flat-blue - new metro look theme
piokuc
Re: flat-blue - new metro look theme
Post by piokuc »
If looks ok but why you dont add it to official Domoticz ?
SchattenMann
Post by SchattenMann »
never thought about it till now
piokuc
Post by piokuc »
:) Good option to think about it :) Thanks for very good theme
piokuc
Post by piokuc »
I found a small bugs and have suggestion to change color size on desktop as show on screen or white and blue split in half equally.
I test in chrome web browser
Oversize dimmer-change to smaller(short)
piokuc
Post by piokuc »
Underline under tabs in settings should be black :)
And text on diagram shoukld be darker. Is too light
diagram text light.jpg (170.83 KiB) Viewed 2058 times
piokuc
Post by piokuc »
Fields which user can edit should be white but fields which can not be edited shoud be darker. Color rows in table also should be white and color background. Looks better than light blue... and seemd that will be lighter.
Look on screen :)
Sorry for my image but i edites it in fast time in Paint :)
piokuc
Post by piokuc »
I done some changes in theme and add pull request on your gihub
piokuc
Post by piokuc »
What do you think abou add icon for submenu ? If you accept i can send you pull request :)
icon submenu.jpg (150.98 KiB) Viewed 1997 times
icon submenu 2.jpg (153.45 KiB) Viewed 1995 times
SchattenMann
I appreciate the effort and time you've put into this.
Unfortunately I can't accept all the changes as some doesn't seem to add up to the overall look of this theme. The general idea is to keep it clean and simple: the use of blacks and too many icons simple go against that.
I've made a few changes myself, feel free to try them out
piokuc
Post by piokuc »
But can i use your theme as base to my new theme with my future which you dont want add ?
SchattenMann
Sure, no problem!
piokuc
Post by piokuc »
Ok thanks. When infinish i also share my theme :-) but again very thanks for good job :-)
piokuc
Post by piokuc »
SchattenMann i have a question. Did you know how resolve problem when sensor timeout in default theme show on tab in red color. On your theme is not show as red color. Show as normal sensor which should work ok. But should be show in red color.
SchattenMann
Yeah that's one of the things I wanted to fix but not sure I can be done.
Problem is the "red colour" is hard coded on the widget instead of being a proper class. Not sure why it's done this way as it makes no sense to me but there's a lot of "in-line" CSS in domoticz...
Unless someone changes this to proper CSS class then this will be a PITA to fix
piokuc
Post by piokuc »
If you find solution please send me :)
Second question is did you know how add to menu CHECK UPDATE icon as i add to other items in menu. I add for other by add to css example:
#cHardware {
    background-image: url("/styles/blue-domo/images/hardware.png") !important;
    background-position: left center;
    background-repeat: no-repeat;
#cDevices {
    background-image: url("/styles/blue-domo/images/devices.png") !important;
#cSetup {
    background-image: url("/styles/blue-domo/images/setup.png") !important;
but for update is no string example
cUpdate
. Sorry for my question but i am begginer in CSS.
SchattenMann
Yes I'm afraid there's quite a few like that where CSS is hard coded instead of using proper CSS classes
li [ng-show="config.HaveUpdate"] {
may just work
piokuc
Post by piokuc »
i set this:
    background-image: url("/styles/blue-domo/images/update.png") !important;
and not show icon...
EDIT
I change to:
li [ng-hide="config.HaveUpdate"] {
and works ok :) Thanks
EDIT
But when i select mouse this item it is hide icon:
Select other menu show icon update:
select menu update hide icon:
This is my code for icon to menu update:
li [ng-hide="config.HaveUpdate"], li [ng-show="config.HaveUpdate"] {
piokuc
Post by piokuc »
Do you any idea to fix it ?
SchattenMann
nop
piokuc
Post by piokuc »
