0:51 Zak, I could not get the interactive control from the command line to work.
maybe similar:
https://github.com/Ape/samsungctl/issues/22
zak45
Post by zak45 »
v2 released. Now with Kodi like remote feature.
