X10 Dimmers; A simple solution
Thuis
Re: X10 Dimmers; A simple solution
Post by Thuis »
Is that a question to me? on github ?
Fun for everyone!
No just an extra remark and confirmation to the developers that it is not working anymore as before.
Thuis
Post by Thuis »
Ah ok, thanks for backing it up !
Fun for everyone!
Thuis
Post by Thuis »
Well i have tested the new script from github, and it works. But it gives an error in the log.
EventSystem: in script_device_dimmers:[string "commandArray = {}..."]:22: bad argument #1 to 'pairs' (table expected, got nil)
Status: User: admin (IP: xxx.xxx.xxx.xxx) initiated a switch command (172/Lamp Aanrecht/Set Level)
Status: LUA: idx: 172, name: Lamp Aanrecht, state: On, svalue: 30, nvalue: 2
Status: LUA: /home/onshuis/Domotica/domoticz/scripts/lua/mochad_dim.sh J3 18
I see the light dim and brighten and go on and off so it all works, but the error.
I have no clue what it means. But the script seems to work!
Do you know perhaps a solution to the bad argument?
Fun for everyone!
Thuis
Post by Thuis »
Ok i put
if (devicechanged_ext ~= nil) then
in front of line 22, and the error is gone.
So thanks all is working now :-)
So to update the forum post, the changed script from Gizmocuz on github is this:
local BASHSCRIPT = "/home/pi/domoticz/scripts/lua/mochad_dim.sh "  --keep the space at the end!
local bashcall = ""
dimmers = {}
-- Dimmer names must be strictly identical to the dimmer labels
dimmers["Lumiere Salon"]="o4"
dimmers["Lumiere Salle a Manger"]="o6"
dimmers["Lumiere Chambre 1"]="o8"
dimmers["TestDimmer"]="o10"
dimmers["TestSwitch"]="o11"
dimmers["Lumiere Bureau"]="o12"
dimmers["Lumiere Chambre 3"]="o13"
for name,value in pairs(devicechanged_ext) do
	if (name == "name") then
		local X10Address=dimmers[value]
		--If a registered Dimmer
		if X10Address ~= nil then
			-- Create appropriate way to call the BASH script
			local state = devicechanged_ext["state"];
			local level = tonumber(devicechanged_ext["svalue"]);
			print ("idx: "..devicechanged_ext["idx"]..", name: "..devicechanged_ext["name"]..", state: "..state..", svalue: "..tostring(level)..", nvalue: "..devicechanged_ext["nvalue"]);
			if state == "Off" then
				bashcall=BASHSCRIPT ..X10Address.." ".. "Off"
			elseif state == "On" then
				if (level == 0) then
					bashcall=BASHSCRIPT ..X10Address.." ".. "On"
					local intdata=(tostring(math.floor(level*0.63)))
					bashcall=BASHSCRIPT..X10Address.." "..intdata
			--Call the Bash script
			--os.execute(bashcall)
			print(bashcall);
And is working as a tierelier. Thanks to gizmocuz and waltervl for helping me.
Fun for everyone!
To be clear, to use this new script you have to update domoticz to the latest beta version 15095 or higher.
Thuis
Post by Thuis »
waltervl wrote: Thursday 23 February 2023 17:16 To be clear, to use this new script you have to update domoticz to the latest beta version 15095 or higher.
Yes thanks, it was clear.
Fun for everyone!
Thuis wrote: Thursday 23 February 2023 17:17
To you probably it was clear but not for the other users that will have the same problem and read this thread :-)
Thuis
Post by Thuis »
You are right again :D
Fun for everyone!
