Irrigation with multiple zones
woody4165
Post by woody4165 »
I would like to implement a script to manage my multi-zones irrigation system.
I have four zones and I would like to activate them one after the other for a specific number of minutes.
I was thinking to use the BakSeeDaa´s Google Calendar for Domoticz as starting point (when and how much time) combined with weather forecast to avoid irrigation if it's raining or has recently rained.
The thing that I don't know how to implement is the activation of all the valves one after the other.
I was thinking to use the text in the Google Calendar event as a combination of values to understand which valve to activate.
Any suggestion?
georgesattali
Re: Irrigation with multiple zones
Post by georgesattali »
what would you think of a "device" script : when the first stops the second starts, ...
and only the first is started by Google Calendar.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Or no calendar but rain expectation?
For example:
This php script will ask buienradar.nl the rain expectation for the next 2 hours.
If the total expected rain is less than 10 ask domoticz the status of switches in roomplan 3.
Depending on the time of day and status of those switches sent switch commands.
$time=$_SERVER['REQUEST_TIME'];
$domoticzurl='http://127.0.0.1:8084/';
function Schakel($idx,$cmd,$name=NULL) {
	global $domoticzurl;
	$reply=json_decode(file_get_contents($domoticzurl.'json.htm?type=command&param=switchlight&idx='.$idx.'&switchcmd='.$cmd.'&level=0&passcode='),true);
	if($reply['status']=='OK') $reply='OK';else $reply='ERROR';
	return $reply;
$rains=file_get_contents('http://gps.buienradar.nl/getrr.php?lat=50.892880&lon=3.112568');
$rains=str_split($rains, 11);
$totalrain=0;
foreach($rains as $rain) {
	$totalrain=$totalrain+substr($rain,0,3);
if($totalrain <= 10) {
	$domoticz=json_decode(file_get_contents($domoticzurl.'json.htm?type=devices&plan=3'),true);
	if($domoticz) {
		foreach($domoticz['result'] as $dom) {
			$name=$dom['Name'];
			if(substr($dom['Data'],0,2)=='On') ${'S'.$name}='On';
			else if(substr($dom['Data'],0,3)=='Off') ${'S'.$name}='Off';
			else if(substr($dom['Data'],0,4)=='Open') ${'S'.$name}='Open';
			else ${'S'.$name}=$dom['Data'];
			${'SI'.$name}=$dom['idx'];
			${'ST'.$name}=strtotime($dom['LastUpdate']);
		if($time>=strtotime('6:00') && $time<=strtotime('6:20')) {
			if($Szone1=='Off') Schakel($SIzone1,'On');
		} else {if($Szone1=='On') Schakel($SIzone1,'Off');}
		if($time>=strtotime('6:20') && $time<=strtotime('6:40')) {
			if($Szone2=='Off') Schakel($SIzone2,'On');
		} else {if($Szone2=='On') Schakel($SIzone2,'Off');}
		if($time>=strtotime('6:40') && $time<=strtotime('7:00')) {
			if($Szone3=='Off') Schakel($SIzone3,'On');
		} else {if($Szone3=='On') Schakel($SIzone3,'Off');}
		if($time>=strtotime('7:00') && $time<=strtotime('7:20')) {
			if($Szone4=='Off') Schakel($SIzone4,'On');
		} else {if($Szone4=='On') Schakel($SIzone4,'Off');}
In my PHP Floorplan script there's also Google Calendar integration.
Then it would be appointments like switch zone1 on and switch zone1 off.
Or switch a dummy switch and have the rest been done depending on that one.
Egregius
Post by Egregius »
Thinking some more...
You should also check if it has rained in the past x hours.
Or even better: use a ground moisture sensor.
woody4165
Post by woody4165 »
Thank all.
This is what I have in mind.
In Google calendar I set a calendar event with a CSV like this:
10,0,8,4
I will decode it and put in four variables, one for each zone.
This will stand for minutes for each irrigation zones. If 0 no irrigation at that time.
When the calendar event will activate, before doing anything it should check if it has rained in the past xx hours or if it will rain in the upcoming ones (still need to find a way to check it for Italy).
If it's ok, it should start a switching On the first relay (I will most probably use an ESP8266 connected to a 4-relay module). And after the first finish it should start the next one that has a value higher than 0 for that specific time.
