Page 2 of 13
Re: monitor internet connection with virtual sensors
Posted: Sunday 23 October 2016 19:02
by safi78
@Derik:
I realised the package has different names, and maybe its even added in the latest distro's only, I don't know.
@hourly runs every xx:00 if I recall correctly, not sure though.
Glad your're happy with it
Posted: Sunday 23 October 2016 19:08
by Derik
emme wrote:low ping means fast response.... so it's good
high ping means slow response... that' bad
Watch out the unit: normally it's ms-->milliseconds
What's a normal/good ping?
Posted: Sunday 23 October 2016 19:11
by safi78
The lower the better. Here's my graph, lowest I got was 25'ish (on cablemodem)
- Screen Shot 2016-10-23 at 19.09.29.png (292.29 KiB) Viewed 3815 times
I eventually found out my problem so, the very high pings are either other stuff that's going on (downloading stuff with sabnzbd full throttle) or my connection with my cable modem and switch flappy (probably the auto-negiotation about duplex / speed etc going haywire). Still have to fix that, but TP-link doesn't offer a lot of Mac-software to manage stuff
regards!
Posted: Sunday 23 October 2016 19:23
by Derik
mmm
Hope this "garbage " give no trouble...
- ScreenShot075.jpg (83.55 KiB) Viewed 3808 times
I mean the Json files
Or i there something that i do wrong ...
This going to kill my sd ...[ after a few months .]
Posted: Sunday 23 October 2016 19:26
by safi78
hmm i have the same thing, even with the 'wget -q' and redirect to /dev/null etc. weird. gotto look into that.
somewhat reassuring, I think I'm using my SSD for about 2 years now with a lot of scripting, testing, trial and error, etc and it's still fine.
Posted: Sunday 23 October 2016 19:31
by Derik
safi78 wrote:hmm i have the same thing, even with the 'wget -q' and redirect to /dev/null etc. weird. gotto look into that.
Ok like to hear from you when you think you have a solution, i will test
My sd is stable ony this stuff is not the best option in that place...
When domoticz kills... some people here @ home get nervous..
Posted: Sunday 23 October 2016 19:34
by safi78
backup, backup backup
Anyway, you can always create a 'ram-drive' to redirect this stuff to? Saves you disk-trashing
Posted: Sunday 23 October 2016 20:05
by Derik
safi78 wrote:backup, backup backup
Backup is not the problem....
0 1 * * * sudo ~/domoticz/scripts/domoticz_backup.sh
5 1 * * 6 sudo ~/domoticz/scripts/scripts_backup.sh
10 1 * * 6 sudo ~/domoticz/scripts/domoticz_map_backup.sh
1 1 1 * * sudo ~/domoticz/scripts/raspberry_backup.sh
Only everytime the work/time...
And Domoticz is going so fast that i do not every time how anything is working..
1 person says to me... when you can hold your card clean why don;t you do that
Posted: Sunday 23 October 2016 20:07
by geho
Try this:
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$idxdl&svalue=$download"
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$idxul&svalue=$upload"
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$idxpng&svalue=$png"
this will not add files
Posted: Sunday 23 October 2016 20:15
by Derik
do i need to replace this.. or add?
Posted: Sunday 23 October 2016 20:23
by geho
replace it
Posted: Sunday 23 October 2016 20:25
by safi78
@Derik: I've been running beta since the beginning, never had any problems. A quick reinstall, yes, but restoring the db / scripts etc gets me up-and-running in an hour.
And, I see you are Dutch as well, so you can have a new SSD within 24 hours with BOL or CoolBlue
@geho: Thanks a bundle! Added to original post.
Posted: Sunday 23 October 2016 20:38
by Derik
pi@raspberrypi ~/domoticz/scripts $ ./speedtest.sh
ping = 37.035 ms
download = 33.04 Mbps
upload = 9.32 Mbps
HTTP/1.1 200 OK
Content-Length: 24
Content-Type: application/json;charset=UTF-8
Cache-Control: no-cache
Pragma: no-cache
Access-Control-Allow-Origin: *
"status" : "ERR"
HTTP/1.1 200 OK
Content-Length: 24
Pragma: no-cache
"status" : "ERR"
HTTP/1.1 200 OK
Content-Length: 24
Pragma: no-cache
"status" : "ERR"
Got some errors.. With the new curl..
Posted: Sunday 23 October 2016 20:46
by safi78
Works fine here. What did you put in your script?
Posted: Sunday 23 October 2016 21:00
by Derik
#!/bin/bash
#setup
host=192.168.5.75
port=8081
username=LOGIN
password=WW
pingidx=4427
downloadidx=4426
uploadidx=4425
# no need to edit
speedtest-cli --simple > output.txt
ping=$(cat output.txt | sed -ne 's/^Ping: \([0-9]*\.[0-9]*\).*/\1/p')
download=$(cat output.txt | sed -ne 's/^Download: \([0-9]*\.[0-9]*\).*/\1/p')
upload=$(cat output.txt | sed -ne 's/^Upload: \([0-9]*\.[0-9]*\).*/\1/p')
#output if you run it manually
echo "ping = $ping ms"
echo "download = $download Mbps"
echo "upload = $upload Mbps"
Sorry i am not sooooo smart//..
Posted: Sunday 23 October 2016 21:18
by safi78
Not sure, but didn't you forget the $username & $password like so:
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$pingidx&svalue=$ping"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$downloadidx&svalue=$download"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$uploadidx&svalue=$upload"
Posted: Sunday 23 October 2016 21:21
by safi78
And seriously, do you have like 4000+ devices in your domoticz history?
Posted: Sunday 23 October 2016 22:02
by Derik
Dear Safi,
looks working @ my crontab time.. without garbage in my sd.. [ love your great work ]
See tomorrow, how his is working
And yes my history is real great.... the reason my complicated Zwave network....
did open new sensors for long time to see my new devices.
Then i delete them all, when i get my new devices..
Did this servile times.....
And Domoticz is still counting...
Only working like a rocket....
Thanks!!
Posted: Monday 24 October 2016 19:31
by Derik
Thanks again
Works great without garbage
- ScreenShot076.jpg (64.97 KiB) Viewed 3660 times
Re: monitor internet download speed with virtual sensor
Posted: Monday 24 October 2016 21:42
by manjh
jumbotroll wrote:manjh wrote:This is great for the R-Pi, but is there an alternative for a Windows based server?
On windows 10 it's working here.
Install python 3.5.2 from
https://www.python.org/downloads/
Open cmd as Administrator and type: pip install speedtest-cli
Then you can type: speedtest
I installed it and ran an admin-cmd. But PIP is not recognized as command or program...
In which directory does Python install? I can't find anything that looks recognizable!
Edit: never mind, I found the directory and was able to install the speedtest package, and run the speedtest manually.
