Page 97 of 123
Posted: Tuesday 19 September 2017 15:41
by pandemicz
For all those of us, who had a problem with left click on wireless switch, there's a .150 update rolling out, which is fixing the problem, just checked.
Posted: Tuesday 19 September 2017 17:55
by timh1004
pandemicz wrote:For all those of us, who had a problem with left click on wireless switch, there's a .150 update rolling out, which is fixing the problem, just checked.
Finally
thanks for notifying!
Edit: mine‘s not yet ready for the update
Posted: Tuesday 19 September 2017 18:23
by deennoo
OK cool which mihome app version dis you have ?
Posted: Tuesday 19 September 2017 18:31
by pandemicz
deennoo wrote: Tuesday 19 September 2017 18:23
Currently on 4.3.11
Posted: Tuesday 19 September 2017 18:50
by deennoo
pandemicz wrote:deennoo wrote: Tuesday 19 September 2017 18:23
Currently on 4.3.11
Same for me, update Fw isn't available on my side...let's wait
Posted: Wednesday 20 September 2017 16:28
by islandman
deennoo wrote: Tuesday 19 September 2017 18:50
Currently on 4.3.11
You need to update the firmware from the gateway not the APP
Posted: Wednesday 20 September 2017 16:35
by chatainsim
islandman wrote: Wednesday 20 September 2017 16:28
pandemicz wrote:
Currently on 4.3.11
What do you meen by that ?
I'm checking the firmware update by opening Mi Home app, then select the gateway, three dots then Check for firmware update.
Posted: Wednesday 20 September 2017 16:40
by deennoo
islandman wrote:deennoo wrote: Tuesday 19 September 2017 18:50
pandemicz wrote:
Currently on 4.3.11
Thx bro...not my First update, just need to check it...and be sure...app update can improve Fw update since their is no other way to ask for it...
Posted: Wednesday 20 September 2017 19:20
by DAVIZINHO
hello!,
In xiaomi mihome app there is a easy scene that i want to replicate in domoticz.
Now i can create a scene with blocky that turn purifier on when detect movement in the sensor but i cant make this other scene:
"when move detector not detect move in 30 minutes, then purifier off"
Anyone can help me?. I tried with blocky but i cant
thanks
-David-
Posted: Wednesday 20 September 2017 20:29
by pandemicz
DAVIZINHO wrote: Wednesday 20 September 2017 19:20
hello!,
thanks
-David-
Show what you got in Blocky
Posted: Wednesday 20 September 2017 21:45
by marcotini
I just update to the version 3.8424 and... why the water leak doesn't appear to the unused devices?
Posted: Thursday 21 September 2017 9:27
by borewicz
Has anyone managed to start the (Xiaomi Aqara Temperature Humidity) pressure sensor with homebridge / edomoticz ?
EVE shows it as voltage sensor with "0" :/
Posted: Thursday 21 September 2017 12:29
by Peggy
chatainsim wrote: Friday 15 September 2017 10:14
xbox2610 wrote: Thursday 14 September 2017 22:17
Hi everyone I wanted to ask if by accident there are working problems with aqara human body sensor and domoticz?
I have some issue with body sensor (1st gen) that doesn't detect motion but it's not related to Domoticz has I also can't see the motion in Mi Home.
My feedback, as I use 4 of them for alarm purpose :
- One have been triggering some "false positive" alerts during 4 weeks. Now it is back to normal.
- The last one I received, I put it above my front door, in a dry place, facing the ground. It immediatly started sending continuous motion alerts, non stop for 24h. Now it is indoor, no problem. I will check whether the other sensors get crazy as well outside.
The other ones are working fine.
Posted: Thursday 21 September 2017 18:33
by xbox2610
Hi everyone I wanted to know if the aqara human body sensor work with domoticz?
Thank you
Posted: Thursday 21 September 2017 18:38
by timh1004
xbox2610 wrote:Hi everyone I wanted to know if the aqara human body sensor work with domoticz?
Thank you
It does work! But the built in brightness sensor is not very accurate :-/
Posted: Thursday 21 September 2017 19:04
by timh1004
I was able to update the gateway firmware to 1.4.1_150.0134 with the latest iOS version of the MiHome App. Finally, the left button of the wall switches works again!!
Posted: Thursday 21 September 2017 21:33
by DAVIZINHO
pandemicz wrote: Wednesday 20 September 2017 20:29
hello!,
thanks
-David-
i use this blocky to turn on the purifier.
But i want to create a blocky to turn OFF the purifier when not detect movement in "movement sensor" in 30 minutes
Posted: Thursday 21 September 2017 21:35
by deennoo
DAVIZINHO wrote:pandemicz wrote: Wednesday 20 September 2017 20:29
hello!,
thanks
-David-
Use LUA that the only way to do your script
Posted: Thursday 21 September 2017 21:52
by DAVIZINHO
deennoo wrote: Thursday 21 September 2017 21:35
ok, thanks for the info.
Can you tell me how can i make this on lua?.
I only need help for the "if" comand because i dont know how to program the "if sensor not detect move in 30min then"
Posted: Thursday 21 September 2017 22:35
by Egregius
With pass2php:
if(timestamp('motion')<time-1800&&status('motion')=='Off'&&status('purifier')=='On')sw('purifier','Off');
Can it be more simple?
Let's see how much code you'll need in lua to do the same...
