All kinds of 'OS' scripts
supergroover
Posts: 23 Joined: Friday 12 July 2013 19:37
Post
by supergroover » Thursday 17 January 2019 21:31
I get this error and I really don't know why.
Can someone point me in the right direction?
+ echo Interface: vmx0
Interface: vmx0
+ echo Calculating bandwidth per 60 seconds in mbps... (wait 60 seconds)
+ + snmpwalk -c public -v 2c 192.168.1.1 .1.3.6.1.2.1.2.2.1.10.1
awk { print $4 }
+ waninkb=4269204041
+ + awksnmpwalk { print $4 } -c
public -v 2c 192.168.1.1 .1.3.6.1.2.1.2.2.1.16.1
+ wanoutkb=1721606739
+ sleep 60
+ + snmpwalkawk -c { print $4 } public
+ waninkb2=4271093885
+ + awksnmpwalk -c { print $4 } public
+ wanoutkb2=1721765333
+ + bc -l
echo 251976
+ inbits=251976
+ + bcecho -l scale=2; 251976 / 1000000
+ inmegabits=.25
+ + bcecho -l 21144
+ outbits=21144
+ + bcecho scale=2; 21144 / 1000000 -l
+ outmegabits=.02
+ + echobc -l 251976 > 2
+ 1
./update.sh: 57: ./update.sh: 1: not found
+ echo There was a problem getting the data
+ true
+ echo
+ echo
ben53252642
Posts: 543 Joined: Saturday 02 July 2016 5:17
Post
by ben53252642 » Thursday 17 January 2019 21:41
What is with all the +'s? How did you get that text?
ben53252642
Post
by ben53252642 » Friday 18 January 2019 11:01
That's the problem right there, at the top of the script it tells your system to execute the script using the BASH command line processor.
You are manually over-riding that and causing the incompatibility by trying to start the script with the SH command line processor.
Try: ./update.sh
Note if you need to make the script executable (which is only needed a single time) use: chmod 755 update.sh
supergroover
Post
by supergroover » Friday 18 January 2019 13:03
ben53252642 wrote: ↑ Friday 18 January 2019 11:01
Try: ./update.sh
Thank you for your help.
I also had to change:
# Do math for Mbps
inbits=$(echo $((("$waninkb2"-"$waninkb") / 60 * 8)) | bc -l)
inmegabits=$(echo "scale=2; $inbits / 1000000" | bc -l)
outbits=$(echo $((("$wanoutkb2"-"$wanoutkb") / 60 * 8)) | bc -l)
outmegabits=$(echo "scale=2; $outbits / 1000000" | bc -l)
In:
# Do math for Mbps
inbits=$(echo $((($waninkb2-$waninkb) / 60 * 8)) | bc -l)
outbits=$(echo $((($wanoutkb2-$wanoutkb) / 60 * 8)) | bc -l)
Do you know how i got the total download and upload per day?
ben53252642
Post
by ben53252642 » Friday 18 January 2019 13:26
Total usage per day is currently not a feature.
Only the current bandwidth utilization in Mbps.