What I am not sure how to implement, is how to let the second (and higher) switch to turn On only after the first one has finished.
What do you think?
Egregius
Post by Egregius »
How will you create the events in the calendar? Is it possible to automate that?
Westcott
Post by Westcott »
Apparently Buienradar only works for the Benelux region.
woody4165
Post by woody4165 »
Egregius wrote:How will you create the events in the calendar? Is it possible to automate that?
I was thinking to create them as repeating calendar event (like programming my actual Orbit irrigation system).
With the possibility to change them from anywhere and to bypass an event based on weather
Egregius
Post by Egregius »
Westcott wrote:Apparently Buienradar only works for the Benelux region.
I guess there are other sites/api's available around the world.
woody4165 wrote: I was thinking to create them as repeating calendar event (like programming my actual Orbit irrigation system).
Sound straightforward.
If you have some php knowledge you should be able to combine the script I posted above with my Google Calendar script.
I do think that just using the appointment timings should do it. Like create 4 repeating appointments: zone1 from 6:00 to 6:10, zone2 from 6:11 to 6:19 etc.
Westcott
Post by Westcott »
Wunderground and forecast.io have APIs
woody4165
Post by woody4165 »
This is what, if possible, I would like to avoid. Creating n different calendar event for each zone is difficult to mantain if I want to modify them.
Regarding PHP, I have no knowledge of it, sorry :?
As well as for Lua, but it's easier for me.
Meanwhile, I have just wrote some parts to use it in a script.
The first one is going to get precipitation forecast from ForecastIo
    -- get data from ForecastIo and decode it in forecastio
    local jsondata    = assert(io.popen('curl "https://api.forecast.io/forecast/xxxxxxxx/xx.xxxxxx,yy.yyyyy"'))
    local jsondevices = jsondata:read('*all')
    jsondata:close()
    local forecastIo = json:decode(jsondevices)
    -- read precipitation forecast hourly for next 12 hours
    for i = 1, 12, 1 do
       print(os.date("%X", forecastIo.hourly.data[i].time))
       print(forecastIo.hourly.data[i].precipIntensity)
       print(forecastIo.hourly.data[i].precipProbability)
But what for past 12 hours, is there a way to get this info, or is there a way to save this info somewhere so that I can read it later?
Then, searching here and there I used this split string function to separate the text in the title of the calendar event
-- Title is like "10,8,0,4"
local_uservar = uservariables['GCal88NextEvent']
function string:split( inSplitPattern, outResults )
  if not outResults then
    outResults = { }
  local theStart = 1
  local theSplitStart, theSplitEnd = string.find( self, inSplitPattern, theStart )
  while theSplitStart do
    table.insert( outResults, string.sub( self, theStart, theSplitStart-1 ) )
    theStart = theSplitEnd + 1
  table.insert( outResults, string.sub( self, theStart ) )
  return outResults
local mySchedule = local_uservar:split(",")
for i = 1, #mySchedule do
   print(mySchedule[i]) -- This will print the for schedules
Now, how to handle the "serial" activation of the four zones?
I'm confused...
woody4165
Post by woody4165 »
I found Weather Underground more complete since it has the possibility to get history data based on a specific date.
Using JSON.lua I have decoded the generate output, but I need to know how many table elements there are and go reverse, since it contains informations on a 30 minutes basis ordered from older to newer.
I would like to test only last 12 hours, so I need to test 24 table elements starting from the latest.
What is the right loop to do do it?
I get an error
2016-04-16 15:44:59.869 Error: EventSystem: in irrigation2: [string "-- ..."]:71: attempt to index field '?' (a nil value)
The element I'm testing is
wundergound.history.observations[x].rain
Westcott
Post by Westcott »
When I try it in a browser I get 15 hours of history at 5 minute intervals.
No 'rain' but -
precip_ratem: "0.0",
precip_ratei: "0.00",
precip_totalm: "0.0",
precip_totali: "0.00",
woody4165
Post by woody4165 »
Strange!
