Page 2 of 7
Re: Step by step guide: Sonos integration
Posted: Sunday 24 July 2016 13:42
by Hanfelt
Updated dzvents code
active = true,
on = { ['timer'] = 'every minute' },
execute = function(domoticz)
local json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
local sonos=assert(io.popen('curl http://192.168.50.3:5005/Altan/state'))
local sonos_name = 'Sonos, Altan'
local status = sonos:read('*all')
sonos:close()
local jsonStatus = json:decode(status)
playerstate = jsonStatus['playerState']
if (playerstate == 'PLAYING')
then
domoticz.devices[sonos_name].switchSelector(10)
elseif (playerstate == 'PAUSED_PLAYBACK')
then
domoticz.devices[sonos_name].switchSelector(20)
domoticz.devices[sonos_name].switchSelector(0)
Posted: Wednesday 10 August 2016 14:21
by scheveningen
No more error
Posted: Thursday 25 August 2016 17:08
by commentator
Holland wrote:There a few options to integrate Sonos with Domoticz
1. via php
https://github.com/DjMomo/sonos
2. via the sonos http api;
https://github.com/jishi/node-sonos-http-api
I prefer option 2, since it's far more flexible and (for me) easier to implement
Below you can find the step by step guide to get this running.
1. First make sure that at least version 4.0.0 of node is running. If it's older; update to the latest version.
Thanks for the nice tutorial. Added this on my Domoticz pi. And it is working very wel. Except this:
I see this in the errorlog when pressing a button:
Error: Error opening url: http://myinternalip:5005/woonkamer/play
Looks like a Domoticz issue as the Sonos is playing musica after pressing the button.
Ideas how to solve this?
Posted: Saturday 27 August 2016 9:26
by Holland
@commentator;
It's a known issue. The sonos api doesn't give any response when it received a correct command, and gives a response when the command is incorrect. Ideally it should return like OK. You can safely ignore the error. Actually the sonos http api developer should be contacted, but I haven't done that yet.
viewtopic.php?f=6&t=10211
edit: today I posted a request at github sonos http api;
https://github.com/jishi/node-sonos-http-api/issues/275
Now, all we need to do is wait........
Posted: Friday 02 September 2016 20:54
by commentator
Holland wrote:@commentator;
thanks
Just waiting for a fix
An other question, how to start a radio stream from domoticz?
Because:
http://mylocalip:5005/livingroom/favorite/qmusic
doesn't work @ all
Posted: Saturday 03 September 2016 8:37
by dhanjel
Is it your favourite list? I use the same command, and it works for me.
Sent from my Nexus 6P using Tapatalk
Posted: Saturday 03 September 2016 9:20
by commentator
yes, the tunein radio channel is in my favorites with this name
Posted: Tuesday 04 October 2016 23:04
by stanv
I got this very very clear and simple guide working. At least....almost.
Got the JSON lua on, when doing the http-request the Sonos starts and stops.
But, how do I get this as a switch in Domoticz after step 9?
Posted: Wednesday 05 October 2016 20:46
by stanv
stanv wrote:I got this very very clear and simple guide working. At least....almost.
dumb question, got it.
well, still not sure what the second LUA script is for.
Posted: Thursday 06 October 2016 20:49
by Holland
The lua script is just an example for what you can do with it. In this case, Sonos stops playing, the moment the TV is switched on
Posted: Friday 07 October 2016 22:03
by Tharland
anyone know where to create the settings.json file?In which folder?
Posted: Saturday 08 October 2016 21:45
by Holland
In the root folder
If you want to change default settings, you can create a settings.json file and put in the root folder.
See:
Posted: Sunday 09 October 2016 14:19
by Tharland
which root folder? i only get a message about i need to register api key, but i have done this. and created a settings.json with the api key in the node-sonos-http-api folder
Can anyone tell me?
Posted: Saturday 22 October 2016 22:49
by Holland
Updated the guide.
Update solves this;
- Install the most resent version of node-sonos-http-api/
- changed the example lua script, since developper changed the JSON string a bit
Posted: Sunday 23 October 2016 22:36
by naitsirhc
first of all, thank you for the easy to follow how to
I get it all running on my Domoticz system and have a nice Icon at my desktop.
Unortunatly I get stuck at booting on startup.
I'm running on Jessie:
when I do:
2. sudo pm2 startup systemd –u pi....... it kills the proces
3. pm2 start nefiteasyhttpserver.sh....... this one I don't understand, copied from another topic I guess
4. pm2 save....... this one saves it.
So I start with 2.
then I do: cd node-sonos-http-api
then I type: pm2 start server.js
follows by: save pm2
Which delivers me a script in:: /home/pi/.pm2/dump.pm2
Do I have to rename the dump in a *.sh script?
or shortened:
What do I have to do, to run the server at startup
Kind regards
Christian
edit: typed wrong code
Posted: Monday 24 October 2016 21:51
by Holland
@naitsirhc
After you got the service running, check with pm2 list, do the following;
This will likely generate the following command;
sudo su -c "env PATH=$PATH:/usr/local/bin pm2 startup linux -u pi --hp /home/pi"
Execute the command that was generated via pm2 startup
Then, execute;
Restart and check if it has worked
Posted: Monday 24 October 2016 22:02
by naitsirhc
I will try it, thanks for the quick reply
Posted: Tuesday 25 October 2016 0:26
by ironrider
i have to start server.js after a Domoticz reset.
Is ist possible to make the server.js running as a service.
Thanx
Sven
Posted: Tuesday 25 October 2016 7:03
by Btje
Would be cool to see just the song playing.
Verstuurd vanaf mijn SM-G920F met Tapatalk
Posted: Tuesday 08 November 2016 0:06
by DJBenson
Quick heads up to inform that 'playerState' is now 'playbackState' in the node-sonos-http JSON response. Aside from that, this is working perfectly using the dzVents method. Thanks all!!
