DannyElfman
Domoticz version: 3.8136
Post by DannyElfman »
Thanks but I'm not sure I get it :)
It could be done or it has be done ?
And what kind of "more appropriate" device ?
Debian Jessie VM on EsxI on a Gen 8 Proliant + RFXCom + AeonLabs Zwave+ + Fibaro eye + Fibaro Smoke + Fibaro FGS211 Philips Hue + Harmony Hub + Somfy RTS + Oregon Temp sensors + Xiaomi Gateway + Xiaomi sensors + Sonoff basic
macher
Post by macher »
Why wired wall switch can't be selector? If I understand only wireless can be as selector switch why not wired? In logs in MI Home it detects click and double clicks
ratjenl
Post by ratjenl »
pvm wrote: Wednesday 06 September 2017 21:49 ratjenl
Do you have these devices available in Domoticz? Then you should be able to play a sound using blockly, some instructions on https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
Did you see those? Does that help you?
I already followed the wiki but didn't read about the blockly scripts. I will try and learn blockly thnx
corbin
Post by corbin »
DannyElfman wrote: Thursday 07 September 2017 10:58 Thanks but I'm not sure I get it :)
Not included in the main beta yet - https://github.com/domoticz/domoticz/pull/1794
deennoo
Post by deennoo »
macher wrote:Hi,
Double click or both click ? Single button or double button. ?
Please give us more information and à log or screen about it
http://domo-attitude.fr
macher
Post by macher »
It's dobule button switch (Xiaomi QBKG03LM Aqara Wall Switch ZigBee Version)
chatainsim
Domoticz version: v4.11307
Post by chatainsim »
matteos1 wrote: Tuesday 05 September 2017 19:18 Cattura.PNG
i think is better
chatainsim wrote: Tuesday 05 September 2017 17:14
matteos1 wrote: Tuesday 05 September 2017 16:38
hy thank you
could see this picture and transform in lua?
It's too small to read text.
Does it work ?
Because the If and Else if is almost the same and only the If should be triggered and never the first Else If.
Here is a start :
time = os.date("*t")
if (devicechanged['Bagnetto Aqara'] == "On" and otherdevices['Bagnetto Aqara Lux'] >= "35" and time.hour > 8 and timeofday['Daytime']) then
	commandArray['Group:Bagnetto lux > 34'] = "On"
elseif (devicechanged['Bagnetto Aqara'] == "On" and otherdevices['Bagnetto Aqara Lux'] >= "35" and time.hour > 8 and otherdevices['Xiaomi Porta Bagno'] == "Closed" and timeofday['Daytime']) then
	commandArray['Group:bagnetto seduto'] = "On"
	commandArray['Yeelight LED (Mono) Bagnetto'] = "Off"
elseif
Jumper3126
Post by Jumper3126 »
I have several of the zigbee powerplugs around the house to form a mesh. Occasionally however there is some problem, causing several sensors and plugs to be offline. I could add more plugs to solve this, but I read it is now also possible to add a second gateway.
What is the experience of this? Will a second gateway function as a repeater for the zigbee singal.Does it perform similar to the plugs or is is perhaps even stronger/better?
Sevift
Domoticz version: Latest
Post by Sevift »
Hi.
I have - Xiaomi Aqara Smart Light Switch WXKG03LM single-key.
Domoticz adds only a battery device. Light/Switch device does not appear. In MiHome everything works fine. Is this related to the Xiaomi gateway firmware (149)?
matteos1
Post by matteos1 »
sorry but language in block and Lua are different?
chatainsim wrote: Friday 08 September 2017 9:19
i think is better
Does it work ?
Here is a start :
elseif
deennoo
Post by deennoo »
Sevift wrote:Hi.
That à Fw problème, api doesn't send info about this switch, wait for gateway update
deennoo
Post by deennoo »
macher wrote:Image
OK just test it, and yeap double Click is on app, but not on api, gateway doesn't send this info/order.
You can activate Xiaomi log on domoticz following this : https://www.domoticz.com/wiki/Xiaomi_Ga ... leshooting
Activating raw message will show everything who is send by the gateway and can be use on Domoticz.
Stanleyk
Post by Stanleyk »
macher wrote: Friday 08 September 2017 9:02 Image
Have you got double button in domoticz ? because, I install double button wired switch yesterday, but no time for configuration. today I check remotely domoticz server and he say that have new xiaomi wall switch. So I add switch from device tab to repository, but I have just one on/off switch..
frigide
Post by frigide »
I have a Xiaomi gateway but when is activate the Xiaomi Gateway MP3 in a script or manually Domoticz crashes. Is this a common problem.
DannyElfman
corbin wrote: Thursday 07 September 2017 23:13 Not included in the main beta yet - https://github.com/domoticz/domoticz/pull/1794
Thank you Sir for this info (and for that great tool :P
macher
Post by macher »
deennoo wrote: Friday 08 September 2017 15:23
macher wrote:Image
Ok I saw in gateway log that it not send information about double click... but... if i click double it send for examle that is clicked two times "Off". So maybe there is posibility to code it in domoticz. For example if gateway send that button has been clicked 2 times "Off" in time range 1 secound than it is double click?
Andree
Post by Andree »
Hi to all,
this new water sensor work in domoticz?
https://www.gearbest.com/home-smart-imp ... 68897.html
Thx
deennoo
Post by deennoo »
macher wrote:Image
You can do it by your own using lua script. Gateway support only support what is send from the gateway.
Mace
Domoticz version: 3.8153
Post by Mace »
My Xiaomi works great in Domoticz with the attached sensors (human body, temp&humidity sensors), but when I want to trigger something on the device itself(fe ring the doorbell), I'm getting an error:
'Error: XiaomiGateway: unable to write command - Invalid Key"
Search thru a lot of posts, but can't find an answer on how to solve this. I'm currently on the latest Beta, I was running on the latest stable production version, upgrading to beta didn't help.
nizaga
Post by nizaga »
Hi, my xiaomi gateway was running ok until i changed the gateway's IP. Even if i updated the IP in the hardware section, devices are not responding. i tried to update the IP (same password) but no way.
Once the gateway's ip changes, do you need to reset the gateway and start over again with the app, and so on?
thanks