Cletus
Posts: 54 Joined: Wednesday 17 August 2016 9:32
Domoticz version: Latest
Post
by Cletus » Wednesday 30 October 2019 14:37
Hi, I dove into this thing again as i still had the old script of you ben53252642 running but it was not working anymore. I made an update only for the total datatraffic used. Please see the script below. Change accordingly and it will work (at least for me)
#!/bin/bash
# Requirements (for Debian / Ubuntu and Raspbian based systems): apt-get install jq bc libxml2-utils
# Send PFSense Monthly Upload / Download data to Domoticz
# Original script made by: ben53252642 on the forum of Domoticz
# URL: https://www.domoticz.com/forum/viewtopic.php?t=16297
# Adjusted to accomodate new cookie logins, domoticz username and password, easy idx configuration
# https login for Domoticz and PFSense (PFSense default 443 only)
# by Paul Bonnemaijers (Cletus) 30 oktober 2019
# Configuration of script
# pfsense configuration
pfsenseipaddress="x.x.x.x"
pfusername="user"
pfpassword="pass"
# Domoticz Configuration
domoticzserver="x.x.x.x"
domoticzport="443"
domoticzuser="user"
domoticzpass="pass"
rxidx="1"
txidx="2"
# Done configuring, don't change anything below here unless you are sure :)
# Clear Cookies and CSRF to be sure
function clear_cookies {
if [ -f cookies.txt ] && [ -f csrf.txt ]; then
rm cookies.txt csrf.txt
printf "\nCookies Cleared!\n"
fi
# Set Workingdir to script executiondir
cd "${0%/*}"
# Clearing Cookies
clear_cookies
# Get Monthly Internet Usage Data
# Login to PFSense
login1=$(curl --silent --insecure -L -k --cookie-jar cookies.txt \
https://$pfsenseipaddress/ \
| grep "name='__csrf_magic'" \
| sed 's/.*value="\(.*\)".*/\1/' > csrf.txt)
login2=$(curl --silent --insecure -L -k --cookie cookies.txt --cookie-jar cookies.txt \
--data-urlencode "login=Login" \
--data-urlencode "usernamefld=$pfusername" \
--data-urlencode "passwordfld=$pfpassword" \
--data-urlencode "__csrf_magic=$(cat csrf.txt)" \
https://$pfsenseipaddress/ > /dev/null)
login3=$(curl --silent --insecure -L -k --cookie cookies.txt --cookie-jar cookies.txt \
https://192.168.2.1/diag_backup.php \
trafficdata=$(curl --silent --insecure -L -k --cookie cookies.txt --cookie-jar cookies.txt \
--data-urlencode "__csrf_magic=$(head -n 1 csrf.txt)" \
https://$pfsenseipaddress/vnstat_fetch_json.php | jq '.interfaces[0].traffic.months')
# Parse Traffic Data
echo "$trafficdata" | grep '"id":' | sed -e s/[^0-9]//g | while read line ; do
month=$(echo "$trafficdata" | jq ".[$line].date.month")
year=$(echo "$trafficdata" | jq ".[$line].date.year")
currentmonth=$(date +%m | bc -l)
currentyear=$(date +%Y)
localmonthdate=$(echo "$currentmonth" "$currentyear")
pfsensemonthdate=$(echo "$month" "$year")
if [ "$localmonthdate" == "$pfsensemonthdate" ]; then
rx=$(echo "$trafficdata" | jq ".[$line].rx")
rxgb=$(echo "scale=2; $rx / 1048576" | bc -l)
tx=$(echo "$trafficdata" | jq ".[$line].tx")
txgb=$(echo "scale=2; $tx / 1048576" | bc -l)
# Endresult
printf "Internet Usage - Download: $rxgb GB Upload: $txgb GB\n\n"
# Send to Domoticz
curl -s --insecure -u "$domoticzuser":"$domoticzpass" "https://{$domoticzserver}:{$domoticzport}/json.htm?type=command¶m=addlogmessage&message=Internet%20Usage%20-%20Download:%20$rxgb%20GB%20Upload:%20$txgb%20GB"
curl -s --insecure -u "$domoticzuser":"$domoticzpass" "https://{$domoticzserver}:{$domoticzport}/json.htm?type=command¶m=udevice&idx=${rxidx}&svalue=${rxgb}"
curl -s --insecure -u "$domoticzuser":"$domoticzpass" "https://{$domoticzserver}:{$domoticzport}/json.htm?type=command¶m=udevice&idx=${txidx}&svalue=${txgb}"
fi
# Clearing Cookies Again
clear_cookies
done
This is our world now... the world of the electron and the switch, the beauty of the baud.
tjabas
Posts: 562 Joined: Sunday 11 December 2016 13:51
Post
by tjabas » Thursday 20 February 2020 12:46
Do i install this plugin in domoticz/plugins?
benedict
Posts: 16 Joined: Thursday 16 December 2021 16:05
Post
by benedict » Thursday 24 August 2023 19:21
ben53252642 wrote: ↑ Friday 18 January 2019 13:26
Is there anyone working on something for domoticz that does calculate totals per day, week, month out of an SNMP source?
I own a mikrotik router and it's incredible how hard it is to obtain this from anything out there. All people do is show current, max, average bandwidth per x time, but never total up and down data usage, while this is precisely what most people need to know, as ISPs all allow a max with fair-use policies thriving these days etc.
