Great approach, looks great! I've been looking for a solution to gather the all main data into one dashboard, including e.g. switches, temperatures, traffic and train details etc; so far the best alternative I've found.
After several hours of fiddling with the dashboard, most of the external stuff (traffic, cameras and so on) are in place, but no Domoticz switches or temperatures. Cannot figure out what's wrong, maybe you guys could help out. For example, a switch from json:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 2,
"HardwareName" : "RFXCom",
"HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
"HardwareTypeVal" : 1,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "0F7E8A2",
"Image" : "Light",
"IsSubDevice" : true,
"LastUpdate" : "2016-10-04 13:08:46",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 15,
"Name" : "Block",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "AC",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Lighting 2",
"TypeImg" : "lightbulb",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "13"
That inserted into the switches section in settings.js should be:
['13', 'Data', 'cell1', 'Block', 'onbutton'],//onbutton = only push on
But nothing, I've tried all the options I could figure out with no luck.
Same goes with my thermometers:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 100,
"CustomImage" : 0,
"Data" : "8.3 C",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 2,
"ID" : "8800",
"LastUpdate" : "2016-10-04 15:42:02",
"Name" : "Outer_temp",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SignalLevel" : 7,
"SubType" : "Viking 02811/02813, Proove TSS330",
"Temp" : 8.300000000000001,
"Timers" : "false",
"Type" : "Temp",
"TypeImg" : "temperature",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "12"
That in other devices should look something like:
['12', 'Temp', 'cell10', 'Ulkolampo', 'Ulko', '#C0382B'],
Again, nothing anywhere but don't know where's the problem.
Even the log page is empty, maybe there's an issue the Domoticz connection. Or something. Any advice would be highly appreciated.
