Page 92 of 94
Posted: Tuesday 11 August 2020 6:06
by IpMan
Trying to use UsbSerialDrivers DSM 6.2 v6-7 on a DS720+ but getting:
cp210x: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
Posted: Tuesday 11 August 2020 10:02
by jumbotroll
IpMan wrote: Tuesday 11 August 2020 6:06
Test the New uploaded USBSerialdrivers package.
I wil build new domoticz package later today.
Posted: Tuesday 11 August 2020 10:11
by jumbotroll
whistler wrote: Sunday 09 August 2020 22:09
jumbotroll wrote: Tuesday 14 July 2020 20:10
eSbek wrote: Tuesday 14 July 2020 15:45
@jumbotroll
I upgraded from 2020.1.11835-8 to 2020.2.12213-8 (cedarview version, DS412+) and domoticz hangs / stops after the start. I had to go back to 2020.1
I have also seen that this happens occasionally in recent versions. I have not located the problem, but if you press RUN a couple of times in the package center on domoticz, it tends to start. It also usually starts immediately after a reboot of the NAS.
If you use Python plugin, it can be a plugin problem?
Remember to also install official Python3 package from synology first if you install domoticz with python or domoticz will not run.
For me Domoticz beta ver. 2020.2.12213-8 (on Synology DS215j) does not work at all. The installation went smoothly, but now even trying to restart Domoticz several times does not work. So all my sensors and actors got stupid. I am waiting for a new beta update hoping that Domoticz will start working again.
Best regards
1. Did you install the Python 3 package from synology first ? . domoticz with python plugin don't start if you not install this package first.
2. Did you test domoticz package without python plugin? This should start on you NAS without Python package.
Posted: Tuesday 11 August 2020 15:02
by whistler
jumbotroll wrote: Tuesday 11 August 2020 10:11
Best regards
1. Yes I installed Python 3 package from Synology before I started using Domoticz at all (more than year ago I think). Should I reinstall this package before any Domoticz upgrade?
2. Thanks for the solution, I didn't thik about that (shame on me...) and I can get Domoticz after install beta version 6.2_2020.2.12233-8 without Python. But... It would be nice to have running version with Python
Posted: Saturday 05 September 2020 10:36
by eSbek
my situation is similar, 2020.2 crashes on python plugin manager (segmentation fault). Deleting the plugins from plugin folder makes Domoticz starts properly. I found the plugin developers had to rewrite the plugin for 2020.2 and made it with Python v3.7.3.
https://www.domoticz.com/forum/viewtopi ... 00#p246401
"Yesterday we installed Domoticz v2020.2 and saw lots of issues due to changes in Domoticz, Python and pymodbus plugin versions, after a whole day programming, troubleshooting and adding new and better features we have updated the plugin, changelog:"
Anyway new plugin is still not compatible with our 2020.2 and crashes it same way probably due to python3.5 used in our Domoticz.
Posted: Sunday 06 September 2020 18:13
by jumbotroll
eSbek wrote: Saturday 05 September 2020 10:36
Test latest build.
I have updated to Python 3.7.7.
BTW. This packages are with full Python package and is much larger.
Not tested plugins because I don't use python plugins.
Please test..
Not all packages is updated yet.
http://www.jadahl.com/domoticz_2020.2_python_6.2/
Posted: Sunday 06 September 2020 19:30
by SteGe
Hi Jumbotroll, thanks for your great support and help so far!
I have tried this version last week (or did you include the python package today?) but unfortunately it didn't work. Seems like there is still a reference to the synology version of Python in the python plugins...
Posted: Sunday 06 September 2020 19:51
by jumbotroll
SteGe wrote: Sunday 06 September 2020 19:30
I'm updating the Domoticz v2020.2.12337-8 today.
Bromolow is not yet updated, check back in later tonight.
Posted: Sunday 06 September 2020 19:57
by SteGe
Wouw that is great! Thanks so much! Will try it tomorrow!
Works like a charm! Only downside is that buienradar plugin isn't working with this python version, but I rather have Domoticz working in the latest version than have other problems and buienradar working.
Posted: Tuesday 08 September 2020 15:21
by whoami
Hi there, just update my synology from DS218 to DS220+, but I can not find the package...
Is ther not a package yet? Otherwise I did not bought another one
Posted: Tuesday 08 September 2020 17:24
by eSbek
jumbotroll wrote: Sunday 06 September 2020 18:13
Test latest build.
