How to do reduce log interval
delchrys
Re: How to do reduce log interval
Post by delchrys »
gizmocuz wrote:Did you also made a change in the database as mentioned ?
No i didn't how do i do that if i may ask?
edit:
Yes i got it working after a lot of googling (my best friend)
I have changed the database also and now i have interval of 1 minute.
I look in to it for a day and test it, maybe the rpi2 is fast enough to keep working properly(fast).
gizmocuz
Post by gizmocuz »
Please tell us your findings after maybe a week ?
Also the database size before, and after a week...
How many sensors do you have in the devices tab... like i got 470....
delchrys
Post by delchrys »
I maybe have about 10 devices so it will not be a problem I think.
delchrys
Post by delchrys »
gizmocuz wrote:Please tell us your findings after maybe a week ?
Is it possible that the database.db preferences reset when updating to new beta release??
Because when i updated to new Beta the shortlog preference was reset to 5 minutes.
I changed it back to 1 min, and now it is working again with 1 min intervals.
delchrys
Post by delchrys »
gizmocuz wrote:you have to remove 2 lines in the SQLServer.cpp and then you can change it in the database (actually the html code is also there but hidden)
	if (!GetPreferencesVar("ShortLogInterval", nValue))
		nValue = 5;
		UpdatePreferencesVar("ShortLogInterval", nValue);
then underneed remove these two lines
	if (nValue < 1)
		nValue = 5;
i probably must have some good reason not to expose this yet ?
Gizmocuz??
Can you tell me where to find the html code where i can change the shortlog settings????
ricard
Post by ricard »
It is the WebServer.cpp in the "main" folder not the SQLServer.cpp
I only had to change the code as below:
int iShortLogInterval = atoi(request::findValue(&req, "ShortLogInterval").c_str());
if (iShortLogInterval < 1)
iShortLogInterval = 1;
m_sql.UpdatePreferencesVar("ShortLogInterval", iShortLogInterval);
m_sql.m_ShortLogInterval = iShortLogInterval;
And then rebuild it
delchrys
Post by delchrys »
ricard wrote:It is the WebServer.cpp in the "main" folder not the SQLServer.cpp
And then rebuild it
Strange both options seem to work, or SQLhelper.cpp or webserver.cpp.
But also changing the database works. In preferences--> shortlog interval.
Now only a selectable option, and it would be perfect.
Two days running now and 1150Kb database size.
fleinze
Post by fleinze »
There has been no post for a year in this thread but I found a new comfortable solution I want to share:
The settings-value for the shortlog-interval is present throughout the source code. It is just missing in the html, not just "invisible" as suggested above.
You can changed that by editing www/views/setup.html
Search for "shortlogtable" and add the following before the </table>-tag:
<tr>
	<td align="right" style="width:60px"><label><span data-i18n="Interval"></span>Interval: </label></td>
	<td><select id="comboshortloginterval" name="ShortLogInterval" style="width:60px" class="combobox ui-corner-all">
		<option value="1">1</option>
		<option value="5">5</option>
		<option value="10">10</option>
		<option value="15">15</option>
	</select>&nbsp; Minutes
</tr>
Save it, delete your browser-cache and refresh your browser. I had problems with chrome keeping the old setup page even after deleting the cache, but using incognito mode worked to display the new page.
The new settings-value is fully functional.
strebor
Domoticz version: 8007
Post by strebor »
Worked like a charm, except can a get Firefox to let go of the old page noooo
S
MasterCATZ
Post by MasterCATZ »
Thanks heaps editing www/views/setup.html worked a treat
<div class="tab-pane" id="tablog">
						<!-- Log History
						<section id="loghistory">
						  <div class="page-header-small">
							<h1 data-i18n="Log History">Log History</h1>
						  </div>
							<h2><span data-i18n="Light/Switches"></span>:</h2>
							<table class="display" id="lightlogtable" border="0" cellpadding="0" cellspacing="0">
							<tr>
								<td align="right" style="width:60px"><label><span data-i18n="Days"></span>: </label></td>
								<td><input type="text" id="LightHistoryDays" name="LightHistoryDays" style="width: 50px; padding: .2em;" class="text ui-widget-content ui-corner-all" /></td>
							</tr>
							</table>
							<br>
							<h2><span data-i18n="Short Log Sensors"></span>:</h2>
							<table class="display" id="shortlogtable" border="0" cellpadding="0" cellspacing="0">
							<tr>
								<td><select id="comboshortlogdays" name="ShortLogDays" style="width:60px" class="combobox ui-corner-all">
									<option value="2">2</option>
									<option value="3">3</option>
									<option value="4">4</option>
									<option value="6">6</option>
									<option value="7">7</option>
								</select>&nbsp;&nbsp;<button data-i18n="Clear" class="btn btn-danger" ng-click="CleanupShortLog()">Clear</button></td>
							</tr>
							<tr>
   								<td align="right" style="width:60px"><label><span data-i18n="Minutes"></span>: </label></td>
   								<td><input type="text" id="comboshortloginterval" name="ShortLogInterval" style="width:60px" class="text ui-widget-content ui-corner-all" /></td>
							</tr>
							</table>
						</section>
					</div>
This lets you manually type in the minutes for better tweaking
shame I could not get it to work in seconds
MaikelK
Post by MaikelK »
Cant we get this as a standard in the Settings instead of manually have to add it again after an update?
Maybe a warning stating that for example 1 minute will make your database quite big?
It would even be better to be able to select it per sensor if you want it in minutes or 5 minutes for example.
Twoink
Post by Twoink »
Where can i find SQLServer.cpp ?
Twoink wrote: Tuesday 24 September 2019 10:41 Where can i find SQLServer.cpp ?
SQLServer.cpp is not part of the domoticz source. Maybe you are looking for ./main/WebServer.cpp or ./main/SQLHelper.cpp ?
pizzulicchio
Post by pizzulicchio »
MaikelK wrote: Saturday 09 February 2019 16:46 Cant we get this as a standard in the Settings instead of manually have to add it again after an update?
Any update about this ?
How is possible to submit a sort of "feature request" to dev team ?
I have edited the html code and ... i know... it's not "funny" to edit again at every update...
pizzulicchio wrote: Tuesday 07 April 2020 12:18 How is possible to submit a sort of "feature request" to dev team ?
You can submit a pull request on github. If it would be accepted it will be merged in a future Beta.
pizzulicchio
waaren wrote: Tuesday 07 April 2020 13:38
DONE!
https://github.com/domoticz/domoticz/pull/4063
Jufo
Domoticz version: 3.9389
Post by Jufo »
This option (html) has been withdrawn, must be added manually :cry:
pbraspi
Post by pbraspi »
Hi all, I am a newcomer with Domoticz. Got my RaspPi to read the electricity and gas from the P1 port of my digital meter. Would now like to display the 15 minute interval data. Does this last posting mean that changing setup.html does not work anymore ? As I made the setup.html change but cannot see the changes (deleted cache, used private/incognito windows on different browsers). Thanks for any help !
Tees
Post by Tees »
The solution of changing the setup.html still works perfectly fine on the last version of Domoticz.
I would wish however that we would be able to set the interval per device, I have my power meter that updates every minute (and now also shows that in the graph thanks to this tweak!), but my solar panel converter updates every 5 minutes, so I now get a stepped graph for that one...
Even better would be to update the graph for every new value, with the possibility to set a minimum time (1 or 5 minutes or whatever one likes).