I've used the call
http://api.wunderground.com/api/xxxxxx/history_20160416/q/zmw:xxxxxxx.json
and I get every 30 mins, for example
		"date": {
		"pretty": "12:50 AM CEST on April 15, 2016",
		"year": "2016",
		"mon": "04",
		"mday": "15",
		"hour": "00",
		"min": "50",
		"tzname": "Europe/Rome"
		"utcdate": {
		"pretty": "10:50 PM GMT on April 14, 2016",
		"year": "2016",
		"mon": "04",
		"mday": "14",
		"hour": "22",
		"min": "50",
		"tzname": "UTC"
		"tempm":"11.0", "tempi":"51.8","dewptm":"8.0", "dewpti":"46.4","hum":"82","wspdm":"5.6", "wspdi":"3.5","wgustm":"-9999.0", "wgusti":"-9999.0","wdird":"0","wdire":"Variable","vism":"-9999.0", "visi":"-9999.0","pressurem":"1015", "pressurei":"29.98","windchillm":"-999", "windchilli":"-999","heatindexm":"-9999", "heatindexi":"-9999","precipm":"-9999.00", "precipi":"-9999.00","conds":"Clear","icon":"clear","fog":"0","rain":"0","snow":"0","hail":"0","thunder":"0","tornado":"0","metar":"METAR LIRF 142250Z VRB03KT CAVOK 11/08 Q1015 NOSIG" },
		"date": {
		"pretty": "1:20 AM CEST on April 15, 2016",
		"year": "2016",
		"mon": "04",
		"mday": "15",
		"hour": "01",
		"min": "20",
		"utcdate": {
		"pretty": "11:20 PM GMT on April 14, 2016",
		"year": "2016",
		"mon": "04",
		"mday": "14",
		"hour": "23",
		"min": "20",
		"tzname": "UTC"
		"tempm":"9.0", "tempi":"48.2","dewptm":"7.0", "dewpti":"44.6","hum":"87","wspdm":"3.7", "wspdi":"2.3","wgustm":"-9999.0", "wgusti":"-9999.0","wdird":"10","wdire":"North","vism":"-9999.0", "visi":"-9999.0","pressurem":"1015", "pressurei":"29.98","windchillm":"-999", "windchilli":"-999","heatindexm":"-9999", "heatindexi":"-9999","precipm":"-9999.00", "precipi":"-9999.00","conds":"Clear","icon":"clear","fog":"0","rain":"0","snow":"0","hail":"0","thunder":"0","tornado":"0","metar":"METAR LIRF 142320Z 01002KT CAVOK 09/07 Q1015 NOSIG" },
		"date": {
		"pretty": "1:50 AM CEST on April 15, 2016",
		"year": "2016",
		"mon": "04",
		"mday": "15",
		"hour": "01",
		"min": "50",
		"utcdate": {
		"pretty": "11:50 PM GMT on April 14, 2016",
		"year": "2016",
		"mon": "04",
		"mday": "14",
		"hour": "23",
		"min": "50",
		"tzname": "UTC"
If I set the date as today, it goes back a certain amount of hours, if I set yesterday I get more data.
I would like to go with the today date, since I want to evaluate last 12 hours starting from now.
Westcott
Post by Westcott »
I used .../history/q/pws:IENGLAND873.json
This is my PWS and it gave today's history at 5 min intervals.
No 'rain' though, but various 'preci's
Perhaps you need -
wundergound.history.observations[x].precipi
although the value of -9999.00 does not look very good.
woody4165
Post by woody4165 »
I get always that negative value.
I tried with a date when was raining, but I get same data.
Maybe Wunderground doesn't collect this data for Italy.
I wasn't correct saying that ForecastIO does not provide history, but does not provide, at least for my region, precip measurement, but just if has rained or not.
It got info for forecast.
Westcott
Post by Westcott »
Perhaps you could try a nearby PWS:
woody4165
Post by woody4165 »
Can I switch on a device from a Lua script setting at the same time "on delay" and "stop after"?
Inviato con Tapatalk
woody4165
Post by woody4165 »
So I wrote my script, actually is made of 2 Lua and 1 bash script.
I'm sure it can be optimized, sorry I am not a programmer and know just a little bit of coding.
The script is for managing a 4 zone irrigation system thru an ESP8266 and a 4 relay board.
First of all, I've created four new Dummy Switch, one for each irrigation zone.
The main script uses the fantastic Google Calendar for Domoticz by BakSeeDaa (thanks!) to check for a specific calendar event.