Please test..
Great work Jumbotroll
I got the domoticz working/not crashing after I found and install python 3.7.7 for synology here:
https://synocommunity.com/package/python3#
(select your architecture, download and manually install in DSM package center)
Now I have to work now on modbus plugins (dependecies etc, cause something is not working as expected)
PS. As I remember some people had issue with OZW after first startup of 2020.2 (crashing the Domoticz), if it happens just delete the OZW cache and restart Domoticz.
Posted: Tuesday 08 September 2020 19:15
by jumbotroll
whoami wrote: Tuesday 08 September 2020 15:21
Yes I have build packages for DS220+
without python:
http://www.jadahl.com/domoticz_2020.2_6 ... geminilake
With python push the Beta button.
http://www.jadahl.com/domoticz_2020.2_p ... geminilake
Posted: Tuesday 08 September 2020 19:17
by eSbek
@Jumbotroll
So I found that a python3.7 is located in domoticz lib folder (unlike 2020.1 where the system python was used).
My plugins didnt want to work as domoticz couldnt find dependencies installed in my DSM python (also 3.7.7).
The workaround was to rename domoticz python3.7 folder to python3.7_bak (just in case instead of deleting it) and just copy my python3.7 folder with all site packages from the /volume1/@appstore. Modbus can read and write registers.
Is there a way to use system modbus like before (was Domoticz somehow pointing to system python?)
Posted: Tuesday 08 September 2020 19:23
by jumbotroll
eSbek wrote: Tuesday 08 September 2020 19:17
@Jumbotroll
I don't use python on my system, so I'm sorry that I can't give much support on this.
With latest domoticz with python3.77 I don't think you have to install The Python package at all because it's with the domoticz package.
Posted: Wednesday 09 September 2020 7:25
by eSbek
...but in this case I can't use any external libraries like Viessmann heat pump ViCare api that must be installed in DSM (pip3 install PyViCare) or PyModbus (pip3 install pymodbus pymodbusTCP).
I'm not an expert, but maybe it's possible to use DMS python3.7.7 like a system installed python configuring it with symlinks, etc? Anyone can advise if it's possible and then PIP3 and will work as expected?
Posted: Wednesday 09 September 2020 12:45
by eSbek
OK, I got the solution.
1. Remove any Python3 you have installed in the DSM.
2. as you have Python3.7.7 in domoticz just add the bin folder to the PATH:
Edit etc/profile file and add to PATH "/volume1/@appstore/python3/usr/bin/", it should look like that
"PATH=/volume1/@appstore/domoticz/bin:"
To apply the above run the command: sudo source /etc/profile
Now you can type python3 or python3 -V in terminal, it should run python3.7.7 or show you the version 3.7.7 if you used python3 -V command
Now you can install pip (curl -k
https://bootstrap.pypa.io/get-pip.py | python3) and all you need....
My domoticz log doesn't show any more errors related to python anymore.
Also I can run any python.py scripts from the cron using Python3.7.7
PS. for the cron I had to edit crontab file (etc/crontab) and add python Path "PATH=/volume1/@appstore/domoticz/bin"
Posted: Saturday 12 September 2020 14:44
by SteGe
Just a silly other question, I get random errors now from OpenZWave. Already removed the old hardware and hard reset the controller but got this message:
OpenZWave: Exception. Type: 101, Msg: Invalid ValueID passed to IsValueReadOnly, File: /home/dahl/spksrc-master/spk/domoticz_python/work-bromolow-6.2/open-zwave-read-only/cpp/src/Manager.cpp (Line 1789) OpenZWave.cpp:4961
Seems like there is a reference to your install @jumbotroll?
Posted: Monday 21 September 2020 12:10
by whoami
eSbek wrote: Wednesday 09 September 2020 12:45
Yes! I got the errors on my DS220+ also when connecting Domoticz with Phoscon App with the Conbee2 USB stick. It was stating that there were missing pip requests and could not install them on the normal way.
Setting the right path made it possible to execute: sudo -H pip3 install requests
Now I see finally all zigbee devices!
Posted: Monday 21 September 2020 14:25
by jellex87
Can someone tell mee what is the latest Domoticz version for the Synology DS213?
And where to download?
Thanks in advance!
Posted: Thursday 24 September 2020 11:41
by eSbek
check Jumbotrol's website:
