I thought that when launching an os.execute the execution was launched, but them the control return to the script.
It's not like this.
So since the irrigation.sh can last also for 30 mins, I modified it adding an " &" at the the end, so is going to launch and the script get back control.
In this way of course I can't get any response (if any) from the bash script.
Do you think is a good idea?
Irrigation with multiple zones
woody4165
Re: Irrigation with multiple zones
- Egregius
- Domoticz version: v2024.7
Let the script write to a logfile, or back to domoticz in a text device or a user variable.
You should (almost) always use & at the end of a bash command to let it continue.
woody4165
Re: RE: Re: Irrigation with multiple zones
Thanks!Egregius wrote:Let the script write to a logfile, or back to domoticz in a text device or a user variable.
How can I write into an user variable from a bash script?
- Egregius
Wiki json api
Just curl the url.
Just curl the url.
woody4165
Thanks Egregius
got the json to update uservariable.
I'm not good in bash, how can I get if a previous curl, updating a switch via json, was ok or not?
I see that it return
"status" : "OK",
"title" : "SwitchLight"
if it's ok
and
"status" : "ERR",
if not ok.
What should I check?
My actual curl command is
"status" : "OK",
if it's ok
and
"status" : "ERR",
if not ok.
curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=$IDX_ZONE1&switchcmd=On" > /dev/null
- Egregius
In http://www.domoticz.com/forum/viewtopic ... 780#p83346 I check the OK status and there's also a if statement.
woody4165
Nice. I will take a look in the afternoon!