It will check for an event that start with IRRIG and separated by comma with the irrigation time for each zone (ie. IRRIG,10,4,0,8)
If the event is correct, it will check for previous and upcoming rainfall forecast, to avoid irrigation. Using Weather Underground.
If all is ok, it can call the bash script that will manage zone activation in a serialized way (sleep).
The third script is "listening" for activation of one of the Dummy Switch and will send http commands to the ESP, to switch off all the relay except the one I want to activate, to be sure that only one is active.
Here is the code:
Main Script
--Main script for manage a 4 zone irrigation system thru an ESP8266
--Is based on Gmail Calendar event (thanks to BakSeeDaa for his Google Calendar for Domoticz).
--It will check for an event that start with Irrig and separated by comma with the irrigation time for each zone (ie. Irrig,10,4,0,8)
--If the event is correct, it will check for previous and upcoming rain, to avoid irrigation.
--If all is ok, it will call a bash script that will manage zone activation in a serialized way (sleep)
--Author   : woody4165
--Date     : 17 April 2016
if (devicechanged['GCalTicz'] == 'On') then
    local innaffia = 1
    return
    local innaffia = 1
oggi = os.date("%Y%m%d")
-- The irrigation event must be this format "IRRIG,xx,xx,xx,xx" where xx are the activation minutes for each zone. Can be also 0.
-- function to split the string comma separated
    outResults = { }
  local theStart = 1
  return outResults
-- Split the Event to check if this is an irrigation event and grab the activation minutes per zone
local CalEvent = local_uservar:split(",")
-- If the first element is not "IRRIG" or if does not contain all the parameters, it's not an irrigation event. Exit
if ((CalEvent[1] ~= "IRRIG") or (#CalEvent ~= 5)) then
    return
--need to find "<" in the calendar event string to cut the last parameter at that position
w = string.find(CalEvent[5], "<")
w = w-1
local minuti_irrig1 = 0
local minuti_irrig2 = 0
local minuti_irrig3 = 0
local minuti_irrig4 = 0
-- If all is ok, define minutes per zone
minuti_irrig1 = tostring(CalEvent[2]*60)
minuti_irrig2 = tostring(CalEvent[3]*60)
minuti_irrig3 = tostring(CalEvent[4]*60)
minuti_irrig4 = (string.sub(CalEvent[5], 1, w)*60)
-- Now can control weather
function checkWeather(fake)
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
-- Check if it has rained
    -- get data from Weather Underground history of current day
    local jsondata    = assert(io.popen('curl "http://api.wunderground.com/api/xxxxxxx/history_'..oggi..'/q/zmw:00000.x.xxxx.json"'))
    jsondata:close()
    local rained = json:decode(jsondevices)
    pioggia = tonumber(rained.history.dailysummary[1].precipm)
-- If has rained exit
    if (pioggia > 0) then
--        print("Ha piovuto ieri "..pioggia.."mm")
        innaffia = 0
        return
-- Check if it's going to rain
    -- get data from Weather Underground forecast
    local jsondata    = assert(io.popen('curl "http://api.wunderground.com/api/xxxxxx/forecast/q/zmw:00000.x.xxxxx.json"'))
    jsondata:close()
    local willrain = json:decode(jsondevices)
    local piove_mattina = 0
    local piove_sera = 0
    local precip_oggi_mattina = 0
    local precip_oggi_sera = 0
    -- Grab only the forecast data for today
    precip_oggi_mattina = tonumber(willrain.forecast.simpleforecast.forecastday[1].qpf_day.mm)
    precip_oggi_sera    = tonumber(willrain.forecast.simpleforecast.forecastday[1].qpf_night.mm)
    if ((precip_oggi_mattina == nil) or (precip_oggi_mattina == 0)) then
        piove_mattina = 1
    if ((precip_oggi_sera == nil) or (precip_oggi_sera == 0)) then
        piove_sera = 1
-- If is going to rain, exit
    if ((piove_mattina == 0) or (piove_sera == 0)) then
        innaffia = 0
