X10 Dimmers; A simple solution
- Domoticz version: 2026.3
Re: X10 Dimmers; A simple solution
No just an extra remark and confirmation to the developers that it is not working anymore as before.
- Thuis
Well i have tested the new script from github, and it works. But it gives an error in the log.
I see the light dim and brighten and go on and off so it all works, but the error.
I have no clue what it means. But the script seems to work!
Do you know perhaps a solution to the bad argument?
EventSystem: in script_device_dimmers:[string "commandArray = {}..."]:22: bad argument #1 to 'pairs' (table expected, got nil)
Status: User: admin (IP: xxx.xxx.xxx.xxx) initiated a switch command (172/Lamp Aanrecht/Set Level)
Status: LUA: idx: 172, name: Lamp Aanrecht, state: On, svalue: 30, nvalue: 2
Status: LUA: /home/onshuis/Domotica/domoticz/scripts/lua/mochad_dim.sh J3 18 I have no clue what it means. But the script seems to work!
Fun for everyone!
- Thuis
Ok i put
in front of line 22, and the error is gone.
So thanks all is working now
So to update the forum post, the changed script from Gizmocuz on github is this:
And is working as a tierelier. Thanks to gizmocuz and waltervl for helping me.
if (devicechanged_ext ~= nil) thenSo thanks all is working now
local BASHSCRIPT = "/home/pi/domoticz/scripts/lua/mochad_dim.sh " --keep the space at the end!
local bashcall = ""
dimmers = {}
-- Dimmer names must be strictly identical to the dimmer labels
dimmers["Lumiere Salon"]="o4"
dimmers["Lumiere Salle a Manger"]="o6"
dimmers["Lumiere Chambre 1"]="o8"
dimmers["TestDimmer"]="o10"
dimmers["TestSwitch"]="o11"
dimmers["Lumiere Bureau"]="o12"
dimmers["Lumiere Chambre 3"]="o13"
for name,value in pairs(devicechanged_ext) do
if (name == "name") then
local X10Address=dimmers[value]
--If a registered Dimmer
if X10Address ~= nil then
-- Create appropriate way to call the BASH script
local state = devicechanged_ext["state"];
local level = tonumber(devicechanged_ext["svalue"]);
print ("idx: "..devicechanged_ext["idx"]..", name: "..devicechanged_ext["name"]..", state: "..state..", svalue: "..tostring(level)..", nvalue: "..devicechanged_ext["nvalue"]);
if state == "Off" then
bashcall=BASHSCRIPT ..X10Address.." ".. "Off"
elseif state == "On" then
if (level == 0) then
bashcall=BASHSCRIPT ..X10Address.." ".. "On"
local intdata=(tostring(math.floor(level*0.63)))
bashcall=BASHSCRIPT..X10Address.." "..intdata
--Call the Bash script
--os.execute(bashcall)
print(bashcall);
return commandArrayFun for everyone!
To be clear, to use this new script you have to update domoticz to the latest beta version 15095 or higher.
- Thuis
Yes thanks, it was clear.waltervl wrote: Thursday 23 February 2023 17:16 To be clear, to use this new script you have to update domoticz to the latest beta version 15095 or higher.
Fun for everyone!
To you probably it was clear but not for the other users that will have the same problem and read this thread