        print("Pioverà la mattina "..precip_oggi_mattina.."mm e la sera "..precip_oggi_sera.."mm")
        return
checkWeather(fake)
-- Now call the bash irrigation script with irrigation time per zone
    comando="/home/pi/domoticz/scripts/irrigation.sh "..minuti_irrig1..' '..minuti_irrig2..' '..minuti_irrig3..' '..minuti_irrig4
    os.execute(comando)
Bash Script
 #!/bin/bash
 MIN_ZONE1=$1
 MIN_ZONE2=$2
 MIN_ZONE3=$3
 MIN_ZONE4=$4
 DOMO_IP="192.168.x.xx"		        # Domoticz IP Address
 DOMO_PORT="xxxx"			# Domoticz Port
 IDX_ZONE1="xx"
 IDX_ZONE2="xx"
 IDX_ZONE3="xx"
 IDX_ZONE4="xx"
 if expr "$MIN_ZONE1" '>' 0
 then
 	echo $MIN_ZONE1
    curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$IDX_ZONE1&switchcmd=On" > /dev/null
 	sleep $MIN_ZONE1
    curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$IDX_ZONE1&switchcmd=Off" > /dev/null
 fi
 if expr "$MIN_ZONE2" '>' 0
 then
 	echo $MIN_ZONE2
    curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$IDX_ZONE2&switchcmd=On" > /dev/null
 	sleep $MIN_ZONE2
    curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$IDX_ZONE2&switchcmd=Off" > /dev/null
 fi
 if expr "$MIN_ZONE3" '>' 0
 then
 	echo $MIN_ZONE3
    curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$IDX_ZONE3&switchcmd=On" > /dev/null
 	sleep $MIN_ZONE3
    curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$IDX_ZONE3&switchcmd=Off" > /dev/null
 fi
 if expr "$MIN_ZONE4" '>' 0
 then
  	echo $MIN_ZONE4
   curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$IDX_ZONE4&switchcmd=On" > /dev/null
 	sleep $MIN_ZONE4
    curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$IDX_ZONE4&switchcmd=Off" > /dev/null
 fi
Executing script
--Script to activate a 4 relay board connected to an ESP8266 to control 4 irrigation zones
-- When one of the 4 Irrigation Dummy Switch will change Status
-- For each zone activation, first switch Off all the others.
if (devicechanged['IrrigZone1'] == 'On') then
 	os.execute('curl "http://192.168.x.xx/control?cmd=GPIO,xx,1"')
 	os.execute('curl "http://192.168.x.xx/control?cmd=GPIO,xx,0"')
elseif (devicechanged['IrrigZone1'] == 'Off') then
if (devicechanged['IrrigZone2'] == 'On') then
elseif (devicechanged['IrrigZone2'] == 'Off') then
if (devicechanged['IrrigZone3'] == 'On') then
elseif (devicechanged['IrrigZone3'] == 'Off') then
if (devicechanged['IrrigZone4'] == 'On') then
elseif (devicechanged['IrrigZone4'] == 'Off') then
And now some help request:
I have defined the function
This function doesn't need (?) a parameter, but I haven't found a way to declare without it and to call it without.
Main issue instead is related to the bash script call. I've done it thru
    os.execute(comando)
The os.execute do nothing or it does not call the bash script
I've tried copying the value of "comando" and execute it into a terminal and it works.
It's like "/home/pi/domoticz/scripts/irrigation.sh 10 8 0 4"
Weird thing is this.
I tried grabbing only some code from the main one and it works.
Only difference is that the "local_uservar" is not taken from Calendar Event, but is in the same format.
What can be the issue?
local_uservar = "IRRIG,10,0,8,4"
    outResults = { }
  local theStart = 1
  return outResults
-- If the first element is not "Irrig" it's not an irrigation event. Exit
    return
minuti_irrig1 = tostring(CalEvent[2])
minuti_irrig2 = tostring(CalEvent[3])
minuti_irrig3 = tostring(CalEvent[4])
minuti_irrig4 = tostring(CalEvent[5])
    comando="/home/osmc/domoticz/scripts/irrigation.sh "..minuti_irrig1..' '..minuti_irrig2..' '..minuti_irrig3..' '..minuti_irrig4
    os.execute(comando)
woody4165
Post by woody4165 »
Found the issue on os.execute
The last parameter was "dirty" since there was also calendar date.
I had to find "<" and made a substring before it.
I have updated previous post
